Question about HP DeskJet 920c InkJet Printer
I have full black ink cartridge. But the printer fault light still shows less ink and refuses to print.
  • HP Master
  • 7,733 Answers
Go to LINK
Posted on Oct 24, 2010
SOURCE:
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
The printer tells me to replace an ink cartridge because the ink has been depleted. The cartridge is nearly new, though. Just yesterday it showed to be half full. I have cleaned the printheads and the...
There is a chip on your cartridge that communicates with the printer to estimate how much ink is left in the cartridge. When the chip thinks the cartridge is empty it will refuse to print any more pages no matter how much ink is left in the cartridge. These cartridges are only estimated to print "up to 840 4" x 6" photos, or 80 13" x 19" photos." If it showed half full yesterday and then you put through a large print job it is very likely the cartridge is empty. In any case once the chip thinks it's empty the cartridge needs to be replaced.
Nov 09, 2009 | HP Photosmart Pro B9180 InkJet Printer
Changing the black cartridge also require change of color
The printer is very good.I ve been using it for approx 1 year now.The printer works on a combination of both black as well as colour ink cartridges.If any of the cartridge is empty,printer will not print.Kindly call Kodak with your problems at 1800 421 6699 and they will take care of the issue for you.
Oct 04, 2009 | Kodak ESP 5 Printer
Ink light keeps flashing
reset the printer by turning it off, waiting 10 seconds and turning it back on, also right click on My Computer and select manage..go to services and stop and restart the spooler service
Jul 24, 2009 | HP DeskJet 930c InkJet Printer
Printer saying refilled bci3e is empty, when it is actually full
This is a very common issue with refilled ink cartridges. The fact is that you have a MP730. The cartridges have an eprom chip loaded into the cartridge which blows once the cartridge is empty. Refilling it as a general rule does not work. The best and only solution to your problem is to pop out to your stationery supplier and purchase a genuine canon cartridge.
As a side not, the ink inside the cartridge is covered by a patent held by canon. it means that no other supplier can use this particular grade of ink. The use on non genuine ink will destroy your printhead and make future use of your unit much less than its normal life expectancy.
Gremlin 11
Dec 10, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Blank Ink not pumping to print head
Turn off the device after removing the printhead After removing the printhead, turn off the device, wait about 20 seconds, and turn it on again without the printhead installed. After it has restarted, reinsert the printhead.
it will go through this long routine of perhaps 20 min or so. after its compleate it should print great.
Nov 22, 2008 | HP Officejet Pro L7590 All-in-One InkJet...
Brother MFC 215C :yellow and red refuse to print
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Nov 12, 2008 | Brother Multi-Function Center® MFC-215C...
Does not print black
Most likely you have no black cartridge installed or it is empty causing your printer to use the colour cartridge for black. But if your colour cartridge has 1 colour which is less full than the others it causes black to become greenish or sometimes reddish depending on which colour is less. A new cartridge or a black cartridge will solve the problem.
Aug 08, 2008 | HP DeskJet 825c InkJet Printer
Printer won't print black
In view of the original poster's lack of interest, I think we can call this one "Solved by Poster".
May 11, 2008 | Epson Stylus C62 InkJet Printer
Low black ink - can not print at all
Most epson inkjets that use separate colour and black cartridges will not print if either the colour or the black cartridge is empty. The printers come with cartridges when new but they are only part full and more ink is used up filling the printer reservoir when first starting up. Replace your black cartridge and you should be able to print. barrie60s
Jul 24, 2006 | Epson Stylus C88 InkJet Photo Printer
HP DeskJet 920c InkJet Printer Logo
35 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
