Question about Dell Dimension 4700 PC Desktop
My dell 4700 diagnostic lights A&B are yellow, C&D are green & the monitor is dark. I can not get anything to show up on the monitor. Everything has power & was working normally yesterday. I dusted everything off & reset the memory cards with no change. Any suggestions?
  • 3,940 Answers
The LED indication is a Memory failure. Make sure when inserting RAM that the power is unplugged and you press and hold the power button till all power is discharged from the motherboard. WHen inserting RAM, make sure levers are int he full back position and you press down firmly with both thumbs till the module snaps in place and the levers snap up in the locked position on their own (DO not pull up the levers)
If there is no change trying RAM modules in slots individually, then either all RAM modules are damaged, or the slot is bad, in which case a motherboard is required
Posted on Oct 24, 2010
SOURCE:
Abcd diagnostic light are green and a and c are yellow
The service manual for the Dell XPS 8300 doesn't show ABCD LED diagnostic lights. On other Dell models Y-G-Y-G indicates a video problem.
Mar 12, 2015 | Dell Xps 8300 Desktop Computer
Diagnostic lights a green, b & c orange
Rear Lights Dell Computer Error Codes
Rear LEDS are labled A through D and can change from green to yellow. Some typical LED reading might be:
A - yellow, B - yellow, C - green, D - green <-- Indicates a problem with the RAM.
A - yellow, B - green, C - yellow, D - green <-- Indicates a problem with the video card.
Refer to the Dell website for your specific model, as these lights can vary from model to model.
see more from this site
Jan 16, 2014 | Dell Precision Workstation 670 PC Desktop
Green power light comes on but disk drive lights keep blinking and my screen is black on my dell dimension 4700
Remove ALL media from the machine DVD, CD, USB, etc. Check/reseat all Monitor cables. Reboot. If that fails, unplug , plug back in in 30 seconds or so. reboot, if you get a Dell Logo, Open the boot Menu and select Boot from HDD first.
Dec 23, 2012 | Dell Dimension 4700 PC Desktop
COMPUTER WILL NOT TURN ON BUT THE MOTHER BOARD THE GREEN LIGHT IS ON..WILL NOT START UP..
For one the green light is just to show that it has power. its mostly there so you don't electrocute yourself. Are there any beeps when you try to turn it on? anything on the screen at all?
Aug 30, 2011 | Dell Dimension 4700 PC Desktop
I have a Dell dimension 4700 desktop and I've had
You have a problem with a device on your system board. If you have the original discs that came with your PC, then the Drivers CD has a diagnostics tool when you boot with it installed. Run the diagnostics to see if you can determine the problem. Here is a link to the Dell site that may help you out:
http://support.dell.com/support/edocs/systems/opgx280/en/ug/tools02.htm
Best of luck to you. But may be time for a new system.
James
Aug 12, 2011 | Dell Computers & Internet
Dimension 3100 wont turns no power button light there is also an green light on motherboard cpu and power suplly fans working but wont bot up
Contact technical assistance.They will most likely ask you to send it back to repair.
This chart is where I got my conclusion.
Power Light
Problem Description
Suggested Resolution
Solid green
Power is on, and the computer is operating normally. On the desktop computer, a solid green light indicates a network connection.
No corrective action is required.
Blinking green
The computer is in the suspended state (Microsoft® Windows® 2000 and Windows XP).
Press the power button, move the mouse, or press a key on the keyboard to wake the computer.
Blinks green several times and then turns off
A configuration error exists.
Check the diagnostic lights to see if the specific problem is identified.
Solid yellow
The Dell Diagnostics is running a test, or a device on the system board may be faulty or incorrectly installed.
If the Dell Diagnostics is running, allow the testing to complete.
If the computer does not boot, contact Dell for technical assistance.
Blinking yellow
A power supply or system board failure has occurred.
Solid green and a beep code during POST
A problem was detected while the BIOS was executing.
See "Beep Codes" for instructions on diagnosing the beep code. Also, check the diagnostic lights to see if the specific problem is identified.
Solid green power light and no beep code and no video during POST
The monitor or the graphics card may be faulty or incorrectly installed.
Check the diagnostic lights to see if the specific problem is identified. See "Video and Monitor Problems" in your Owner's Manual.
Solid green power light and no beep code but the computer locks up during POST
An integrated system board device may be faulty.
Check the diagnostic lights to see if the specific problem is identified. If the problem is not identified, contact Dell for technical assistance.
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
It doesn't show red color. i tried to do factory reset. but still problem.
1.After turning on the projector, press "+" and "-" buttons on the control panel
simultaneously for 3 seconds and release the buttons when screen goes blank.
2 Press "+" and "-" buttons again to exit the diagnostic mode.
3 While in Self-diagnostic mode, the screen will run a seven-color-cycle test as
following:
Red--> Green--> Blue--> White--> Watchet Blue--> Dark Green--> Yellow.
Ensure that the colors of the test pattern are correct.
Contact Dell if the colors are not displayed correctly.
Mar 01, 2011 | Dell 2400MP DLP Projector
Processer fan comes on high speed at start up and monitor is dark
Hi there, you might be lucky
The dell dimension has a feature for diagnosing problems
on the back of the pc right beside the network port RJ11 are four lights if the pc is fine then they all go green, if there is a problem then they will show yellow or not light up at all please check these and get back to me.
The light on the front with the (battery icon) is actually the hard drive activity light, meaning that the hard drive is being constantly accessed may be important will know more from the lights.
Apr 30, 2009 | Dell (E210882) Motherboard
Dimension 4700 wont light up the monitor.
Hi Cactus,
My name is ArmyMason, let me get this straight. You have a Dell Dimension 4700 and the Monitor isnt working with the PC? This could be one of two things. Either the monitor is bad, to test this I would connect it to some other computer to verify its not the monitor. It could be the video card. According to Dell it the light combo you gave me indicates their is an issue with the floppy or hard drive and you should check to see if all the cables are correctly seated on the motherboard and on the Drives.
I really think it could be an issue with the video card. To resolve this I would consider purchasing a new card or rip one out of an old know good computer to see if that is the issue.
Thanks,
ArmyMason
Feb 23, 2009 | Dell Dimension 4700 PC Desktop
Dell Dimension 4700 PC Desktop Logo
364 people viewed this question
Ekse
Clive
Clive
