Question about Muratec - MFX-1300 Copier
Please call for service - Muratec - MFX-1300 Copier
    Genius:
  • 1,218 Answers
If the machine is saying "Please Call Service"..you will have to access the Service Call function to determine the exact problem.
Press PROG,*,6
Press PROG to select "service call" mode, then press ENTER.
The Error Mssge will be displayed.
For example Heater Error, Drum Fuse Error, Inside Fan Error, etc, etc...
**Most common( given m/c age.) would be "Heater Error"...which indicates a problem with the Fuser Unit.....if this is the case you will need to contact local Muratec service for parts.
Posted on Nov 02, 2010
  • Ian Prescott
    Ian Prescott Nov 04, 2011
    Many thanks apb20, you are a Star!
    Cheers, Ian
SOURCE:
What is machine error 4F on Brother dcp-145c
Sir/Madam
According to your Problem I think In Your machine These error codes mean the machine problems. In many cases, the machine will require service. Or Re-installation Brother Printer Services,
If the error code on the LCD display of your machine is not listed in the On Brother Printer Official website Then I Suggest You To Follow On This Below Link To Contact Official Brother Printer Customer Service,Or Your Brother Printer your machine is not listed in the chart below,
http://welcome.solutions.brother.com/BSC/public/as/hk/en/faq/faq/000000/000100/000068/faq000168_005.html?reg=as&c=hk&lang=en&prod=dcp145c_eu_as#other-faqs
Error Code Cause Solution 10,11,12,1A,1D There is a problem on the duplex unit. Please contact Brother Customer Service from "Contact Us". 30,31,32,33,34,35,36,37
38,39,3C,3E,3F The machine does not work due to a paper jam. Clear the paper jam. (Please refer to "FAQ's & Troubleshooting" for information on the Paper Feed Problem.) 40,42,43,44 The internal temperature is too low or too high. Unplug the machine from the AC outlet and if possible warm or cool the room where the machine is located. 46 The ink absorber pad is full and needs replacing. Please contact Brother Customer Service from "Contact Us". 48 There is a problem on the print head. Please contact Brother Customer Service from "Contact Us". 49 The internal temperature is too low. Unplug the machine from the AC outlet and if possible warm the room where the machine is located. 4F There is a problem on the print head. Please contact Brother Customer Service from "Contact Us". 50,51,52,57,5A,5B,5C,5D
5E,6C,6F,70,71,72,73,7A
7D The machine does not work due to a paper jam or some sensor problem. Clear the paper jam. (Please refer to "FAQs & Troubleshooting" for information on the Paper Feed Problem.)If the problem still continues after clearing the paper jam, please contact Brother Customer Service from "Contact Us". 8F There is a problem on the paper feed motor. Power the machine off and back on. If the problem still continues, please contact Brother Customer Service from "Contact Us". A5,A6,A7,A8,AF There is a problem on the scanner. Please contact Brother Customer Service from "Contact Us". E0 There is a problem on the modem. Please contact Brother Customer Service from "Contact Us". E2,E3 There is a problem on the main PCB. Please contact Brother Customer Service from "Contact Us".
Or In case Your Printer Is Out Of warranty And You Still Need Online Brother Printer Support For Your Brother Printer y Third Part Online Brother Printer Customer Services Representative,The Follow Us On Hear Brother Printer Support
Jan 29, 2013 | Brother Ink for Dcp145c Lc-980
Tip
WHAT TO DO IF YOU ARE UNABLE TO SEND TEXT MESSAGES ON YOUR PHONE
Subscribe -The text message and e-mail features are supported by the service provider. To use these features, you have to subscribe to the service.
Please contact your service provider for more information on the availability of these services in your area. The service provider will also need to assist you in storing a message center number. Load Settings - Multimedia Messaging Service (MMS), Short Messaging Service (SMS), and E-mail settings may be available on our website. Please visit our settings area.
