Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
When I plug in the flashdrive it won't light up and the computer says it doesn't recognize it.
  • Doctor PC
    Doctor PC Oct 24, 2010
    Try other ports?
  • SanDisk Master
  • 7,733 Answers
Try other ports.
Posted on Oct 24, 2010
2 Suggested Answers
SOURCE:
babes_ganda0
  • 381 Answers
SOURCE: it doesn't show up on the computer and the light on the flashdrive doesn't turn on
update the drivers of USB
Posted on May 23, 2009
Belkin mini mouse not working
try a different mouse if it works then your Belkin mini mouse
is defected.
Feb 07, 2018 | Belkin MOBILE RETRACTABLE Mouse WRLSUSB...
After copying 3.4 Gbyte or about 600 jpeg's to my Imation flashdrive 2.0 (4Gbyte) using my Apple Mac OS 10.5.8, I formally ejected the drive and inserted it into our Vista Windows machine. The Vista...
Plug the flash drive into the windows PC first and open "Computer". Find the drive and format it to Fat32 or NTFS. Now plug it into the mac and copy the pictures too it. Now your Windows computer should see the files. Mac will default to making the flash drive use HFS+ filesystem. Windows doesn't recognize this format at all. Mac will see fat32 and ntfs just fine though.
Aug 28, 2011 | Computers & Internet
My projector won't project anything. the computer recognizes the projector, but the projector does not recognize the computer. also when i turn on the projector the benq logo doesn't show.
Disconnect all inputs to the BENQ and power on. Do the lights come on as per normal operation. Does the lamp come on when the power button is pressed. Does anything show when the menu is selected.
Aug 19, 2011 | BenQ PB6240 Multimedia Projector
I plug in the sundisk cruzer 2.0 GB USB device and all it does is blink. It will not show up on my computer for the drive.
Hello
If the computer recognize that there is a device plugged into the system, then just try to plug the flashdrive into another port at the back of your case.
If the computer does not recognize that there is a device plugged in, there is a problem with your flash drive. It still gets power from the computer(Bliking light), but there is no data transfer between computer and flash drive.
If it is still under warrenty, send the flash in for repairs(presuming that your USB ports work), otherwise try and see if it works on a other computer. If it does, the the problem is with the USB ports on your computer. I really hope this can be of help.
Best regards
Andrea
Oct 28, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Heating up, light not coming on
cruzer micro 4GB, loaded with data. works perfectly in all systems except my xp. Problem didn't originate until after ghosting system to correct different problem. Now, error message states flashdrive not recognized. must then get behind pc, and gently work with it until i can hear the shift in the duo core processors and the orange light on the flashdrive comes on. Please help.
Mar 10, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Problem
Hello!
Hopefully I can try to walk you through a process that I would use.  First check to see if the flashdrive is damaged.  Usually the cases don't break, but the USB connector itself takes a lot of hits/damage/wear.  You should be able to see 4 metallic contacts on the USB connector and they should be in good shape.  Blow out any dirt/garbage in the connector as well.
Next is to see when you plug it in if the LED on it lights up at all.  If there is no light whatsoever, it is one of two things, either the flashdrive is totally broken or you have a failled USB port.  Either one is possible.  If possible, take the flashdrive and test it on another system, or at least another USB port.  That will give you some important information.
Assuming that the LED lights, then it is a question of getting Windows to recognize the drive.  If there is nothing important on the drive, fdisk the drive in DOS, then format it, and then Windows should recognize it, allowing it to be used.
If you have no LED lighting on the flashdrive, after testing on another system as well, get another flashdrive (or return this one if under warranty), since there are no real parts to service/fix.
Hope this helps out!
Ken
Jan 06, 2009 | Computers & Internet
Toshiba 4mb jump drive
try to jump from one usb slot to another until your computer recognizes your flashdrive.
Mar 25, 2008 | Computers & Internet
USB plug in recognition
Hello Silvertop01,
This is Romeet, id like to help you with the problem. Unfortunately it seems a lot of things that you love :) wont work right? well, Let me know if you are running windows xp with what service pack? service pack 1 or service pack 2? to do this, right click the icon " My Computer " and select properties,a system properties dialog will open, on the top right you should be able to see:
System:
Microsoft Windows XP
Professional / Home ( Depends what you have )
Version ( 2002 )
Service Pack X ( X could be 1 or 2 )check this and let me know
B.Regds
Romeet
Nov 30, 2007 | Dell Inspiron B130 Notebook
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
Top SanDisk Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
