Question about Toshiba Satellite A105-S2031 Notebook
Laptop has 2 gigs of memory. On start up, laptop freezes at "In Touch With Tomorrow TOSHIBA" screen. Neither of the 2 choices offered (F2 of F12) work. Nor does any attempt to start in safe mode. Removed memory in various configurations resulting in no change to blank screen with hard drive clicking. Even tried installing original memory just in case one of the current module went bad. Same results depending on which bank I used. I would assume that even if the hard drive was bad, I should be able to reach the set up screen??? Any suggestions? Thank you, Ralph
6ya staff
SOURCE:
sandrew
andrew pester
  • 2961 Answers
SOURCE: Laptop Freezes During Startup, before I can press any buttons or anything.
It could be a corrupt bios, which can be deleted with the removal of the bios battery or by the 'JBAT1' terminal to pins 2-3 then back to 1-2. The bios is probably set to halt on all errors and thats why it only goes so far. If there is no action at all; then there is a power failure to the motherboard or the processor has failed. Depending on your notebook age is whether it's economical to repair.
Posted on Jan 04, 2007
gc2531
SOURCE: Toshiba Satellite L25-S119 No boot
Had the same problem turned out to be the DVD drive. Apparently it won't boot if the DVD drive is not recorgnized.
Posted on Feb 21, 2008
Nixcroft
Uwe Klopfer
  • 137 Answers
SOURCE: bios batt
if you leave it long enough does it boot ?
press F2 and go through the settings and check for something like "display boot menu" or similiar.
remember to save your settings upon exiting
Posted on Nov 21, 2008
Ekse
  • 13434 Answers
SOURCE: I Have an hp ze4300 laptop. it will not boot up?
Seems the laptop doesn't start up properly, the bios maybe corrupt or you have a hardware fault.
the bios may need to be reprogrammed and parts need to be tested to see what the problem is.
Theres not much we can do about this, you will have to take the laptop to a professional or contact hp for assistance / repairs.
Posted on Jan 03, 2009
Anonymous
  • 54 Answers
SOURCE: Toshiba L35-s2174 stops on boot at the BIOS screen ...
Your problem sounds hardware related which boils down to really only 3 things, CPU, Memory, or motherboard.
If you have more then one RAM chip installed, try removing both and booting the laptop with only 1 inserted individually, if it works fine with one chip but not the other then thats your problem. Its statistically inprobable that both chips would be bad so if it behaves the same way with both chips the problem is likely bad CPU, bad Mobo, or possibly a corrupted BIOS.
Posted on Jan 20, 2009
Check system then press f1 key
Try this:
Instructions
    • 1
      Insert the Toshiba A60 recovery disc into the CD/DVD-ROM drive.
    • 2
      Power off the Toshiba (with the recovery disc still loaded inside the optical drive).
    • 3 Hold down the "F12" key, at the same time hit the "Power" button to turn the system back on. You don't have to hold down the Power button, but keep holding the F12 key.
    • 4
      Release the "F12" key when the" In Touch with Tomorrow TOSHIBA" screen is displayed. This will open up the BIOS.
    • 5
      Change the boot order by using the arrow keys to select "CD/DVD ROM" icon in the menu. The Toshiba will now boot from the recovery disc and restore the system. Follow any additional on-screen instructions.
Aug 19, 2012 | Toshiba Satellite A60-S166 Notebook
I restarted my Toshiba satellite a305 and now it won't boot up or go into safe mode. It comes to the start up screen that says press f2 for setup f12 for boot manager. It will let me go into setup and boot...
If it won't let you go to safe mode,then there's something that the BIOS(setup) or Boot Manager needs before starting the operating system(Windows Vista). You should have a Toshiba Recovery Disk which will fix this . The disk will not touch any of your current files and data,so don't worry about that.
Apr 12, 2011 | Toshiba Satellite A305-S6908 Laptop
My Toshiba A135-S2246 has a black screen. External monitor will not work, hard drive lights for a second then stops, can't get into BIOS or any other help (F2,F8,F12)screen.
Start taking your laptop apart piece by piece and test it after each removed component:
1. Remove the hard drive and test the laptop.
2. Remove the DVD drive and test the laptop.
3. Remove the wireless card and test the laptop.
4. Unplug the display panel from the motherboard/video card and test the laptop.
etc....
Continue taking it apart until you have only three major components connected: motherboard (with video card), processor, and memory. If you still experience the same problem, most likely it's bad motherboard.
By the way, before you start, try reconnecting the memory module. If you have two modules installed, try removing them one by one and test the laptop with each one separately.
Sep 19, 2010 | Toshiba Satellite A135-S2246 Notebook
Toshiba satellite L300 freez...
Hi the problem sound familier, Firstly unplug all the USB devices from the notebook and remove the battery and the power cable and press and hold the power button for 10 sec and then remove the memory from the notebook one by one if there is more then one and reset it agian and try to connect the notebook on power cord and check. let me know about it.
Feb 13, 2010 | Toshiba Satellite L300D-ST3501 Notebook
Splash screen comes up with f2 to enter setup f12 for boot options but freezes will not proceed no farther
First of all if it will let you press F2 and see if you can reset the BIOS to default configurations. Hit F10, save the changes and exit the BIOS.
The computer will restart and hopefully boot to the operating system boot screen.
If it's still freezing on post then remove the battery and the AC power supply. Turn the laptop over and locate the RAM (memory) cover and remove the holding screw.
