Question about Amana 24 in. ADB1200AW Built-In Dishwasher
Dishwasher will not drain.
Dishwasher started but did not go into wash cycle. When it started it sounded louder than normal and did not sound like the water was filtering through and then it just quit. Now the tub is full of water and the dishwasher will not work at all. I checked the circuit breaker and that was fine but when I push any of the buttons nothing works.
  • Amana Master
  • 19,396 Answers
Check first that the drain hose and the drain lines are not blocked.
Once you ensure that the drain lines are clear, this usually means that the drain pump is stuck, clogged or faulty.
Try first unplugging power cord for ten minutes.
If this does not help, the pump is clogged or defective.
The drain pump must be tested by energising it, if the pump is fine, then this is may be a faulty control, replace the control assembly in this case.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
Posted on Nov 29, 2008
Why is my whirlpool dishwasher making a loud noise during drain, wash and rinse cycles?
They can be complicated to re-assemble. Best solution is to video the procedure (if you have a video camera) during disassembly and make notes and diagrams to orient things properly and make sure the correct screws go back where they shoud. Takes more time, but you'll be glad you did, it will save you a lot of aggrevation in the long run.
Aug 24, 2014 | Whirlpool 24 in. GU1500XTLS Stainless...
Dishwasher MDB6769AWS1 has started making noise just after it fills and starts to wash
There are several moving parts: The motor, pump, valves and actuators, and the rotating sprayers. Is your door seal still okay? If it's not sealing at the top it could sound louder yet not leak water. Or the motor and/or pump shafts are wearing out and becoming noisy. Keep an eye open for leaks, as this is what will happen if the pump becomes defective.
May 06, 2012 | Maytag MDB6769AWS Stainless Steel Builtin...
Kenmore 665 Dishwasher
Sound like you have a bad control console, which will need to be replaced.
Apr 08, 2012 | Kenmore 13742 / 13744 / 13749 Built-in...
Loud sounds
Many Frigidaire dishwashers come with the promise of being the "quietest dishwasher in its class," according to Frigidaire. However, a quiet dishwasher doesn't necessarily mean that the dishwasher is silent, as some noises are normal. It can take some troubleshooting at times to determine if a noise coming from the dishwasher is typical or if it indicates a larger problem Listen for the sound of water filling and draining throughout the wash cycle. These sounds are normal and do not indicate an issue.
  • 2 Pay attention to the drain motor, which operates at the beginning of each cycle. This noise should be fairly quiet and should not sound like a loud, grinding or banging sound.
  • 3 Note that the sound will change when the wash cycle moves between the lower and middle spray arms. This sound should be temporary and fairly quiet.
  • 4 Look for hard items in the dishwasher grinder or filter if a loud crunching, buzzing or grinding sound is heard. The dishwasher can typically grind up these items within one or two cycles, but the item may be lifted out and discarded to eliminate the sound.
  • 5 Remove the bottom rack and spray arms from the bottom of the dishwasher if there is a loud noise coming from the dishwasher that does not resolve itself. Look inside for the impeller, which is round and spins. Remove any debris that may be clogging up the impeller or pump.
  • Oct 07, 2011 | Frigidaire Professional Series 24 in....
    Frigidaire dishwasher noticeably louder - circulation motor?
    Try to position the machine, so that you can run the cycle and watch the dish washer. Remove the back panel and hear the sound of origination. Take suitable action as per your convenience. You can clean & replace the bearings if they are worn or replace as a whole unit.
    Jul 06, 2010 | Frigidaire Dishwashers
    Maytag DWU6602AAE. My Maytag dishwasher (14 years
    SOUNDS LIKE A TIMER PROBLEM. YOU MAY WANT TO PRICE A REPLACEMENT TIMER. AND PRICE OUT NEW DISHWASHERS. GOOD LUCK!
    Feb 25, 2010 | Dishwashers
    GU1500XTL loud humming sound during the cycle, getting louder
    The run capacitor on the main wash motor needs replacing. Eventually it will just hum and overheat instead of rotating, so better replace it now before it overheats.
    I doubt you can acces it easily yourself, as it may be away from the motor, and have to be tracked down.
    Aug 05, 2009 | Whirlpool 24 in. GU1500XTLS Stainless...
    My dishwasher is making a very loud noise during the wash cycle.
    It is probably a dying recirculation/drain pump. It serves both purposes so is only off when the drying cycle starts. If the bearings are going bad the seals will probably fail soon too since they will be more stressed by any wobble in the pump shaft due to wear.
    Dec 28, 2008 | Dishwashers
    Diswasher motor making noise during wash cycle
    It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
    Jan 04, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
    Amana 24 in. ADB1200AW Built-In Dishwasher Logo
    179 people viewed this question
    Top Amana Dishwashers Experts
    Oloyede Monsuru
    Kolbrun...
    Mike
    Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
