Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Ice fan don't work - LG LFX25960ST Stainless Steel French Door Refrigerator
    New Friend:
  • 51 Answers
The ice fan relay could be bad, the fan motor need to be check, and also check any bad connection
Posted on Oct 24, 2010
SOURCE:
Samsung RM255LABP/XAA freezer only gets to 27 degrees, won't harvest ice. Fridge and lower freezer work fine. After pressing the ice maker reset button, I hear a ding don sound coming from the control...
It won't harvest ice on its own unless it detects a temperature of 10 degrees. The ding ding sound is the control letting you know that the ice maker is functioning fine. Remove the evaporator cover in the freezer and make sure the coil isn't frozen over and the fan isn't restricted from turning. Check the door gasket is getting a good seal. If that's all good replace the sensor on the ceiling of the freezer.
Aug 31, 2016 | Samsung Refrigerators
Front panal displays code 1F, and pads don't function
You are probably seeing the Er IF error code that indicates a problem with the ice compartment fan.
The Er IF error code indicates that the main control board detects that the ice compartment cooling fan is not working. This will cause a lack of cooling in the ice compartment and will normally result in no ice production. This is something that a service technician will usually need to correct. If you are advanced in technical skills, you may be able to correct this problem yourself. It will require the removal of the inside back panel of the freezer compartment. This is not an easy task. I recommend that you review the procedure for this task that is shown in the image below. Make sure that you are able to safely perform the tasks described before proceeding with this repair. Unplug the refrigerator to disconnect electrical power before accessing internal components. Once you access the ice fan, you may find excessive frost in this area and on the evaporator that could be causing your cooling problem and fan problem. If you defrost this area, you may find that you do not need to replace parts. If you find no excessive frost or the Er IF error code resumes after removing any frost then you will likely need to replace the ice fan. You can order this part here.
Click here for the image.
Nov 21, 2012 | Kenmore Refrigerators
Fridge not getting cold...but freezer is working
the fridge gets its cold air from the freezer fan blowing it through small air passages between the freezer and fridge. when you adjust the temperature in the fridge you are increasing/decreasing the amount of air being let into the fridge. Two common problems that could cause the freezer to freeze but not the fridge getting cool is the freezer coil is frooze like a ice cube blocking the air going to the fridge or freezer fan is not working could be bad or froze up due to too much ice. If fan works after manually defrosting problem could be in the auto defrost mechanism. If fan don't work after manual defrost replace fan. Manual defrost by putting a pot of very hot water in freezer with door closed change water foten until defrosted.
Jan 02, 2012 | Westinghouse Avalon Refrigerators
E442B Fridge is not cold & some ice build up in fridge. How do you remove the back of inside of freezer to check ice build up there?
don't mess about with it just remove items and get a new one sound like its leaked it's gas (BUT DON'T PANIC) its not harmful and its not going to blow up! you could call a engineer but a lot of the time your just as good putting that money towards a new one
your friendly domestic appliance engineer chris
Dec 05, 2011 | Refrigerators
Freezer working fine but fridge not gettind cold.
The first thing you need to check is whether the fan is operating, moving the cold air from the freezer to the refrigerator. If it is operating, you should be able to feel air flow in the refrigerator when the fan is operating. If you don't but the fan is operating then the cooling tubs are probably clogged with ice or frost.
Jul 20, 2011 | Smeg Microwave Ovens
KENMORE COLDSPOT MODEL10652212104 THE FAN IN THE FREEZER DOESNT SEEM TO RUN, DOESNT FREEZE ICE EITHER BUT IT DOES HAVE WATER IN THE ICE TRAY. THE REFRIG PART DOEN GET COLD EITHER WE REPLACED THE VAVLE...
Hi, if the fan, evaporator fan is not running, it has failed on you. If you are up to doing this kind of work, you can replace it your self. It is a 120 volt evaporator fan motor, and if you can get it out, take it with you along with the name of the unit, model & serial # to an appliance parts house to get one. If they don't have the exact one, they have universal ones that will fit. This will solve your problem.
Shastalaker7
A/C, & Refrigeration Contractor
May 16, 2011 | Microwave Ovens
Freezer is working but refrigerater side is not
Hi!!
This could be due to few things, so let's start with the easy ones;
Check fridge temp. control.
Check fan in freezer (should come on if door is kept open a couple of minutes.) if fan does't come on,
or if weak (should come on strong), unplugg the unit and take back cover off, (should be 4 screws), test fan applying 110v AC to it, if defective, replace. If fan OK, check for iced up evaporator, if so, defrost using a heat gun or hair dryer, make sure air duct to fridge is clear of ice..
Adjust temp. settings according to manufacturer suggestion (wait 24 hrs. before adjustments)
Don"t forget to rate this post. Good Luck
May 12, 2010 | Refrigerators
FAN DON´T WORK IN THE RIGHT SIDE (REFRIGERATOR)SAMSUNG RS21DDSW
I had this problem, Motor is gone. The drep motor is a pile of ****. Go to ebay or buy a replacement direct from korea, The 12v doesnt appear on the cct as the fan doesnt operate unless the door is shut. Hope this helps anyone who google this
Mar 26, 2009 | Samsung RS2630AWW Side by Side...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
51 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
deecee73
Level 1 Expert
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
