Question about Canon PIXMA MP160 All-In-One InkJet Printer
How to install Canon MP 160 ink cartridges?? - Canon PIXMA MP160 All-In-One InkJet Printer
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 544 Answers
Turn on the printer and open the scanning unit. The cartridge holder unit will move to the left.There is marking on the printer housing B and C. B is black and C is color. B is the left side holder and C is the right side holder.The cartridges are inserted on a slight tilt. Angle the cartridge with the cartridge resting on its buttom, Push the cartridge in until it touch the front of the holder, then up until it click in place.You have to tilt the cartridge in order for it to snap in.
Posted on Dec 14, 2010
  • Canon Master
  • 7,733 Answers
6ya staff
SOURCE:
MUKHTAR
mukhtar21 shaikh
  • 2022 Answers
SOURCE: GETTING ERROR CODE E27, INK ABSORBER FULL
to reset kindly folow this steps,
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on Mar 22, 2010
old marine
old marine
  • 2256 Answers
SOURCE: giving the error e 2,3
Go to this link. Type "error e 2 3" in the search window and click the Search button. Try the troubleshooting steps provided. If the error still persists, you may need to have the machine serviced.
Posted on Apr 30, 2008
Anonymous
SOURCE: resetting my ink levels
This is not a solution, but i must comment strogly to the guest that submited the solution of holding the stop button...because IT WORKS(even though it doesnt reset the counter, it atleast allows you to continue printing)!!! and no, i am not the same user as the above...i am just someone who gave the solution a try and it definatly does work! so to that user...thank you very much!!!
Posted on Jan 14, 2008
Anonymous
SOURCE: How to reset the ink level monitor on Canon Prixma MP 160
Desconectar del toma corriente el impresor
Mantener presionado el botton de power mientras se conecta al toma corriente
Manteniendo presionado el mismo boton de power presionar dos veces el boton de reset (circulo con triangulo rojos)
Soltar el boton de power
La impresora se tardara unos 10 segundos en mostrar el vaor numeroco de cero.
Presionar + para que el valor se mueva de 0 a 1.
Cuando el valor este en 1, presionar el boton que esta a la par de reset, de esta manera se encenderan dos luces
una es la de plain papaer y la otra de photo paper, en este momento se coloca papel en la impresora
Se presiona el boton de power una o dos veces (da igual), la impresora imprimira una hoja de prueba
Al imprimir esta hoja el valor en la pantalla regresa al valor de cero, dejarlo asi
Abrir el scan cover (para sacar los cartuchos pero no se sacan), con la tapa abierta desconectar fe la energia al impresor
Sacar los cartuchos, cerrar la tapa y encender el impresor.
Volver a colocar los cartuchos ya refilados en la impresora y LISTO.
Posted on Jun 16, 2008
Anonymous
SOURCE: reset my printer canon pixma mp 160
reset-mp160
Posted on Oct 28, 2008
Error 5B00
Canon PIXMA MP180 All-In-One InkJet Printer
Error 5B00
Jul 04, 2012 | Canon PIXMA MP180 All-In-One InkJet...
How to make Canon pixma MP-220 to recognise refilled ink.
Read the manual.
Get online and got to www.google.com In the google search box type: "Canon Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for manuals on the site.
An Error Message Is Displayed on the LCD (MP220 series)
Message
Action
CHECK INK
U051/U052/U053/U059
The FINE Cartridge may not be installed properly, or the Cartridge may not be compatible with this machine. Open the Scanning Unit (Printer Cover) and install the appropriate FINE Cartridge.
If the error is not resolved, the FINE Cartridge may be damaged. Contact your Canon Service representative.
Jun 02, 2012 | Office Equipment & Supplies
My printer won't print? it has full ink cartridges.How do i fix it?
Maybe your cartridges are not out of ink. Try it with another game cartridge kit...
Apr 30, 2012 | Canon PIXMA MP780 All-In-One InkJet...
Cant get myy new ink cartridges installed
Are you sure you have the correct replacement cartridge???
Apr 16, 2012 | Canon Pg-40 Black Ink Cartridge Pixma Mp...
Error code 16
Hi there .the error e1.6 on Canon Multifuntionals ( MP, MG , MX ) is :
DESCRIPTION:
Ink has run out.
SOLUTION:
Replace the ink cartridge and close the Scanning Unit (Printer Cover).
If printing is in progress and you want to continue printing, press the Stop/Reset button for at least 5 seconds with the ink cartridge installed.
Then printing can continue under the ink out condition.
The function for detecting the remaining ink level will be disabled.
Replace the empty ink cartridge immediately after the printing.
The resulting print quality is not satisfactory, if printing is continued under the ink out condition.
I hope this information will help you
Dec 22, 2011 | Canon Office Equipment & Supplies
Is MP210 and MP240 the same? can i use the same cartridge?
no both are different
Here are the list of cartridges u can use
MP210
PG-30 Pigment Black
PG-30 Pigment Black Ink Cartridge
PG-40 BLACK
CL-31 Color FINE Ink Cartridge
CL-41 Color
MP240
PG-210 Black Cartridge
CL-211XL Color Cartridge
CL-211 Color Cartridge
PG-210 XL Black Cartridge
Nov 28, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
MP 160 Canon printer, error code E5. I just want to use this machine as a scanner. Do I still need to load the cartirages?
Yes, the unit will not operate without the cartridges.
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 29, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Mp 160 don't work
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
Jan 15, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
239 people viewed this question
Clive
Clive
old marine
old marine
Ekse
