Question about Baby Lock Evolve
I need help threading baby lock model 5280E - Baby Lock Evolve
6ya staff
SOURCE:
Anonymous
SOURCE: Instructions for threading Baby lock eclipse BLE1LX for 2 thread sergering
I have just learned this :)
Either needle thread may be engaged for 2-thread serging.
1. Open the front cover and cutting blade cover, cut the upper looper thread just above the threading guide ( this is plate that has two holes for the threads) Raise the presser foot and pull out the clipped thread from under the foot. Remove upper thread from the machine (or you can leave the cone thread on, it doesn't matter).
2. Rotate the handwheel to bring the upper looper to its lowest position.
3. Rotate the subsidiary looper up and to the left, then slip the end into the upper looper thread eye from backside.(this sounds complicated, yes? but it is very simple : the looper has a counter part that is spring-locked to move from left to right and right to left. This is the little claw-looking part of the looper that when in the postion to serg with four threads is to the right side of the looper. It looks like a scorpion's tale. If you can't figure which part it is, use your finger to probe the looper and you'll feel it give a little. This part needs to be moved to the left - it will not slide over, but swing up and over and down, like an arch. Then, where the thread comes out of the looper is where you want the little claw-like part to hook into.)
4. Close the covers. Decrease the needel tension - this depends on what the stitch length is. Stitch length: 2-3, stitch width: 3.0 = L needle n/a, R needle 1; upper looper n/a, lower looper 5
stitch length: 2-3, stitch width: 5.0 = L needle 0, R needle n/a, upper looper n/a, lower looper 3.5
Those are for a flatlock stitch - for a 2-thread rolled edge :
Stitch length: 0.5, stitch width: M = L needle n/a, R needle 4.5, upper looper n/a, lower looper 3.5
Stitch lenght: 1.0, stitch width: M = L needle n/a, R needle 4, upper lopper n/a, lower looper 3.0
If you have any questions, e-mail me at [email protected]
Posted on Oct 28, 2008
Anonymous
  • 4 Answers
SOURCE: Baby Lock Evolve wire Looper threading tool
You have to get the replacement wires from a Babylock dealer, I did too then after sticker shock at the price of that wire I learned to make a thread cradle and use that to thread difficult threads no. Take about 24 inches of regular sewing thread and fold it in half, put the open ends (together, same legnth) into the jet air port and hold onto the loop end, press the jet air threader and it will thread the machine, insert the thread you want to use into the loop you have in your hand and pull it thru the machine using the ends of the thread you put thru the machine, sounds harder than it is and works all the time. No more spending $8 on replacement wires. You can use this method for all the jet air sergers.
Posted on Dec 07, 2008
trial2962
Val
  • 107 Answers
SOURCE: Threading illustrations too small
You might take a look on ebay item 160362974035
Posted on Jan 14, 2010
keeneddie
SOURCE: I have a Baby Lock
Assuming you mean a narrow rolled edge:
  1. Remove the left needle and thread.
  2. Open both the front and side covers.
  3. Raise the presser foot and the upper knife to the highest position.
  4. Clear the stitch fingers.
  5. Push the stitch with former release lever and remove the stitch former from the lower knife base. (Don't lose it!)
  6. Turn the stitch with adjusting dial until the "M" on the dial matches the red indicator on the needle plate.
  7. Set the stitch width length to "M".
  8. Close the covers, lower the presser foot and the upper knife.
This gives you a narrow edge. To roll the edge, increase the tension of the lower looper (the green knob) about three numbers higher than normal.
Posted on Nov 12, 2010
SOURCE: looking for a needle plate for a Baby Lock 5280E
try sewingpartsonline.com
Posted on Jan 20, 2011
How to thread my baby lock b15 machine
Something here may be helpful. Although they may not be your particular model, sewing machines tend to thread the same from model to model.
Be sure to ALWAYS RAISE the presser foot when threading the top thread!
Baby Lock b15 threading Google Search
Apr 24, 2018 | Baby Lock Sewing Machines
Hi, how can use 4 thread in serger baby lock vintage?thanks
It would probably help if you had an owner's manual. That should have the information you need for threading and using your machine. Search for:
Make Model manual
although I've frequently found that manuals for Baby Lock are not free.
Nov 12, 2017 | Baby Lock Sewing Machines
I have a Baby Lock 5280E. Can you tell me how to set the machine for rolled hem?
Nov 03, 2010 | Baby Lock Evolve
I have a Baby Lock BL4-736D serger. I need the
orange-(5-7)
yellow-(4-6)
green-(2-4)
blue-(2-4)
medium weight, 4 thread
Dec 06, 2009 | Baby Lock BL1556
May 29, 2009 | Baby Lock Eclipse Serger
Sewing Machines Logo
184 people viewed this question
Top Baby Lock Sewing Machines Experts
Chris Wetmore
Thomas F. Schneider
tsalagi152
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
