Question about Bosch Nexxt 500 Dryer
Turn on the dryer and it clicks but the drum does not turn.
  • Bosch Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Oct 28, 2010
SOURCE:
Why will my dryer not start, but makes a clicking sound?
If the motor runs and the drum doesn't turn the belt may be worn or broken...or you may have a faulty idler
Regards,
Dennis
Aug 15, 2014 | GE Dryers
Dryer makes clicking noise but won t start
The heating element is working or the belt is slipping.
the drum does NOT turn?
See manual. un plug and pop the front off to see if the belt is attached.. Try to rotate the drum by hand.
Aug 26, 2013 | LG Dryers
My dryer will heat but won't turn, I replaced the Dryer motor but it still doesn't turn. The door switch works fine, when I push the start button it clicks like normal and when I open the door I...
Have you looked for a belt on the drum of the dryer? Mine has a motor but it is attached to a wheel that turns large belt that extends around the drum.
Oct 03, 2017 | Roper Dryers
When i try to start my dryer it clicks to turn on but doesnt fire the drum
Reach in and turn the drum by hand if you can do so with very little resistance then the belt may be broken or off the motor.
Oct 15, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Maytag Performa PYE G2200 gas dryer, the dryer seems to turn on but the drum will not turn.
Based on the information provided, it sounds like a broken drum belt is at fault. Below is an illustration of the drum belt.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-PYG2200+-%3d%3di529597&PartID=529597
Here is a parts/disassembly diagram:
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
Here is a belt installation diagram:
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
All links courtesy of www.repairclinic.com
Aug 16, 2009 | Maytag Dryers
GE Profile Harmony Dryer Drum will not turn
the inertia switch on the shaft of the drum motor has failed This will require removal of the drum motor
Jun 01, 2009 | GE Profile Harmony DPGT750EC Electric...
Duet dryer drum does not turn.control panel turns on.
it appears the drum has come loose on my maytag dryer model #LDE313 but figure out how to get inside to checkout the drum
Feb 05, 2009 | Whirlpool GEW9250 Electric Dryer
Open Questions:
See all Bosch Nexxt 500 Dryer Questions
Bosch Nexxt 500 Dryer Logo
91 people viewed this question
Top Bosch Dryers Experts
Elie Balas
Tommmix
Level 1 Expert
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
