Question about Linksys WRT160N Wireless Router
My wrt160n is not responding. The 1,2,3,4 lights stay lite and so does the globe/Internet light. I've held reset for 30seconds and have no response. The computer can not access the router
    New Friend:
  • 105 Answers
That's error is happening because of an IP conflict between your ADSL modem and your wireless router; both of them want to be 192.168.1.1
Remove the internet cable and reboot the router, then follow the steps bellow:
1) Use a web browser and go to page http://192.168.1.1. 2) In the login screen write the following so you can access the configuration screen.
admin: admin password: admin
3) There you must go the the LAN configuration and find your router IP address (192.168.1.1). 4) Write 192.168.2.1 instead of 192.168.1.1 5) Save and logout. 6) Restart your wireless router and wait some minutes.
Now the new IP address of your router is 192.168.2.1
7) Connect the internet cable again.
Now it should be fixed, if it does't work you'll need to use a web browser and enter 192.168.2.1 and do any further configuration.
Write me a comment if you need further assistance.
Regards,
Posted on Oct 24, 2010
  • falyniii Oct 24, 2010
    I'm unable to connect to the router even when typinghttp://192.168.1.1. 2) I think it might be bricked. I can't even get the lights to flash after holding reset for 30 seconds any other suggestions. Is there another way to reset?
  • Linksys Master
  • 7,733 Answers
SOURCE:
Why Lamp and temp lights come on after power up and stay on
You need to replace the lamp and then go into the settings menu and reset the lamp hours counter to zero.
Aug 16, 2014 | ViewSonic PJD6531W Projector
Cisco WRT160N, all 4 ethernet lights on, so as the internet light ( no blinking ) ... power light and wireless light are totaly off. No connection at all. Tried reset, but nothing changed. The temperature...
Does holding the reset button in do anything? If not, might be that the router is simply fried and time to get a new one. If it does react to resetting try just connecting one device to it to see if you can get to the web interface and configure.
Oct 25, 2013 | Cisco Linksys WRT160N ULTRA RANGEPLUS...
If my interior lights are dim is it a fuse problem
No, that's the quick response. If you had a blown fuse you would have no light at all. Have you recently replaced a faulty globe in the interior light? if so, then the likelyhood is that you've put a lower power rated globe in than the original. An auto-electrician will know the correct globe to fit.The other thing an Auto electrician can check is to see if you have an earth fault in the wiring of the fitting.
Oct 09, 2012 | 2001 Hyundai Sonata
I changed the battery in my remote now my car will not respond
Reprogram the remote: press and hold the f button for approximately 8 seconds. the remote will flash three times. press the remote start button on the remote. the remote is now ready to pair. enter vehicle, turn ignition on, press and release button and antenna, immediately press and hold same button, the vehicle should respond with a horn honk and/ or light flash on antenna. While holding button on antenna, pres lock button on remote...vehicle should respond with a confirmation horn honk and/or light flash. Release button on antenna, turn vehicle off. Test system.
Jul 12, 2012 | 5101 LE 1 Way Car Remote Starter System
The brake light on my dash stays on even when the emergency brake is off. THe interior light sometimes goes on when the door is opened, sometimes doesn't and the ignition light doesn't always come on
The handbrake warning light is activated by a switch on the handbrake bracket under the console. This is most likely stuck or broken.
The interior light staying off when the door opens is common. It could be that a door plunger switch is sticking (they can corrode inside), or there is poor contact at each end of the dome light globe. Take out the globe and press the contacts closer (just a bit) then push the globe back in, checking that it is firmly held. Then spray a little WD40 or similar on the plunger of each door switch and press it in a few times against the spring.
Which ignition light is not working, one of the warning lights? Or the check engine light?
Dec 25, 2011 | 1995 Toyota Camry
Lost password reset router to factory defualt cant find defualt password on linksys wrt160n
Please leave the user name box blank and type in admin for the password. I hope this helps and thank you.
Jan 23, 2011 | Linksys WRT160N Wireless Router
Our wireless devices, IPOD and laptops, will not connect to the internet. It is not even showing Linksys available to us. The wireless router is hooked up. The #1 light (ethernet) keeps blinking on the...
If by "reset", you mean you have done a factory defaults reset by pressing and holding the RESET button down for 15 to 20 seconds, then it sounds like your router has failed.
If you haven't held down the RESET button on the back for 15 to 20 seconds, then try that. If that doesn't return the router to working order, then the device is defective.
You should be able to get a warranty replacement.
Dec 30, 2010 | Linksys WRT120N Router
Need instructions for setting Globe outdoor timer photocell model one button on/off #16UL/PC-24222
Use the on/off button to cycle through in the following order:
F = off
0 = on
1-9 = Number of hours unit stays on after detecting 15 seconds of low light
R = Random. After detecting low lux for 15 seconds, unit will select random number of hours to stay on. Will repeat randomization cycle in 24 hrs
d = On from dusk til dawn
1.-9. = (number followed by period) On now and will shut off after the indicated number of hours elapses.
Neat little timer. Have fun with it.
Nov 13, 2010 | Globe Electric Globe Indoor/Outdoor Lights...
Down light globe change
usually the light is changed by just rotating the inner part of the face. This should then drop down where you'll find the globe held in place by 2 metal pieces. Simply pull the globe out and put a new one in. Oh and it doesn't matter which way you connect the 2 wires to the globe either (turn off the light switch first).
Mar 19, 2009 | Electrical Supplies
Linksys WRT160N Wireless Router  Logo
1,410 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
