Question about Polaroid FCM-0700A 7 in. Portable Television
Our polaroid FCM 0700a TV's screen is blank. it was working one day & then when we turned it on again, the screen is black. there is a very faint image, but we can't really see it. sound still works
  • csimmons913 Oct 24, 2010
    thanks. I'll give it a whirl
  • 1,606 Answers
If the faint image is a normal tv image ie it moves changes like a normal display but is ghost like or faint then your problem will be either the back light (led or bulb or electroluminescent) or the back light inverter board. This is a very common problem with any LCD type display such as used on tv or laptops and smaller devices. The backlight works almost like a projector bulb and lights the actual display.
Both of these are be located to the sides of the display.The bulbs or leds are usually worth about $30 and the inverter board perhaps $40. If you don't do the repair yourself then you can add perhaps $75 or so in labour. So what you should do is talk to a few tv repair shops if there are any around you or even talk to a computer shop if you have to or the polaroid repair depot. What you want is a estimate. You may find that it will be cheaper to actually replace the unit than repair it.So you also need to check around to see what a replacement is worth.
This is a bit of a iffy call even on larger tv's if it is worth doing. On a small one if you have to pay for labour is usually isn't cost effective to fix. Ie it costs more than a new one. If you can get the repair parts cheap enough and do it yourself it can still be close on a small display unit. It's annoying as there isn;t really anything major wrong with the unit and I know of cases where one person took the actual display out of the case and put it into an old cabinet tv with a reading lamp behind it and it actually had a better brighter display. Another fellow just took the back of the case off so sun would shine through and he claimed it worked ok.
So as long as you keep an eye on the cost and let that be your guide you'll do ok on this.
Posted on Oct 24, 2010
SOURCE:
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Polaroid fdm-0700 with black screen display. DVD
go here and order the replacement inverter board. this will fix the backlight issue or no picture issue
http://lcdparts.net/LCDTVInverterdetail.aspx?InverterOriginal=UI8007S-1MSS
Aug 09, 2009 | Polaroid FDM-0700A 7 in. TV/DVD Combo
FDM-700A
go here and order this inverter board. this will fix the no picture or inverter backlight problem
Aug 07, 2009 | Polaroid FDM-0700A 7 in. TV/DVD Combo
Unit is completely dead
Is the adapter getting hot ,then you replace the adapter else you can check the o/p of the adapter with help of multimeter it read 12 volts ,if it reads 12 then there is problem with tv itself..
Good luck...
Feb 02, 2009 | Polaroid FCM-0700A 7 in. Portable...
Sound but no picture on polaroid television
It is the inverter for the LCD I have the same problem the inverter pt# is UI8007S-1 and they sell on EBAY for 58.00 but I found a web page that will give instructions and a plave in Canada that the person that posted says it should cost about 20.00 I removed the inverter and it has a burnt chip just like the article said. Good Luck!
Dec 30, 2008 | Polaroid FDM-0700A 7 in. TV/DVD Combo
Polaroid FCM-0710 - major issue
buy a new after all their not that expensive
Jan 01, 2008 | Polaroid FCM-0710 7 in. Television
FDM-0700A
Hi everyone, I don't know if you have solved your issues yet or not, since these posts are from a while ago, but I have had the same issue. The problem is that of the back-light inverter circuit. The original part is defective and the chip that powers the coils will continually burn out. You can pick up a cheaper replacement substitute here:
http://www.lcdparts.net/InverterDetail.aspx?InverterNumber=UI8007S-1MSS
The part can be found just behind the screen on the bottom if you take the back panel of the screen off.
Hope this helps1
Nov 13, 2007 | Polaroid FDM-0700A 7 in. TV/DVD Combo
Sound works, picture is very dark
You have to be specific when asking a question please. as you dont mention its a flodable LCD screen TV as I had to look it up. your problem is in the backlite circuit. if your a tech, you should have no problem finding this fault but could be a little trick if your not as your going to need to know how a back light circuit works, the parts in the circuit and know how to use a multimeter. Good Luck
Aug 25, 2006 | Polaroid FCM-0700A 7 in. Portable...
Polaroid FCM-0700A 7 in. Portable Television Logo
96 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
