Reloaded Windows XP on computer but apparently lost the ethernet drivers. Downloaded drivers but Wizard cannot find them. I know where they are but Wizard won;t let me select the files, Help!
  • 707 Answers
Http://www.broadcom.com/support/ethernet_nic/downloaddrivers.php
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Ethernet+Components&ProductLine=Ethernet+Controllers&ProductProduct=Intel%c2%ae+82573L+Gigabit+Ethernet+Controller
http://download.cnet.com/PCI-Ethernet-Drivers-version-A01/3000-2112_4-109142.html
Hope this helps.
If this helps you resolve your problem, please
consider giving a good rating and a quick thanks
or good job.It will help me as well Thank you.
Posted on Oct 24, 2010
SOURCE:
Lost the CD driver. Where can i find the audio driver for nforce 630i with geforce 7100(MG-630I-7109) ? I'm using windows xp. I just downloaded the driver and install the driver it includes Serial
That is because the audio controller is not build into the chipset. You would need to know the manufacturer of the motherboard and download the driver from their site, then install it.
Feb 17, 2012 | Pine Technology Computers & Internet
Acer Aspire 3690 laptop network problem
There are multiple LAN drivers available for that model from Acer. Make sure you download all of them for the specific OS and try each one. I note that the only operating systems they have drivers for are Windows XP 32bit, XP MCE 32bit and Vista 32bit. Make sure to also download and install the chipset driver.
Nov 11, 2017 | Acer Aspire 3690 Notebook
I posted a problem for someone else and he has been out of work for 3 months and needs help, I was told to use a person for $50 thid person cannot pay this are there no one that can help him. This is not ...
Is this the problem you're referring to bonescitgo1?
http://www1.fixya.com/support/t10679772-loaded_new_set_windows_friends
If so, yes, when Windows is reloaded sometimes drivers are lost. (They aren't actually lost. The address to them is)
Dell Support > Dimension 2200 Desktop PC > Downloads,
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=DIM_PNT_CEL_2200&os=WW1&osl=en&catid=&impid=
Page comes up automatically to Windows XP operating system. (You installed WinXP Pro)
On this page scroll down to the heading - Network (17) and left-click on the blue down arrow to the left.
There are two drivers listed for an Ethernet adapter;
1) GVC - Driver - Ethernet 10/100 PCI Adapter
2) Intel - Driver - PRO 100/M Ethernet Adapter
To know which Ethernet adapter is in the computer go to Device Manager.
A) Left-click on Start
B) Right-click on My Computer
C) Left-click on Properties at the bottom of the list.
D) Left-click on the Hardware tab
E) Left-click on Device Manager
When Device Manager loads left-click on the + sign to the left of -
Network Adapters
Look at the manufacturer name. It should be either GVC or Intel.
Close all windows, (Device Manager and System Properties), go back to the desktop screen.
Now go on the internet, and to the link above.
Left-click on Download in the blue oblong circle, to the right of the appropriate driver file, GVC or Intel.
The Download Options window will come up.
USE the bottom option; Download via your Internet Browser.
Left-click on Download in the blue oblong circle, at the bottom left.
A small window will come up on the right; Opening R35845.EXE
Left-click on Save File.
Another small window will come up on the left.
In the wording at the top of this window, tells you where the file will download to.
Suggest you write it down.
It may have Desktop, or My Documents, or Downloads, in the wording. (Windows XP)
1) Desktop: The file will be on your desktop screen.
2) My Documents: Left-click on Start, then on My Documents
3) Downloads: Left-click on Start, then on My Documents. DOUBLE-click on Downloads.
When you see the file DOUBLE-click right on it. The Installation Wizard will come up.
At the bottom of the first small window left-click on Next.
Same with the second small window.
Left-click on Finish on the third small window.
[ DO NOT change any settings in the second window. Windows knows the proper place to put this driver file ]
After the Installation Wizard is finished, close all windows, go back to your desktop screen, and restart the computer.
When Windows loads all the way, you should get a pop-up out of the system tray at the bottom of your desktop screen,
"Found new hardware", and perhaps another one will follow, "Found XXXXX Ethernet adapter"
(XXXXX = the manufacturer name of the Ethernet adapter)
For additional questions please post in a Comment.
Regards,
joecoolvette
(Hope things start looking up for your friend)
Oct 17, 2011 | Dell Dimension 2200 (A-D0601) PC Desktop
I installed windows xp on a Dell XPS 400 and on a Dell Latitude D505, both are genuine copies of Windows Xp pro. I forgot to save the Drivers before installing the XP. So the ethernet ports don't work on...
Probably the previous download files you have downloaded are corrupted, do a check the downloaded files sizes from source & the downloaded to your PC/Notebook are the same sizes.
1. Download link @ Drivers & Downloads for Latitude D505
2. Dowload link @ Product Support for XPS/Inspiron XPS (Key in your "Service Tag" to locate the exact drivers for your model).
Hope it helps.
May 01, 2011 | Microsoft Windows XP Professional...
Driver won't download intellinet ethernet driver os 98
Try to manualy specify the path to your driver using driver update.
Oct 06, 2009 | Microsoft Windows XP Professional
Dell dimension 5150 ethernet problem reloaded windows xp home from a windows xp entertainment os. apear fine but not receiving.
Okay, so it seems you installed Microsoft Windows XP Home on a what was Media Center Edition installation, and the ethernet is no longer worker.
Please refer to dell.com's support section, enter your model, and download drivers that you need.
To find drivers you need, Go to start --> control panel and then go to (under classic view) system --> the hardware section, open up device manager, and then look for ones with a yellow big question mark, and get those drivers from dell's website. Burn these drivers to a CD on another computer, or use a USB flash drive if that does work.
Good luck.
Jul 16, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Video capture
try another usb port first..
you may need to update your xp to service pack 2 or 3 as well.
Nov 21, 2008 | IC Intracom Manhattan FUN! CAM Webcam
IBM ThinkPad i Series 1200
Try this driver. I've used it on a few I-series Thinkpads that I've had come through my shop. After the download, uninstall the ethernet drive from the device manager, then reboot. The machine will find the ethernet port and reinstall the drive automatically. If this one doesn't work for you, let me know, an d we'll try a different one.
Aug 17, 2008 | IBM ThinkPad i1200 1161 Notebook
I need vista driver
Here is a link for your driver. I think it will work.
try this
This link will open the download page, select your model and download the driver you needed.
Thanks
Iqbal
Mar 16, 2008 | Kodak EasyShare CD33 Digital Camera
Open Questions:
Computers & Internet Logo
792 people viewed this question
Ekse
Alun Cox
