Question about Durabrand Anti-Skip CD-895 Personal CD Player
Duranbrand Hm3817DT CD player won't play
We have the CD home music system and the CD player will not play CD's. It just spins one way then reverses and spins the other way. Its not even a year old. Any suggestions? I've tried cleaning everything I can see in the unit. Tried several CD's including brand new ones.
  • 2 more comments
  • Falisha T Jul 12, 2008
    I just bought a brand new Durabrand CD Home Music System and it only plays one track. I have tried cleaning it and reseting it and nothing works!
  • upsetbuyer Aug 03, 2008
    In decemeber, I bought a Durabrand CD Home Music System. I have tried svereal CDs and none work. On other CD players they work. It isn't even a year old.
  • selenapruitt Nov 03, 2008
    I have the same problem. It starts playing, stops, skips, plays then stops completely. It just spins. I tried cleaning the CD as well as the player, but it doesn't help.
  • Anonymous Dec 05, 2008
    i have the same problem..radio works fine but will not play cd's
2 Suggested Answers
mook76
  • 79 Answers
SOURCE: CD Home Music System HM3817DT
Try a laser eye cleaner. It possibly may need to be dusted on the inside. Overheating can cause strange things to happen to electronics.
Posted on Jul 19, 2008
I have my RCA music system it won't let me play music on it. What do I do?
Check the cd types that that system will play. Depending on the type of recorded material, some CDs won't play on certain systems.
Feb 08, 2013 | Audio Players & Recorders
Gpx stereo cd won't work
The laser pickup head has failed, or the pladder motor that spins the disc is open, or there is no voltage to the motor. Chances are the whole assembly will need to be replaced, but as a rule it is cheaper to replace the stereo.
Jun 23, 2012 | GPX HM3817DT Shelf System
The cd player will not rotate the cd that is in the machine. Its in cd function.
Hello
Check whether the CD loads into the mechanism fully inside. If it does not spins even after loaded well into the mechanism, the sled motor of the loader mechanism to your devie is faulty, and should be replaced. OK.
Aug 21, 2011 | GPX HM3817DT Shelf System
Can't load a cd...just out of the box
If you cant load a CD then it either doesnt belong in that CD player or your CD is to scratched up to play.
Dec 31, 2009 | GPX HM3817DT Shelf System
CD pops off
Despite the lack of set-up instructions with this product, I finally figured out I had to remove the cardboard disc covering the guts of the machine.
Dec 14, 2009 | GPX Audio Players & Recorders
My durabrand cd home music system wont come on
If you have no lights or power to the unit, check on the back of the unit to see if there is a twist and pull type knob for a fuse. If so, unplug the unit/player and take the fuse out. If it is damaged/broken/wire element burned/cracked, it will need to be replaced. Take the old fuse with you to make certain of a correct match(volt/amp/slow or fast acting)Most Radio Shack/Walmarts/Ace Hardware stores stock these type of fuses. They are very inexpensive, usually less than a $1 or $2. They are on most home entertainment equipment/t.v.s etc. to prevent some degree of lightning or power spike damage the unit.
Oct 13, 2009 | GPX HM3817DT Shelf System
I ripped a CD on my computer than tried to play it on the GPX it wouldn't play but the screen said "File". What does that mean and can I get it to play a ripped CD?
You have to burn a CD in "CD/Music" format. You can't burn it as a data CD. Which just sucks cuz doing it in CD format, you can only fit 15 or so songs on each CD. And I wasted a CD finding that out.
Aug 31, 2009 | GPX HM3817DT Shelf System
Durabrand CD Home Music System Model hm3817dt
If the unit is not under warranty then you can open it and have a look inside. Keep your eyes peeled for bad soldering joints and if it is dusty clean it out.
However if it is under warranty and you open it, then you will break the conditions of the warranty and if it needs repairing then you will be charged the full amount.
May 28, 2017 | Audio Players & Recorders
Jul 15, 2008 | Durabrand Anti-Skip CD-895 Personal CD...
Top Durabrand Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
