Question about VeriFone (M19755014US1) Magnetic Card Reader
Machine requires manual entry of credit card number, it used to read the cards by swiping it
  • 14 Answers
Buy a magnetic head cleaning card, swipe several time.
After clean the head, it will work again.
Here is link
http://www.gorillapaper.com/10pk-cleaning-swipe-cards.html
Posted on Nov 05, 2010
SOURCE:
My credit card scanner is not scanning pproperly. Have to punch in the numbers manualy. But my gift cards swipe great. I need help.
We are Fixya dot com. You need to contact your credit card merchant direct and get a new scanner sent to you.
Have you tried cleaning the reading head. Wrap a card in a thin piece of linen like a handkerchief or a J-Cloth and moisten it. Run through the card slot a few times.
Jun 20, 2018 | Punch Computers & Internet
Will aluminum foil protect credit cards
No! They make special cases for protecting them from radio wave theft devices.
Oct 06, 2015 | Ovens
Is there a way to quick swipe a credit card with no signature required for a small purchase?
Yes there is but I cant share it on the net , in case the info falls in wrong hands as it is a door to fraud
Apr 11, 2015 | Retail Supplies
What's the difference between a credit card and a debit card?
Credit cards work on "credit"
meaning that the card company trusts that you are good for the money and you
pay a bill at the end of the month. Debt
cards are similar to credit cards in the way that you can pay for things
without cash. However, when a charge
goes through on a debit card it is taken immediately and directly out of your
bank account. Many people prefer this
method because it prevents you from going into credit card debt.
Aug 08, 2013 | Finance
Can a credit card be processed using a code bar scanner?
no, you can't. bar code scanner only read bar code. Credit card should read using swipe card reader (using magnetic to read code behind black strip on credit card).
Aug 10, 2010 | Computers & Internet
How can i use credit card mashine
Following are the steps to use credit card machine
step1:Input the credit card numbers.If you have the credit card in hand, swipe it through the card reader. Most readers have a small icon or picture on them that shows which way the magnetic strip on the back of the card should be facing. If not, try running it
through the reader with the strip facing the machine first, since that is the most common direction. If you have a phone order, or do not have the credit card in hand, select the button marked "sale." On many machines this is also the "1" key, but it varies depending on the brand of the machine. Then follow the on-screen prompts to enter the card number and expiration date. Always double-check the numbers before pushing enter
step 2:
Input the sale information.Typically, the machine will first ask for the sales amount in dollars and cents. Input the amount using the number keypad. Double-check the amount to make sure it appears correctly on the screen and if it does, then push enter. If you accidentally input the wrong amount, look for the "clear" or "delete" key and start over. In some cases, the machine will prompt you for additional information after you've entered the sale amount. Follow the prompts to enter information, such as the customer's zip code or an order number.
step 3:
Wait for the sale to process. Depending on the machine's connection the sale may process within seconds or it may take a few minutes. If the machine seems to become "stuck" while processing a sale, do not re-enter the sale, but instead call the processing company's phone number for further instructions. In many cases this number will appear on a sticker on the machine.
step 4:
Process the receipt.If the customer is present, have them sign the credit card receipt. Give them the copy and retain the original for your records. If the customer is not present, write "phone-in" or another appropriate phrase on the signature line of the receipt. Keep one receipt for your records and include the other in the shipment of the goods to the customer.
step 5:
Close the batch.Double-check with your processing company, but most require you to run a "batch report" or close a batch of credit card receipts each day. This is the process that tells the company to finalize the credit card charges and deposit the balance to your account. Many machines will have a key that is marked "batch." You can press this key and then follow the prompts to close the batch at the end of the day. If the machine does not have a "batch" key, consult the user's manual for instructions or call your credit card processing company for instructions.
Thank you
Mar 14, 2010 | IBM Domino.Merchant Server Pack Upgrade...
I am trying to set up my First Data FD100 credit card machine to work with RPE, but am having problems doing so.
I don't think this machine will work within RPE. You should verify this with the vendor that sold you RPE. However, you can set RPE to manually accept credit cards and swipe them seperately with the FD100. Everything will report OK, it just takes more steps and more receipt slips.
Or you can set RPE to process with First Data and buy an MSR to attach to PC to swipe cards. Much quicker process and only RPE receipt(s).
If your unsure about setup for either approach, contact me at [email protected] .
Nov 17, 2009 | Pc America Restaurant Pro Express
Error message while attempting to swipe a credit card
ok only plug it with the keybord pluuged in and restart your machine that will work go to posspecialist.com if need any assistance
I’m happy to assist further over the phone at https://www.6ya.com/expert/jaime_08785c7d726a554e
Aug 24, 2009 | ID Tech Computers & Internet
VeriFone (M19755014US1) Magnetic Card Reader Logo
171 people viewed this question
Top VeriFone Televison & Video Experts
Marvin
Marvin
Slowride5551
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a VeriFone Televison and Video Expert? Answer questions, earn points and help others
