Question about Lexmark X4580 InkJet Printer
I'm getting a Error 5 running command Setup.exe while tring to download the drivers
  • Lexmark Master
  • 7,733 Answers
Go to Lexmark - United Statesand find OEM drivers.
Posted on Oct 24, 2010
SOURCE:
Cant download skype, problem with toolbar, error 2738
Take a look in Event Viewer I looked in Event Viewer to find out what MSI-file that generated the error message and found:
Log Name: Application
Source: MsiInstaller
Date: 23.09.2010 21:58:26
Event ID: 1040
Description:
Beginning a Windows Installer transaction: C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}\SkypeToolbars.msi. Client Process Id: 6564.
2. Running MSIEXEC with logging options I started a "Command Promt" and used the command: "cd C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}" to navigate into the folder containing the MSI-file.
Now using the command: "msiexec /i SkypeToolbars.msi /lv log.txt" (msiexec options: /i = Install, /lv = Log + Verbose output).
After clicking away the error message I just wrote "log.txt" in my "Command Promt" to open the log-file. Near the bottom of the log-file I found this line:
DEBUG: Error 2738: Could not access VBScript runtime for custom action
3. DEBUG: Error 2738 After a quick search at Google I found out this error indicates that the VBScript engine is not registered on the computer.
The solution for a Windows Vista or Windows 7 32bit:
- Click Start -> All Programs -> Accessories
- Right click "Command Promt" and click on "Run as administrator"
- Write "cd %windir%\system32" and hit Enter
- Write "regsvr32.exe vbscript.dll" and hit Enter
- You should now get a message that says: "DllRegisterServer in vbscript.dll succeeded."
- Click "OK"
The solution for a Windows Vista or Windows 7 64bit:
- Write "cd %windir%\syswow64" and hit Enter
- Click "OK"
4. Try again... Now I tried once more to run "msiexec /i SkypeToolbars.msi /lv log.txt" (I kept the /lv log.txt option to look for changes if the installer would fail again).
If you still get the same Error than continue to step 5.
5. Cleanup registry first, then re-reg My installation still gave me the same error, so after some more searching and reading on Google I found a solution that explained what I tried before (with the regsvr32.exe) and also an alternative step if that one should fail. The alternative step was to remove the Registry Key pointing to vbscript.dll.
The alternative solution for a Windows Vista or Windows 7 32bit is then:
- Write "reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Click "OK"
The alternative solution for a Windows Vista or Windows 7 64bit:
- Write "reg delete "HKCU\SOFTWARE\Classes\Wow6432Node\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Write "cd %windir%\ syswow64" and hit Enter
- Click "OK"
Now using the command "msiexec /i SkypeToolbars.msi /lv log.txt" the installer started perfectly, ran all the way thru and Finished.
Conclusion This message indicates that VBScript engine is not currently registered on the Computer running the installer.
Vbscript.dll must get registered to solve the problem.
Ref: http://community.spiceworks.com/how_to/show/1577
Apr 25, 2011 | Computers & Internet
Tip
HP printer UNINSTALL using CD
<p><span><b>Resolution:</b></span><br /> <ol> <li> <span>Run the uninstaller from the SETUP.EXE driver</span> <li> <span>Delete printer from Printers folder</span></li></ol> <p><span><b>Removing printer using the SETUP.EXE driver:</b></span><br /> <ol> <li> <span>Run the uninstaller from either the printer CD-ROM, diskettes, or the downloaded Setup.exe printer driver.</span> <li> <span>Go to Start, then Run and in the Open line type X:\Setup.exe, (where X is the CD-ROM drive or the floppy drive or the Directory on the hard drive where the downloaded driver as copied to.</span> <li> <span>Follow the on screen instructions.</span></li></ol> <p><span><b>Deleteing Printer:</b></span><br /> <ol> <li> <span>Run the uninstaller from either the printer CD-ROM, diskettes, or the downloaded Setup.exe printer driver.</span> <li> <span>Go to Start, then Run and in the Open line type X:\Setup.exe, (where X is the CD-ROM drive or the floppy drive or the Directory on the hard drive where the downloaded driver was copied to.</span> <li> <span>Follow the on screen instructions.</span></li></ol> <br />
on Mar 10, 2011 | Office Equipment & Supplies
When i install scan cm1312 on my PC ruuning win 7 i get an Error saying Extanal Error
Are you installing the driver from the CD?
