Question about Casio G'zOne Boulder Cell Phone
My phone wont stay charging. I have to pull the cord tight and at an angle to get it to stay charging. this is with my home charger. Any other problems with plug or chargers?
  • 282 Answers
Sound like the terminal on your phone is broken off internally. the soldier of the pins are bad thats why you have to move it around to get it to connect. You can see if there is a local repair shop in your area that does port repairs. hope this will help.
Posted on Oct 23, 2010
SOURCE:
Mophie charger plug wont stay in
I had the same issue. I was able to trim the cable shell to get it to insert further and take better hold. I suspect some cables may work better than others but the design is poor as they have the jack on a curved corner. Had they angled it a little it would work better and actually work. They should also include a screen protector for the price. The case scrapes off standard protectors because of the tight fix, though the tight fit is good. I actually love the product though as it actually works. Just not enough real world testing.
Jan 20, 2014 | Apple iPhone Smartphone
Wont' stay on and wont' charge
If your telephone wont stay on and wont charge, then you need to carry out some test to know where the fault is from. First, test your battery if it is working by inserting it in another phone then charging it for about 3 hours then power on the phone to see if it will come on, if it does, then it means the battery is alright. But if it does not come on, then you know the battery is bad and needs to be replaced.
Now test the phone by inserting a well tested battery inside the phone then power it on, if it comes on, then the phone is alright, but if it does not come up, try to prop the battery so it will connect tightly with the terminal of the phone, then power it on, if it comes on, then it means the battery was loose and just need some propping, but if it still does not come on, then there is a problem with the phones power panel.
Test the charger also, by trying to charge another phone with it to see if it will work, if it charges, then it means the charger is alright and if it does not charge, then it means the charger is bad and need to be replaced.
After carying out these tests, you will be able to tell which component is faulty and needs replacement.
Take care and good luck
Dec 29, 2010 | Cell Phones
My samsung rant does not charge when the charger is attached, when you remove the charger it beeps like it is supposed to if you turn the phone off and try to charge it just recycles from off to the...
This worked for me........Plug in the charger, and then wrap the cord around the phone tightly! But no too tight or the whole damn thing will fly out (this happened to me)
Jan 31, 2010 | Samsung Rant Cell Phone
My env2 wont charge. whenever i plug it in, the battery stays the same. what do i do?
This seems to be a common problem for the env2. If you hold your charger a certain way in the phone does it charger? Is the charger port broken or damaged?
If so the easiest workaround is to get an external battery charger and extra battery to charge the phone.
Check out the following link for information on the battery charger and other options for the env2 charge issue.
Lg Env2 External Battery Charger Fix
Jul 17, 2009 | Verizon Communications enV2 Cellular Phone
My delphi xm2go radio unit will not take a charge. Have tryed everthing! It starts to charge then goes dead!
I had the same problem, Based suggestion that the plug in the Radio is worn and not making contact, I used a small screw driver to shift the pin in the charger input hole from the center a little. That did it on both my Myfi;s. The now charge properly, and stay on as long as I need. Which needless to say, brings a smile to my face :) .
Apr 21, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
My phone doesnt charge
If it only charges at a certain angle, that means that one of the tracks and/or pieces of metal is not alligned correctly. The only thing that you can do is report it under warranty/insurance and try to get a new one.
Feb 23, 2009 | LG Vu CU920 Cellular Phone
Can't get charger cord to stay in phone to charge
I would recommend stopping by the shop you bought it at, or a cell phone accessory store. They will usually (more than likely) let you test out a charger, as it could be simply wear and tear on your charger. Doing this will address your problem as it will let you know whether in fact it is the charger, or the phone itself.
Good luck.
Jan 26, 2009 | LG CHOCOLATE VX8500 Cellular Phone
My sidekick 2 won't charge
mine stop charging sometime ago, and I switched to a nokia 3310 charger and its been working fine since. might be a little tight going in at first. good luck.
Aug 10, 2008 | T-Mobile Sidekick II
My enV will not charge!
Hey i think i just figured out the problem to all the port charging issues for the envy and envy 2 phones with verizon. its not the phones, its the charger cord! the part that goes into the phone. it gets pulled out over time from pulling the cord out of the phone all the time. get a pair of pliers. grab the end and push the metal end of the cord against somthing hard, push it back in so it is at the appropriate depth. this should make it charge properly again!
Jul 17, 2008 | LG enV VX9900 Cellular Phone
My phone wont charge
I have the same phone and bought a new charger and it still wont work, it's the phone
Sep 13, 2007 | Samsung SPH-M500 Cellular Phone
Casio G'zOne Boulder Cell Phone Logo
620 people viewed this question
Top Casio Cell Phones Experts
Ekse
RONALD CARTER JR
Are you a Casio Cell Phone Expert? Answer questions, earn points and help others
