Question about Refrigerators
Im after a manual for westinghouse freestyle fridge RJ422T-R
    New Friend:
  • 51 Answers
You can go visit onlinand Google.www.manual for westinghouse freestyle fridge RJ422T-R
Posted on Oct 24, 2010
SOURCE:
Hi I have Westinghouse freestyle 450 my problem is that no matter how low I have temp the begs freeze in crisper other wise been very happy I have had this fridge for 20years
fridge settings work in reverse to freezer settings
1 for a fridge is almost freezing where it should be around 4
cold air sits at the bottom of the fridge so the setting will be colder in the crisper draw that at the top shelf
May 26, 2017 | Westinghouse Refrigerators
I have a Westinghouse freestyle fridge and it is collecting up to 500 ml water underneath the crisper bins each day.
remove crisper bins and look for the drain tube . it must be clogged . as water is supposed to drain to the evaporation tray under the fridge .
Dec 17, 2014 | Westinghouse Refrigerators
Where is drainhole in westinghouse freestyle refrigerator
usually located midway of fridge compartment in center its a small one usually covered with a casing or cover sometimes? some are located at center sides or bottom of fridge. if u look under the fridge and see the tubing then follow it up and get an idea where that drain plug is?
Dec 04, 2014 | Westinghouse Refrigerators
I need a wiring diagram for the RJ532S freestyle westinghouse fridge. The defrost timer is dead and its in defrost mode
We do not have wiring diagrams. Please contact the manufatuer for a service manual
Feb 02, 2012 | Refrigerators
Westinghouse freestyle fridge. Fridge compartment not staying cold, freezer compartment working fine.
likely a malfunction somewhere in the defrost system, i.e., the defrost timer control, the defrost heater assembly, or the defrost bimetal thermostat
Mar 01, 2010 | Refrigerators
Need an instruction manual for Westinghouse freestyle 745 wall oven, preferably in PDF, having trouble setting the clock. Can you help please?
instructions-manuals.com/search.php?...WESTINGHOUSE%20FREESTYLE...FREESTYLE%20920%20DISHWASHER
safemanuals.com/index_upload.php
www.manualsnguides.com/search.php?...WESTINGHOUSE%20FREESTYLE......
You can copy and paste any of the above links in your internet address bar under a new tab to bring you to your manual
Nov 12, 2009 | Ovens
My westinghouse freestyle frost free 650 litre is
The fridge need to be devrosted open up freezer door take back of and look if all ice gone from freezing rods restart if same prob it looks like fan not going or heating element not workingon
Nov 08, 2009 | Westinghouse Refrigerators
I have a westinghouse freestyle fridge and it is leaking water seem to be coming from behind the tempreature adjusting knob. Do you have any suggestions. Thanks Michael model RJ452T-R
Open the fridge door, locate the dial which moderates the temperature located on the 'ceiling' of the fridge. Remove the light cover, remove the globe. Unscrew the two screws which hold the dial housing to the ceiling of the fridge, let this housing hang from the ceiling in the wires. This will expose a red funnel shaped tray, gently lift the tray and pull it out, you will most likely find the tray drain is blocked with gunk, clean and reinstall. Assembly is reverse of removal.
Nov 03, 2009 | Westinghouse Refrigerators
Fridge freezer not cooling
(bad news) Repair man came today and said the compressor has died ;- (
(good news) Westinghouse will replace compressors less than 5 years old with a new one, just ring them with your serial number (inside front door) or supply a receipt and you only have to pay for the labour ;-)
Apr 12, 2009 | Westinghouse Refrigerators
Refrigerators Logo
1,138 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