Try downloadingg the driver from their site.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3558902&prodNameId=3562006&swEnvOID=2100&swLang=8&mode=2&taskId=135&swItem=ma-61238-3
1. Download the file: 1312series_full_solution_v5.0_AM-EMEA.exe (306 MB)
2 Use the full download from the website and it self extracts to your root directory.To run the self extracting file, first set the compatibility mode to Vista sp2 and run as admin.
3) The files remain and you can find them here:
C:\HP_CM1312_series_full_solution_v5.0_AM-EMEA\
4) Set the compatibility mode to Vista sp2 and run as admin on the Setup.exe.
5) Run the full install. Works for both usb or network.
Regards,
Mar 18, 2011 | Computers & Internet
Able to download the exe file obtained online onto
Have you tried to restart your computer?
Is the error only appears to this software?
Did the file came from HP's official site?
That file might be corrupted
try to download the file again
Feb 26, 2010 | HP Photosmart 7850 InkJet Printer
What is system error 5 ?
The following reasons may cause to the error message:
1. Time Synchronization problem.
2. Missing permission to access the remote computer (Share, NTFS, GPO).
3. Firewall and/or third party product may eliminate connection to the remote computer.
4. The computer account isn't disable (Or have expired computer account password)
or doesn’t exiting in the domain.
5. Active Directory replication problem may occur.
  1. Verity correct time zone and clock synchronization:
Windows Time Service Technical Reference
http://technet2.microsoft.com/WindowsServer/f/?en/Library/a0fcd250-e5f7-41b3-b0e8-240f8236e2101033.mspx
2. Verity correct permissions on the remote host.
Tip: A useful that can be used is: (GPResult.exe) Command Line Tool
How to Use the Group Policy Results (GPResult.exe) Command Line Tool
http://www.microsoft.com/windowsxp/using/setup/expert/gpresults.mspx
3. Open the required ports on the remote computer.
4. Verity that the computer account is active and the computer connect to the domain.
Tip: A useful that can be used is: Netdom.exe Command Line Tool
Netdom.exe
http://technet2.microsoft.com/WindowsServer/en/Library/460e3705-9e5d-4f9b-a139-44341090cfd41033.mspx?mfr=true
5. Verity correct replication in the Active Directory Replication.
Troubleshooting File Replication Service
http://www.microsoft.com/technet/prodtechnol/windows2000serv/technologies/activedirectory/maintain/opsguide/part1/adogd11.mspx
Feb 26, 2010 | Microsoft Windows XP Home Edition
I just purchased my 2nd Asus My Pal A626 Pocket PC. And I cannot run the setup program on any of my 5 computers. It tells me I need Flash 8.x or higher and I have Flash 10.x or it says I may have a...
Go to a command prompt (CMD) by navigatinf to START->RUN and typing CMD In the command prompt, type Type c:\Program Files\Common Files\InstallShield\Driver\8\Intel 32\IDriver.exe -Embedding Then run your setup.exe or install.exe of the prog you are trying to install...
If this doesnt run, think there must virus infection in all your system...
Does any other setup files runs in your system?
Please leave these details as comment and we will provide further assistance
Rnj VINODKUMAR
Nov 03, 2009 | ASUS MyPal A626
Canon i250 printer will not work with window vista os
The Vista add-on module driver (whatever THAT means!) can be found here. Have you tried downloading this Vista driver already?
Hope this helps :)
Scott
Oct 06, 2008 | Canon Office Equipment & Supplies
Camera wont download the photos.
http://digiblue.com/customer-service/downloads/drivers/SQ905C_DSC_Drive_XP_Vista_DigitalBlue_V2.005_2007MAY24.exe
if you are using windows vista use the following above link to download the new driver.
1) Please install the Disney Pix 2 software and the Disney Pix Micro Downloader to your computer via the software CD that came with the Disney Pix Micro
2) Please double-click on the "Setup" to begin the install of the Pix Micro drivers. The User Account Control will appear warning you that a program is trying to run. Please click "Allow".
3) Complete the install of the driver by following the prompts.
4) After the install completes, you are prompted to restart the computer. Please select "Restart now" and then click "Finish".
5) You can now delete the Setup program from your computer
6) Connect your Disney Pix Micro to the computer and wait for the device to install.
