Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Kenmore Refrigerator 596.72913200 refrigerator is cold and freezer is cold but nothing is frozen
I have a Kenmore refrigerator, model # 596.72913200.
The top is the refrigerator and the bottom is the freezer.
Last week the refrigerator started warming up but the freezer remained cold.
The AC Evaporator Fan Motor seemed to be running fine, so I
thought it might be the Defrost Timer. I got a new Defrost Timer and put it in.
I turned the clutch screw once and the evaporator fan came back on and the refrigerator
started to get cold, but the freezer isn't freezing anything.
I have the refrigerator temperature and the freezer temperature set to "Coldest".
What else would you suggest?
  • 1 more comment
  • luseeedwards Jun 24, 2008
    Thanks Drcool299 for responding to my post. I ended up having the issue resolved by calling out a refrigerator repair technician. The problem turned out to be the Defrost Heater.
  • francis rivero May 11, 2010
    can you look at the bottom door rear wall if there is frost accumulation?
  • Anonymous Mar 25, 2014
    Cold freezer warm refrigerator
  • 958 Answers
Hi lussed,
your problem is still poping up even though it was resolve already. i guessed you should rate a technician in this form as to delete the work from the list of jobs to do.. i am on the way to solve it but you had it solve with a real technician.
can you just rate me?...thanxs...
drcool299
Posted on Jun 25, 2008
Why does my refrigerator keep acting up the freezer gets frosted up then the frig gets warm I have cleaned it underneath unplugged it for 24 hours then plugged it back in it works great for about a w
This problem can have many causes, but generally it is a defrost issue. If the freezer coils are frozen over, they block cold air flow to the refrigerator; and can be caused by different part failures. See the link below for a good explanation of possible failures and for parts. Also, if you turn the refrigerator temp to 0ff and unplug the refrigerator then plug it back in, it should go into defrost mode. Leave it that way for 15 or 20 minutes, then unplug and plug it back in. It may resolve the defrost mode problem. If not you'll need a part, or repair man. Kenmore Refrigerator Freezer is Cold But Refrigerator is Warm
Oct 18, 2014 | Kenmore Refrigerators
Kenmore coldspot 106
What is your model number?
Oct 09, 2013 | Refrigerators
Not cold enough
You have to balance the freezer and the refrigerator. The freezer runs both and if you have one set too low then the other suffers or if you have one set to high the other suffers. Make sure that nothing is blocking the air flow from the freezer to the refrigerator and make sure the coils in the freezer are not frozen with ice.
Aug 10, 2012 | Kenmore Side by Side Refrigerator
The freezer side is cold & food is frozen, but the refrigerator side isn't keeping food cold. Its warm!!
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 28, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Hi. My Kenmore frezzer model # 25326442100 is not working properly. Nothing is staying frozen but is a little more than slighly chilled. This freezer was only purshed in 2007. Any ideas to fix this...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 04, 2011 | Kenmore Freezers
I have a kenmore refrigerator model # 596.61864101 with a freezer on the bottom that is not getting cold enough top and bottom . food in freezer is not frozen solid and food in fridge is not cold , just...
heatman101
Jul 01, 2011 | Kenmore Refrigerators
Kenmore refrigerator top freezer
sounds like the freezer is frozen solid and not lettting the cold air down to the fridge. Make sure the freezer is going through the auto defrost cycle.
Jan 01, 2010 | Kenmore Refrigerators
Freezer cold fridge 52 degrees
We have a Kenmore Coldspot Model # 106.8770687 and the freezer is cold and keeping things frozen, but seems to be frosting over and the refrigerator is warm at 40 to 50 degrees ... any help regarding what to check is helpful! Or a schematic / manual
Jun 14, 2009 | Kenmore Refrigerators
Kenmore Elite Stainless French Door Not getting cold
This unit may be frozen up.  Defrost completely to allow the passages to get a free flow of cold air.
Nov 16, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
624 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