If you have subscribed to this service and loaded your settings and are unable to send messages, please contact your service provider
on Sep 28, 2010 | Cell Phones
I need help to get a password on a sylvania netbook.The service is not working.
Hi.
Based on the information you have provided, it seems that the issue is due to the "Netlogon Service".
The Netlogon Service is responsible for the Windows logon.
Hence, it is required to ensure that this particular Service is running.
Please follow the below steps to enable this Service:
1) Press the "Windows Logo" and "R" keys simultaneously.
2) This should open the Run command window.
3) In the Run command window, please type "services.msc" and press Enter.
4) This should open the Services window.
5) In the Services window, please check for the "Netlogon Service"
6) Double-click on the Netlogon Service.
7) Then, check if the Service is started. If not click on "Start" to start the Service.
8) Also, click on the drop down menu, and select the option to "Automatic".
9) Then, click on "Apply" and "OK'.
10) Restart the Computer and then try to login to Windows.
11) The issue should be resolved by the performing the above steps.
Hope this helps.
Please feel free to contact for further assistance.
Thank you.
Suresh
Aug 08, 2011 | Computers & Internet
When i start my laptop, its always shows a message that WDDM service is not working.
You need to set the WDDM service automatic.
please follow the below steps to set the service Automatic.
Click on Start -> Control Panel -> Administrative tools -> services
Or
Start -> Run and type in Services.msc and perss enter
Find the WDDM service on the Services window. then right click Properties go to general tab select startup type set it to AUTOMATIC then apply and restart the services.
Please check the status after restarting. Please let me know this resolve the issue you are facing, if not i can assist you further.
thanks,
Satheesh
Jan 20, 2011 | Computers & Internet
I have a set of X-540 Logitech speakers and they are still under waranty and a few nights ago the power when into them what is the problem and how do I get the service to get it fixed
Please go to service center & service your X-540 because if you services so warranty void. So Please go to service center.
If this answer helpful please vote me.
Good luck.
Thanks for using FixYa
Jan 17, 2011 | Logitech X-540 Computer Speakers
Bpl service menu code
press one time display key and three times mute .service mode will open
Feb 27, 2010 | Hitachi C25-RF35S 25" TV
Vaio service utility stopped working
You may enable the VAIO Event Services in the Services window.
Please press the Windows logo on the Keyboard and then press the "R" key while holding down the Windows logo key to open the Run dialog box. Then, please type "services.msc" in the Run dialog box and click OK to open the Services window.
In the services window, please locate the "VAIO Event Services" then righ click on it and select start.
If the issue persists then uninstall the "VAIO Event Services" from "Add or Remove Program" windows then restart the Computer. After restarting the Computer, please download and install Sony Shared Library and the Sony Notebook Utilities.
You can download the Sony Shared Library from the link given below:
http://www.esupport.sony.com/US/perl/swu-download.pl?mdl=PCGV505DX&upd_id=1325&os_id=7
Please click on the link given below to download Sony Notebook Utilities:
http://www.esupport.sony.com/US/perl/swu-download.pl?mdl=PCGV505DX&upd_id=2266&os_id=7#
Please download and save both the utilities on the Desktop then first install Sony Shared library then restart the Computer and then install Sony Notebook Utilities. This may also require restarting the Computer. After installing the Sony Notebook utilities and restarting the Computer, please perform the steps mentioned at the top on this page to check in the "services" window whether the "VAIO Event services" is started if not please do so.
Performing all the steps as mentioned above should resolve the issue.
Apr 05, 2009 | Sony VAIO V505 Notebook
I nedd sst for canon IR8500
i can get you the newest ver. of the SST but i need your email and you have to rate first
Mar 15, 2009 | Office Equipment & Supplies
Phone locked! Please Contact service center!
My phone is giving message Phone locked! Please Contact service center!)
Dec 31, 2007 | Haier D6000 Cellular Phone
356 people viewed this question
Top Muratec Office Equipment & Supplies Experts
Ed
Ed
Adorjani Laszlo
Cosmas Matanda
Cosmas Matanda
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
