Question about Garden
How do I replace drive belt on my Greenfield ride on mower
6ya staff
SOURCE:
John McKinney
  • 42 Answers
SOURCE: how to replace drive belt
here is a diagram that will hopefully help you. let me know if it helps, or if you need further assistance. thanks.
convert?ilfn=d%3a%5cempartweb_52%5ccatalog%20data%5cemp_img%5chus%5cimages%5c33%5c28%5c0009.tif&ilsc=16&iliv=0&ilbr=0&ilif=g&ilre=8
Posted on Mar 15, 2009
SOURCE: BOLEN RIDING LAWN MOWER 13AN683G163 TRANSMATIC
Either the belt routing is incorrect or there is a tensioner which needs adjusting. Recheck your belt installation. Oh, it could be the wrong belt, too.
Posted on May 01, 2009
wilson59
  • 496 Answers
SOURCE: How do you replace a belt to a riding lawn mower?
You will need to get some information from your mower. Click on this link to get started:
http://www.outdoordistributors.com/MTD/MTDpartslists.html
Posted on Aug 25, 2009
mickey813
mickey813
  • 472 Answers
SOURCE: need to find out whitch way the drive belts go on
CAN YOU SEND ME THE MODEL AND SER# AND ILL SEND YOU A COPY
Posted on Oct 08, 2009
Roger Geer
  • 78 Answers
SOURCE: blade belt diagram for John Deere LX178 Riding
Remember the belt rule, V of the belt goes in V pulleys.Flat pulleys that are stationary or move get the back of the belt. You can figure it out. Its not rocket science. Remember at some point there has to be a tensioner,usually gets the back of the belt if its a flat pulley. U may have to remove the spring and then reattach the spring after the belt is routed.
Posted on Oct 29, 2009
I want to change the drive belt on my ride on mower the Brand is greenfield ride on mower
If you have not got a manual you can go to website to get a full blown spare parts manual with prices try that
Feb 03, 2018 | Garden
Greenfield Ride on Mower need to increase tension on drive belts
As a rule there is 2 ways.
1 is a spring loaded idler pulley and the other is to loosen the motor and pull it back.
Depends on the age.
May 14, 2017 | Garden
My Greenfield 12-30 mower constantly drops the Drive Belt. How do I correct this?
First make sure that you have the correct size belt.
Then make sure the belt you are using is not stretched or worn out. Check all pulleys and make sure they are not worn and that they are in alignment. Finally make sure that all the idler springs are in place. It is wither an alignment issue or a belt tension issue
Feb 02, 2015 | Garden
Have greenfield fast cut 34 mower replace drive belt but have problem going forward up hills clutch is worn half mm could clutch be glazed
Are you sure your new belt is the proper length A quarter inch too long could make it slip. Something to try is spray your belt with belt dressing and see if that helps That will help stop it from slipping.I had to do that with one of mine when my belt was not the right size. I shot spray about once a week one summer.
Dec 07, 2014 | Garden
Greenfield mower chain tension
take chain off -- lay on floor --pull taught end to end push together --if it flexes more that one quarter of a inch --chain is worn --replace chain--also see how deep chain sits on sproket--- if sits too deep sprokets are wore and need replacing
Dec 27, 2013 | Garden
I need a diagrahm of a belt drive greenfield ride on mower
Go to this website, upper right hand corner and do a parts look up. Search for your model and that good stuff they ask of you and then choose mower housing should be there, browse the site it's really cool and has a lot of info.
http://www.jackssmallengines.com
I did a sample search for generic riding mower deck and found great diagram of belt routing. Give it a try you will find same results Good Luck! Don't forget the thumbs!
Nov 10, 2010 | Garden
Have a Greenfield Evolution 2000 mower , the forward drive clutch is slipping badly on hills is ok on the flat, what is required to fix this problem. Can the clutch pads be replaced or are complete clutch...
The Greenfield clutch (drive belt) is adjusted by spring pressure pulling a long rod that has serations on it. Either the belt has run out of adjustment (= new belt needed) or the adjuster has stuck. Lift up the seat and push the adjusting rod that has a big spring attached to see if you can move it towards the front. Look at the pulley beside the rod, if the belt has stretched too far, the pulley will be hard up against its slot. The pulley moves towards the front to tighten the belt. I just push with my leg to get another "click" out of the adjusting rod. New belts are cheap too.
Oct 31, 2010 | Garden
We mow 2 acres with a Greenfield ride-on. Sometimes have to cut long grass by slipping the clutch to get slow forward speed. Problem is that the clutch system occasionally locks into forward or (worse...
Hi i have seen this with most greenfield models The only way to fix this problem is to replace the drive clutch assy as it ends up to costly to replace the worn parts : shaft,clutch plates & drive pulleys.
In most cases replacing these parts has led to a new assy six months later.
Mark.
Jul 18, 2009 | Garden
Garden Logo
319 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
