Question about Saeco Odea Go
Saeco Odea: The brew group is jammed possibly due to incorrect insertion? Cannot insert dregs draw and cannot remove the brew group.
I had the same problem. I got around it by inserting just the grounds container (which sits inside the dregs drawer) and powering the machine on. Then the machine reset itself to the home position. It wouldn't do this with the dregs drawer removed, but putting in just the grounds container fooled it into thinking the dregs drawer was inserted. Hope this helps. JRP
Posted on Jan 17, 2011
SOURCE:
Right red light is blinking all the time
Alarm LED:
• Permanently on (one or more causes): No coffee left, water tank is empty, empty the residual water
tray is full (in this case the dreg drawer also has to be emptied to prevent problems).
• Flashing slowly (one or more causes): Brewing unit is missing, dreg drawer has not been inserted,
coffee container cover has not been inserted, service door is open, rotary knob for opening the hot
water / steam is not in the right position.
• Flashing rapidly:Ventilate the water system
Nov 09, 2014 | Saeco Odea-Giro Espresso Machine
I removed the brew group and it is now stuck in the remove position. I cannot replace it in the machine. The lever that says push is stuck in the pushed position
On the inner side of the brew group (The side opposite the hand grip) there is a small rectangular slider mechanism with a vertical tab that sticks out and a catch near the funnel where the ground coffee is deposited. This slider must be in the correct position in order for the brew group to be inserted properly. If this slider is in the upper position, push gently on the catch so that the slider slides downward about 5mm or 3/16 inch. (I am replying from memory - it is possible that the slider must be in the upper position to engage). This will realign the funnel slightly and release the thumb lever, allowing the brew group to be inserted.
Jul 27, 2014 | Saeco Odea Go
The brew group is stuck and will not come out
I hope one of this two solutions solve your problem.
1- The brew group is out of place. Turn the machine on. Close the service door.
The brew group is automatically placed in the correct position.
2-Coffee grounds drawer is inserted. Remove the dregdrawer first, then the brew
group.
Jan 15, 2011 | Saeco Odea Giro Plus Coffee Maker
I have a Saeco Odea Go and my puck in the dreg drawer are really wet and I have water leaking (brown so with coffee) under the dreg drawer. how I can fix it ?
I recently had this problem. I throughly cleaned and lubricated the brew group as directed by the manual. Apparently if the brew group doesn't move smoothly enough it won't grind the correct amount of beans. Try lubricating and then brewing 2-3 cups to have the machine recalibrate the grind amount.
Jan 12, 2011 | Saeco Odea Go
Hi, I have a saeco odea giro plus that has just started to leak nearly all of the brewed coffee into the dreg drawer! Any ideas? thanks in advance...
I had a crack in the tube that connected to the brew group that resulted in a similar dumping of coffee in the dregs (and below the dreg drawer and onto the counter) in my Saeco Odea Giro. Replacing the "Saeco Odea Giro Coffee Dispensing Tube, part number 11003468, fixed my problem. You can replace this yourself if you are very handy. These photos are very helpful (The Go seems pretty similar to the Giro.) http://odeago.zxq.net/Odea_Go_Repair/Welcome.html
Aug 04, 2010 | Saeco Odea Giro Plus Coffee Maker
Saeco Incanto Deluxe brewunit jammed
Remove the dredge drawer. Open the door. On the left side of the brewing unit, and towards the back of the brew group, there is a single screw. Remove the screw. Grab the handle and pull carefully, but firmly with a quick ****. The brew group should come out. There is a piece that remains in the machine. Slide that piece down and to the right and it will come off. Insert the piece into the hole on the backside of the brew group with the clip up. Tighten the screw and move brew group back into position.
To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. (You can insert your key into the hole in the front and twist the key to return the brew unit to the center. Line up the 2 diamonds and it centered) If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit,(it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door and turn on the machine without having the brew group in, but you must have your drip tray and dredge drawer in. Turn the machine on. You will hear the motor turn on and when it stops completely, open the door and remove the tray, now insert the brew group and replace the tray.
Mar 04, 2010 | Saeco INCANTO DELUXE Espresso Machine
Cannot release the brew group for, saeco
Group is stuck in mid cycle due to some obstruction. You will need to have it serviced. Though it's possible to jiggle and pull it out. The machine will not likely reset itself, preventing you from re-inserting the group. Still requires a service to manually remove obstruction and reset it.
Feb 08, 2010 | Saeco Odea Go
How can i reset de saeco odea giro plus ? I can not place the central unit because the axes or spindle is not in the right position.
Turn off the machine. Open the side panel, remove the dreg tray, remove the dreg box and remove the brew group. reinsert the dreg box without the tray. Using a flat head screw driver insert lightly into the slot where the brew group sensor is until you hear a click. Hold the screw driver in place while closing the side door and turning it on. The head will re-align. Now open the side panel, remove the box and reassemble. Leave the machine off for an hour and turn back on. That should reset it.
Jan 10, 2010 | Saeco Odea Giro Plus Coffee Maker
Saeco odea go. the brew group is stuck, i cant get it out
Turn off the machine - open the service door and see if u can tilt out the tall dregs container and remove it and the drawer. You need to get it past the coffee par rejector flap on the left of the brew group. It sticks out half way into the left hand side space.
Close the door and put in only the tall dregs container. It has a metal bit on the back the releases a magnetic reed switch inside the machine.
Turn the machine on and you should hear the drive rotor moving. As you move the dregs container back and forth, the drive motor should turn. The idea to is fool the machine into getting the water inlet point in the back of the brew group to clear the boiler pin in the back of the machine so the brew group can be removed.
Jul 04, 2009 | Saeco Odea Go
Saeco Odea Go Logo
908 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
espressofixr
Level 1 Expert
Ray Murphy
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