7) Double-Click on the Downloader shortcut to open the downloader
Now the Pix Micro Downloader is open with the correct privileges and the Pix Micro camera is connected. If you click the "Download" button. A dialog box appears saying "Pixel Up".
Please click the "OK" button and the download will complete successfully. The images can even be deleted via the downloader after the images are downloaded. Although, every time you open the downloader, you must run it as an administrator and every time you download, the "Pixel Up" box will appear.
If you are having a problem installing a product that uses InstallShield as their installation tool, and the steps below do not resolve your issue, you will need to contact the vendor of the software, as we cannot provide further support. Your vendor, who used InstallShield as an installation tool, created the product that you are trying to install. It is very likely that the error you are getting is related to how the vendor used our product and only the vendor would know which InstallShield product they used, which version and how they programmed it. Thank you for your understanding and patience.
This article applies to the following errors when trying to install an application that uses InstallShield:
Error extracting support files
Error installing Ikernel.exe (0x any number)
Access is denied
Error loading Type Library/DLL
Discussion
Detect Version
Different troubleshooting steps are necessary for different version of InstallShield. To check the version of InstallShield Professional that was used to create the setup, take the following steps:
1.Right-click on the setup.exe
2.Select "Properties".
3.In the Properties dialog, select the tab labeled "Version".
4.Near the top there will be a filed labeled "File Version". The number specified here will tell you approximately what version of InstallShield was used to create this install.
InstallShield 5.x and 3.x
If the version of InstallShield is less than 6.00, see article Q100198, HOWTO: Eliminating General Setup Initialization Errors.
InstallShield 6.x
If the version is 6.00 or greater, continue with the following steps.
Setup initialization errors can be caused by a number of factors. This is a non-exhaustive list of possible resolutions:
1.Insufficient permissions on the machine. If you are using a Windows NT or a Windows 2000 machine, you need to have administrative permissions to run an InstallShield Professional 6.x setup. Make sure you have the correct permissions.
2.If you just ran an InstallShield setup, the engine takes a few seconds at the end of the installation to clean up. During this time Ikernel.exe (the engine file) is running in memory from a previous process. That is why you are not allowed to launch another setup. Waiting a few seconds and running the setup again should resolve this.
3.Check and make sure Ikernel.exe is not in memory. If it is, and no setup is running at the time, end that task and restart the system.
4.Clean out the Temp directory.
5.Delete the Program Files\Common Files\InstallShield\Engine folder and then rerun the setup.
6.Reinstalling Internet Explorer (IE) 5.x can also repair a number of corrupted/missing core Windows files from your machine, so reinstalling IE 5.x and the NT service pack is also suggested.
7.Another possibility is that you do not have sufficient COM permissions. For information on how to troubleshoot this, see article Q104986, INFO: Initialization Error Troubleshooting.
8.The other potential cause is a missing Stdole.tlb file. This is a core Windows file and should exist on your machine. Make sure that if you get this file from another machine, the machine is running the same operation system as the machine you are trying to run the setup on.
9.If you are trying to install to a Windows 98 machine, download and run Dcom98.exe from the following site: http://www.microsoft.com/com/dcom/dcom98/download.asp.
10.Make sure that you are using the latest version of the InstallShield engine. To install the latest engine see article Q105097, INFO: Install the Latest Version of Ikernel.exe
Aug 01, 2008 | Disney Pix Micro Digital Camera
CANT INSTALL DRIVER
since you have not given any model no for your ibm web cam, Its very difficult for anyone to tell which drivers to download
visit this link to scan for your web cam drivers:
http://www.softwaredriverdownload.com/ibm_33l4889_pc_camera_windows_2000xp_driver.html
installation:
  • Make sure the IBM PC/Net Camera is unplugged from the computer before installing this software.
  • Click [YES] to continue, the exe will then extract setup files to c:\\setup folder.
  • Go to C:\\setup folder, you will find Setup.exe there, double-click to run it.
low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not
dilipbagdi
Apr 09, 2008 | IBM 22P5086 Webcam
Erro message
hi it is some problem .exe file. you setup regd recovery
download it download.com
or setup c drive xp boot cd to recovery .exe file.
go to run command type sfc then enter. setup
Feb 17, 2008 | Microsoft Windows XP Professional With...
Lexmark X4580 InkJet Printer Logo
2,280 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