Take out the system memory and clean the brass contacts, also clean the slots that the memory sits in.
Re-seat the memory making sure it clips into place nice and tight and replace the RAM cover.
Return power to the laptop and turn it on to see if that has helped.
Good luck.
Sep 29, 2009 | Toshiba Satellite A205-S4617 Notebook
Starting problem
not sure on model what f2 or f12 is
f2 enter bios
f12 choice menu
options:-
re-install xp
repair xp
flash bios
Jan 06, 2009 | Toshiba Satellite A135-S4527 Notebook
Bios batt
Sep 20, 2008 | Toshiba Satellite M100 Notebook
Frozen Computer
If you know some one with a xp disk you can use it as a tool to boot up. Once it is booted up it will write a log file and it should work
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Jan 12, 2008 | Toshiba Satellite M35X-S163 Notebook
Jan 04, 2007 | Toshiba Satellite A105 Notebook
Open Questions:
change password MOZILLA email #{18OO~8O31O69} phone number usa asif There are two circumstances that can cause someone to want to change his/her MOZILLA password: 1 forgetting the MOZILLA password and needing to recover it and 2 to change the MOZILLA password. The latter can be because the MOZILLA password has leaked to someone or the user wants to adhere to the good practice of changing his/her password periodically. It is a good practice to change one's MOZILLA password at least once in a month. Contact MOZILLA Mail Password Reset 1-8OO-8O3-IO69 . For your convenience to contact MOZILLA Mail Password Reset We have provided all possible information of MOZILLA Mail Password Reset. You can contact MOZILLA Mail Password Reset on the given phone number 1-8OO-8O3-IO69. Changing an MOZILLA Password The following steps show in detail how to change an MOZILLA password when the current password is known: Sign into the MOZILLA Mail Account from MOZILLA Do you want to recover/reset your MOZILLA email password? So you'll be do the some steps to recover your MOZILLA password. We'll help you to fix your problem and we'll guiding the some steps to recover your MOZILLA password. Follow and do the below steps to recover your MOZILLA email password- Go to the MOZILLA - login page. Enter your Username or Email address and click next. Click Forgot Password below the Password field. Enter your Email address and click Next. Verify your Email address or Phone Number and click on the Next. Open your Email account and check your MOZILLA mail message on your Gmail account. MOZILLA is an abbreviation for America Online, one of the country's earliest providers of internet and email services. While MOZILLA's dial-up internet is not as widely used as it once was, many people still use the company's email service. It's a great email service that lets you stay connected with your family and friends -- that is if you remember your password. Forgetting your password on any internet service is an annoying and sometimes painful process; thankfully, MOZILLA has made it easy to recover or reset your account's password. *Please Read* If you don't remember or didn't sign up with one your alternate email address, or you didn't use a mobile phone to register, you will not be able to reset your MOZILLA password. If you find yourself in this situation, create a new account. If you do have access to your alternate email or mobile number, follow the steps below to reset your MOZILLA password.
Oct 23, 2019 | Mozilla Computers & Internet
change password MS OUTLOOK email #{18OO~8O31O69} phone number usa asif There are two circumstances that can cause someone to want to change his/her MS OUTLOOK password: 1 forgetting the MS OUTLOOK password and needing to recover it and 2 to change the MS OUTLOOK password. The latter can be because the MS OUTLOOK password has leaked to someone or the user wants to adhere to the good practice of changing his/her password periodically. It is a good practice to change one's MS OUTLOOK password at least once in a month. Contact MS OUTLOOK Mail Password Reset 1-8OO-8O3-IO69 . For your convenience to contact MS OUTLOOK Mail Password Reset We have provided all possible information of MS OUTLOOK Mail Password Reset. You can contact MS OUTLOOK Mail Password Reset on the given phone number 1-8OO-8O3-IO69. Changing an MS OUTLOOK Password The following steps show in detail how to change an MS OUTLOOK password when the current password is known: Sign into the MS OUTLOOK Mail Account from MS OUTLOOK Do you want to recover/reset your MS OUTLOOK email password? So you'll be do the some steps to recover your MS OUTLOOK password. We'll help you to fix your problem and we'll guiding the some steps to recover your MS OUTLOOK password. Follow and do the below steps to recover your MS OUTLOOK email password- Go to the MS OUTLOOK - login page. Enter your Username or Email address and click next. Click Forgot Password below the Password field. Enter your Email address and click Next. Verify your Email address or Phone Number and click on the Next. Open your Email account and check your MS OUTLOOK mail message on your Gmail account. MS OUTLOOK is an abbreviation for America Online, one of the country's earliest providers of internet and email services. While MS OUTLOOK's dial-up internet is not as widely used as it once was, many people still use the company's email service. It's a great email service that lets you stay connected with your family and friends -- that is if you remember your password. Forgetting your password on any internet service is an annoying and sometimes painful process; thankfully, MS OUTLOOK has made it easy to recover or reset your account's password. *Please Read* If you don't remember or didn't sign up with one your alternate email address, or you didn't use a mobile phone to register, you will not be able to reset your MS OUTLOOK password. If you find yourself in this situation, create a new account. If you do have access to your alternate email or mobile number, follow the steps below to reset your MS OUTLOOK password.
Oct 23, 2019 | Internet Computers & Internet
See all Toshiba Satellite A105-S2031 Notebook Questions
Toshiba Satellite A105-S2031 Notebook Logo
70 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
