Question about Kodak ESP9 All-in-One w/USB Cable & 4x6 Premium Paper InkJet Printer
The problem with D-link Router it does talk, I had Belkin G Router and than upgrade to D-Link N and i had no luck at all and switch back to Belkin it work. I do not know what to do? is it G or N or WiFi
  • Kodak Master
  • 7,733 Answers
SOURCE:
Belkin (F5D8235-4) with Tp-Link TL-WR702N as a repeater
It needs to be configured as a repeater first.
http://www.tp-link.com.au/article/?id=397
Nov 14, 2012 | Computers & Internet
I have a belkin g+ mimo router and am currently trying to set it up as an access point to interact with my d-link dir-615 router. when i add my d-link routers ip address string, the belkin disappears. i...
Hello...
Steps To Convert your Belkin Router as an Access Point.
- Connect your D - Link Router to your PC & Check the Default Gateway It Might Be 192.168.1.1 or 192.168.0.1
( Finding Default Gateway: Right Click on Local Area Connection & click on Status - Click on Details For Win 7 & Win Vista & For Win Xp - Right Click on Local Area Connection & Click on Status, Select Support Tab & Click on Details )
- Now Connect the Belkin router to your Com .. Open Internet Browser & Go to 192.168.2.1
- Towards your Left Corner Under Wireless Clink on Use as Access Point
- It will Prompt you For a Password Leave it Blank & Click on Submit
- Select the Radio Button Next to Enable
- In Specify IP Address Type in IP Address in Range of your D - Link Router Eg: 192.168.0.254
- Select Subnet Mask - 255.255.255.0
- Click on Apply Changes
- Now Open the Router Setup Page Using the Ip Address which you gave EG: 192.168.0.254
- Connect an Ethernet cable From your D - Link Router to Any 1 of the Wired Slots on the Router ( Note: We are using Wired Slot as we have Disabled the NAT on the Belkin Router It Gives you IP Address From your D - Link Router & the DHCP on the Belkin Router is Turned Off)
- Power cycle the D- Link Router & Belkin Router For 15 Seconds Each ( Unplug the Power cable & Plug it Back After 15 Seconds)
- Now go to the Router Setup Page & Check the Internet Status in the Top Right Corner It Would Be Connected.
- Try Going Online... :)
Feb 19, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Windows 7 upgrade, Belkin wireless router. Sa...
I RECOMMEND YOU TO UPDATE THE FIRMWARE OF YOUR ROUTER. Download the firmware from belking support site.
May 20, 2010 | Belkin F5D8236-4 Router
CANT CONNECT ROUTER BELKIN MODEL FSD7632-4 TO TALK TALK
Hi Friend,
Please follow the below link,which provide the easy stepwise installation for your belkin router
http://www.fixya.com/support/r4364415-configure_brand_new_belkin_routers
Regards,
Aysaam
May 13, 2010 | Belkin (F5D7230-4) Router (587009)
Belkin F5D7234-4 i have great connection but
  1. A very useful tool to use for wireless issues is xirrus, http://www.xirrus.com/library/wifitools.php If you can copy the program onto the PC install and run, this test if your adapter is working and also will display all the networks broadcasting in your area. and what channel they are using. If you are also using one of the same channels it may be interfernace - Have a look at the channels being used - loginto the router and change channel to one that is not used - try and use channel 1 or 6 or 11
  2. Wireless Security:- Loginto the router, this may seem difficult, but its really straight forward, - however you will need to know how to login into your make of Router - A manual cna be found here http://en-us-support.belkin.com/app/product/list/q/routers/ choose, G in first drop down and then the model in the second dropdown. That will explain how to login. Once you have logged into the router main page, goto the wireless section and remove any wireless security, this maybe a simply as a box and click disable. --- Now see if the machine run faster on the wireless. This may be a direct link to the manual http://en-us-support.belkin.com/app/product/detail/p/387
  3. safemode:- Try to boot the PC into "safe mode with networking". To do this switch the PC on and now as it starts keep tapping the F8 key untill a menu appears, from that menu choose "safe mode with networking". If that now connects at a fast speeds - post back a comment and if that's the case, We can try doing a "clean boot" and try to identify the startup or process that is causing the issue
  4. It may be you need a firmaware upgrade from here http://en-us-support.belkin.com/app/answers/detail/a_id/301 also includes instructions on how to do the upgrade. This may be a direct link to the firmware http://en-us-support.belkin.com/app/product/detail/p/387
Mar 23, 2010 | Belkin F5D7234-4 Router
I'm trying to upgrade the firmware on a belkin wireless router
upgrade of Firmware is at your risk...
never upgrade Firmwares....they are not ment for that....
your hardware may be rendered useless after firmware upgrades....the chip inside your hardware is programed to run based on a certian program installed as a firmware from the factory....sometimes upgrades will screwup your hardware....so be careful and do it at your own risk...
Dec 10, 2009 | Belkin (F5D7230-4) Router (587009)
F5D7230-4 & Linksys AG241 no longer talking!
first reattch all connection to Belkin router then check.
If still can't access interent then you need to reset router.
For that press RESET button for 10 seconds it is in back side of router.
then connect your router to computer with ethernet cable then access it with defalt link
http://192.168.15.1
type user name as "admin" and password "admin" or blank or "password".
Then configure your router then check.
Aug 07, 2009 | Belkin (F5D7230-4) Router (587009)
Kodak ESP9 All-in-One w/USB Cable & 4x6 Premium Paper InkJet Printer Logo
67 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Clive
Clive
Ekse
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
