Question about Frigidaire GLTF2940ES Front Load Washer
Washer will not go into spin mode cleaned out rubber boot and drain hose no alarm code comes up
    Brigadier General:
  • 3,513 Answers
Please check the bellow links for the no spin problem in your washer:-
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help#itdoesntspin
http://www.applianceaid.com/direct-nospin.html
Test for a capacitor with ohm meter, follow the bellow link:-
http://www.applianceaid.com/micro4.html
Please get back to us if you have any further query or else accept the solution.
Thanks for contacting fixya.com
Posted on Oct 24, 2010
6ya staff
SOURCE:
Run diagnostic test gltf2940es0
if the drain pump is bad or clogged and can't drain the water it won't spin until water is drained.pump number 137221600,it's around 110 dollars,but first get a shop vac,pull out the drain hose from the washer and connect the shop vac to the hose and vac out all the water,you first have to remove the bottom front panel to get at the pump,remove the hoses going to the pump and have the vac ready to clean up any water that still might be in there,then check the pump and see if anything is in there,i've found coins that get into the pump or other debries and clean it out of the pump,then check the rubber boot on the hose,make sure nothing is in there and check the other hose,you can set the shop vac on blow and blow through the drain hose to make sure that's clear,remove any junk you find in any of the hoses and pump,reconnect the pump and hoses,put some water in then set it to drain and spin or rinse and spin,if the water drains and then it spins you're all set if not the pump could be bad,one more thing if the drum doesn't move you could just have a bad door switch,this is the easiest part to fix and i always have a door switch for frigidaire washer,remove the spring the holds the boot seal on.remove the rubber boot on the door switch side,take out the screws that hold the door switch in,and replace it,run it,if the drum starts to move then drain and spin it was the door switch,any error codes come up? good luck,have any questions let me know and hopefully i can help you
May 19, 2014 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity ATF6000FS1 model I recently
E20 means clogged drain pump, slow drain . What you need to do is to remove the screws on the back that holds down the top panel and slide it back to remove then the 5 screws on the Ctr panel and pull that off and then remove the spring around the door seal on the front panel and remove the 4 screws on the bottom of the front panel and then the 2 screws for the Door catch on the front and then the 3 or 4 screws on the top part of the front panel to removed the front panel then underneath you will see a black rubber flexible hose coming off the tub loosen the ring clamp at the top of the hose with a Phillip screwdriver and reach in the hose and grab the filter on clean it out and reinstall and put everything back together and you should be all set
Jan 16, 2011 | Frigidaire Affinity ATF6000F Front Load...
F21 clogged hose water left in the washer after spin cycle is done how do I get the hose off the washer and then how do i check if the clog is on the in side
Yoy will need to take off the bottom cover (3 star screws), locate the drain pump at front (the drain hose goes to it). It has a strainer in it which you turn counterclockwise to remove this will allow you to clean it out. Then one of the three tumbling blades inside can be removed to clean out the boot to the drain pump. Good luck!
Jul 05, 2010 | Kenmore HE2 Plus Front Load Washer
ATF6000ES front load washer won't spin during regular cycle.
clogged filter will cause this error code. I have the same washer and the filter located inside the rubber boot attached to the pump was full of junk. there was enough room for water to get thru but not enough for full volume. clean it out and it should work. note : its a pain to get the boot back on so be ready and take it slow. this worked for me.
Aug 27, 2009 | Frigidaire ATF6000ES Front Load Washer
What is a ld error code? It will not spin when it is supposed to spin fast. This is the error code that comes up.
LD is the error when it takes longer than 5 minutes to drain the water out and reset the sensor. Press pause/cancel twice to clear. The washer will begin a slow spin, and when the motor allows, increase the spin speed towards the spin speed selected. Depending on the model, it will make several attempts, each time pulling water off of the load at the slower speed. If it cannot "get permission" to increase to it's selected speed within the allotted tome, it ends the cycle and the error code "LD" is displayed. Usually two common things can contribute to the DL alarm. One is the strainer, and the other is the drain line. The strainer is in line between the drum and the pump. On a front loader, it is behind the kick panel below the front main panel. It is connected to the drum with a rubber hose and strains the water going to the pump. Clean the strainer, and, while it is open, look inti the pump cavity. Remove any debris that you find there. Reassemble the strainer.
Anything that gets by the strainer and pump will eventually pass through the drain line and on out through the house drain. Empty the drain hose into a bucket to help displace any sediment and debris in the line. If possible, run an empty cycle with the drain hose pointed outside.
