Question about HP Pavilion MD5020N 50" DLP HDTV
Hewlett Packard hd pavilion tv opc light flashing
SOURCE:
  • 1003 Answers
SOURCE: Driver
WHAT DRIVER DO YOU NEED OR ARE YOU REFERING TO A RESTORATION DISC
Posted on Feb 02, 2008
  • 94 Answers
SOURCE: hello orange light constantly flashing at bottom
check your cartridges, perhaps one or both need to be changed.
Posted on Aug 14, 2009
  • 6027 Answers
SOURCE: how many USB ports does HP / Hewlett-Packard
If you have the standard configuration, this machine has 7 USB ports (4 on the back and 3 on the front).
I hope this helps.
Posted on Jan 22, 2010
Testimonial: "This HP desktop is a new offering and I could not find any detailed manuals or specs. So thank you for your answer."
SOURCE: We have a 42" Hewlett-Packard
Y Board is out. The boards costs about $150 and easy to install.
Posted on Mar 12, 2011
SuperTech-11
  • 1591 Answers
SOURCE: We have a 42" Hewlett-Packard HD Plasma TV. It's
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, eventually the screen may come on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Apr 09, 2011
Testimonial: "Great advice thanks. "
Sound not working in windows 7
- re-install audio driver
- system restore
- re-install windows 7
- upgrade to vista
- HP 623913 003 Pavilion HPE H8 CTO 656599 001
Mar 15, 2014 | HEWLETT-PACKARD Hewlett Packard HP Envy 17...
How to connect my Pavilion g7 notebook to my Toshiba TV
If the TV doesn't have a VGA port, but does have HDMI, purchase a HDMI to VGA cable and insert the VGA into the netbook and the HDMI into the TV. Hope this helps. Get back in touch. Steven :D
Jan 01, 2013 | HEWLETT-PACKARD Pavilion g7t Notebook PC...
How to connect my Pavilion g7 to my toshiba TV
Vga cable? S-video? HDMI? I don't know what connection you have on the laptop and the TV?, you didn't give the model of TV? Try HP support here for info: http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lc=en&product=5078402&
Nothing on my computer turns on and the light on the back is solid green
Press and maintain the On button pressed for 5 to 10 seconds. If you have a router, unplug it and replug it. Try to turn on your computer again. One thing is sure: the light in the back must flash (it is the network signal). Make sure that there is no CD in the CD player of the computer. Please, let me know the result.
Oct 18, 2011 | HEWLETT-PACKARD Hewlett Packard Pavilion...
Lap top goes to screen saver and then light on power button flashes and will not turn on or off i got it yesterday sept 15 2011 dv52155dx
hi; first try to press power button for ten seconds, then press power on again if it still wont work. remove the battery then wait another 30 seconds and place it back, and check if will work. thanks..
Sep 16, 2011 | HEWLETT-PACKARD Hewlett Packard HP 145...
Put phone and usb cord in the lap top to charge...it says software unsuccessful..when i tool the phoen out..and shut it down..the computer wont come back on,,and a little orange light on the side is...
HEWLETT-PACKARD Pavilion dm4-1265dx Notebook
The flashing orange light could be the indicator to tell you that your wireless adapter is working and has a connection to your routericon1.png, if you are not wireless, press the button that is flashing and it will disable your wireless connection,to turn back on press it again.
Or there is another smaller orange indicator which tells you you are runing on battey and it is in need of charge
Aug 21, 2011 | HEWLETT-PACKARD Pavilion dm4-1265dx...
I have a HP s5660f for 1 month now, last week the computer dint start up, the monitor is black and the hd led dint blink. I think that the problem is the motherboard, since the computer turn in but nothing...
My computer has been out of commission since 3 months after I bought it, HP does not stand by it's warranty or it's product. TERRIBLE, TERRIBLE, TERRIBLE customer service!
Mar 30, 2011 | HEWLETT-PACKARD Hewlett Packard Pavilion...
I have tried everything to turn my HP 2150US on, but the power on button does not work. Have already tried to take battery off, memory and HD. Any other idea to be able to turn it on?
Why you take off memory and HD?You definitely can't do that.There maybe something wrong with HP power provide module but shouldn't be your hp laptop battery matter. It is always a difficult problem can't be solve by some words or sentences,you'd better go to a professional laptop repair center to repair it. Good luck.
Feb 17, 2011 | HEWLETT-PACKARD Hewlett Packard HP...
HP Pavilion MD5020N 50" DLP HDTV Logo
63 people viewed this question
Top HP Televison & Video Experts
Ekse
Thomas F. Schneider
Edward Easley
Edward Easley
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