Best regards, --W/D--
Aug 13, 2009 | Kenmore Washing Machines
My cltf2940es0 fridgidare front loading washer will not start a cycle. The door will lock and the timer will set, however when the cycle should start the motor makes a subtle humming noise. This will...
unplug washer. take off bottom front panel remove rubber boot hose from bottom of tub to pump .have towel or cake pan ready for water.clean out boot and stick finger in pump clean out also remove drain hose at pump check for coin reinstall hoses this fixes must problems with front loaders
Nov 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washer won't spin
Did you check that the door lock switch is working?
See this thread:
http://www.applianceblog.com/mainforums/showthread.php?t=3124
If it's not the door-lock switch, you need a new speed control board.
Oct 26, 2008 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
Whirlpool Duet Washing Machine 9150P
f02=slow drain First if you have a wet vac pull the drain hose out of the drain spout and use the vac to pull the water out of the washer through the drain hose.If not you will need a pair of radiator hose clamps from the auto parts store. Pull the screws from the lower panel at the front of the washer and remove it.in side you will see a rubber hose coming down from the tub to the drain pump. Put the radiator hose clamp there if you didn't have a shop vac.On the front of the pump is a round part with a handle turn that and remove the pump filter .Clean any foreign objects out of the pump and look inside the pump to make sure no impeller blades are broken if any are you will have to replace the pump. put the filter back in and tighten it. If you had to use the hose clamp remove it now.reassemble and don't forget to give the tech his four boxes if this fixes it
Jun 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite Washing Machine leaking water
Okay...my experience with this model front loader leads to the following possible problems:
CAUTION: UNPLUG the washer if you plan to service the interior. It is dangerous to have your hands inside the unit with moving parts and energized. Plug the washer back in and stand back if you plan on doing any operation checks.
1. Door bellow ripped or torn (this is the gray rubber boot around the door - open the door and inspect along the entire door boot. Including the areas behind the rubber fold where the rubber meets the wash tub. It is common for them wear out and tear. NOTE: Make sure the fill hose on the left-hand side of the door boot is fully snug in place. Sometimes it will come loose and leak BEHIND the door boot.
2. Drain pump or hoses leaking - You will need to remove the lower panel under the door to see inside the washer. Remove the three torx type screws under the front lip at the bottom of the panel. For easier access, place a small block of wood under each front foot. The washer is heavy so you may need assistance to lift the front slightly. CAUTION: Do not lift on the door, push on the door panel or control panel. If the panel sticks, slightly tap on the sides and it will drop down and come off. The pump is located in the front under the wash tub. Make sure the clean out trap is snug and all your hoses are tight and not torn. Check the drain hose that leads out of the back of the washer from the drain pump to ensure it is not cracked.
3. Air Dome hose has come loose from the tub - This will be a small rubber hose connected to a plastic piece (called an air dome) on the right-hand side of the wash tub as you are looking in from where you removed the bottom panel. It should be located behind the drain pump and mounted physically to the wash tub. The other end of this hose runs to the pressure switch, which turns the water flow off when the washer tub fills to the approriate level. If this hose comes off, the washer will start to leak on the FILL cycle and will not shut off. I don't think this is what you are talking about, but it is still worth a look since you have the panel opened.
4. Tub seal leaking or tub cracked - These would be the most undesirable of all possible problems because it would require the removal of the entire wash tub in order to correct. Inspect the wash tub seam and make sure there's no water coming from around the tub.
I hope this gives you a few possible items to work with. Inpsect the washer interior when you get the panel off and post back if you can determine where the leak is coming from.
HELPFUL HINT: Put the washer into diagnostics mode if you plan to leak test. At the control panel select DRAIN/SPIN, NO SPIN and press any key under OPTIONS 4 times (it must be the SAME key, however). "C00" will be displayed on the operator console, and you will hear the door latch engage. The washer will run through a series of tests by filling using hot and cold water, checks all your dispenser features, tumbles the drum, spins and drains. This diagnostics can be stopped at any time by pressing the PAUSE/CANCEL button twice. The drain pump will come on and drain the washer.
I hope this helps you...
Feb 20, 2008 | Kenmore Elite 45986 Front Load Washer
F02 code - won't spin
You you probably need a pump, but try this first.  Remove the pump filter again and put you finger into the hole going to the pump and see if there is anything in it and see if you can turn the pump impeller. If this checks ok, Put filter back in and put washer into drain/spin. It should spin since you have drained the tub. If so replace the pump.
If it still doesn't spin remove the top of the washer and find the pressure switch. It will have a rubber hose going from it down to the bottom rear of the tub. Remove the hose from the switch and make sure you can blow through it. Hook hose back to switch and try drain/spin again. If washer does not spin now, you will need to do some trouble shooting with a volt/ohm meter or have a tech come out.
Post back to let me know what you find out.
Oct 12, 2007 | Kenmore Elite 45986 Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
