Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool washer transmission
I need to know how to get transmission to line up to re-install bolts.
  • Toby Norton
    Toby Norton May 11, 2010
    What model do you have? Most of the newer transmissions have a small nub with a white peice of plastic on it that will face towards the front. If your transmission won't go back in, look where it came out of. There will still be a basket drive (brake) that can slide down. Make sure that it is pushed back up inside. (steady thumb prssure should do it) Also make sure that the brake strike (white, plastic looking thing still inside the unit) and the clutch spring (you should have taken this off your old tranmission) are not pushing against each other when you slide your transmission shaft back in. If they are, simply rotate the clutch so that they aren't.
  • 246 Answers
We have not heard back on this in about a week. I'm presuming It's been repaired?
Posted on Jun 21, 2008
Need Help! Washer fills,aggitates and drains but doesn't start to spin,motor is running. What is odd is that if I unplug the washer and plug it back in,it will start spinning. What is causing this? ...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If it will drain but won't spin the problem is likely in the transmission. "Neutral Drain Assembly".
See the Whirlpool / Kenmore Service manual for top load direct drive washers.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
When ours had a similar problem, we looked at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) and noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 15Oz of gear oil (auto parts store) , remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Most likely the torque from the motor starting when you un-plug and re-plugging the washer is causing the cams to connect with the main spin gear allowing the washer to spin.
Jan 21, 2011 | Kenmore 22422 Top Load Washer
Kennmore top loader makes noise in spinning and adgating at same time
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the following Whirlpool Service manuals for top load, direct drive washers. They describe what happens in the transmission when the washer goes into spin mode:
Also see the Whirlpool Parts list for their Commercial washers, although the consumer models use the same transmission.
Basically whats happening is this.
When the washer goes into spin mode two plastic cams are forced together and raise a gear on the main agitator shaft that is supposed to keep the agitators from spinning. If the cams are worn (not necessarily broken) the gear doesn't lift high enough to completely disengage the agitators. We had the same problem. Ours was a major gear noise but a clicking could also be a symptom. A set of Whirlpool Agitate Cams (part number 62580/01) cost about $15.00.
It's a bit messy to fix (16 oz. of oil in the transmission) but very inexpensive.
See the following for how to remove the transmission.
The top agitator uses a plastic 1/2" drive bolt. A 1/2" socket extension works well.
You can also see this site for removing the transmission.
ILLUSTRATED DESCRIPTION OF REMOVING CABINET THRU TRANSMISSION.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 15 Oz of 80-90 weight gear oil. (Available at auto parts stores)
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
I'd also check the Motor Coupler (a $15.00 item that tends to wear) while you have the transmission out.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
Jan 06, 2011 | Kenmore 24032\24036 Top Load Washer
Won't disengage the aggitator
Jul 03, 2010 | Kenmore 24032\24036 Top Load Washer
Washer drains but wont spin
If it will drain (AND AGITATE) but won't spin the problem is likely in the transmission. "Neutral Drain Assembly".
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
May 13, 2010 | Washing Machines
Kenmore washer will fill with water and agitate but will not spin. The motor hums. I have replace motor, check capacitor, check lid switch and tank fill switch. all are ok. I am think it is the timer but...
If you it will drain but won't spin the problem is likely in the transmission. "Neutral Drain Assembly".
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
Feb 03, 2010 | Kenmore Washing Machines
Pump works, but tub won't spin
This is the Whirlpool PDF on installation and maintenance of direct drive washers.
If everything else works OK,, including the drain, and the timer moves, the problem could be in the transmission / gearcase.
If you lift the lid, put it down again and the washer begins to spin, or only the drain worksw the problem is likely in the transmission "Neutral Drain Assembly".
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again.
The Sears site for your washer may have a sub-component section on the gearcase with a part number for the Neutral Drain Assembly repair kit.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
With ours, all told, it cost less than $30 (including new 80-90 weight gear oil) vs. about $170 for a new transmission.
The job is a bit complicated and messy but not too difficult.
Dec 18, 2009 | Kenmore 22422 Top Load Washer
I have a KitchenAid topload washer. The spin cycle does not work, you can hear the pump and motor but it will not turn. What could be the problem? Is it belt driven or gear driven? Sherry
First, see the following to determine if you have a direct or belt drive washer
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=50&osCsid=7a980a8b05b84ff3b7ee1c8ba46e2ae8
Whirlpool makes Kenmore and Kitchen Aid.
If you have a direct drive washer, the following may help.
The Kenmore / Whirlpool /Kitchen Aid top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If the washer agitates fine, the pump will drain but the washer will not spin, the problem points to the transmission / gearcase.
If everything else works OK,, including the drain, and the timer moves, the problem could be in the transmission / gearcase "Neutral Drain Assembly".
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kitchenaid) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt. You don't have to remove the drum.
http://www.fixya.com/support/r699497-replacing_gearcase
OR
If the cam that should have a spring doesn't, or the others look damaged, the washer won't go into spin mode.
Oct 28, 2009 | KitchenAid Washing Machines
Washer does release water but when it is needs to start spinning it wont
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode. Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again. The Sears site for your washer may have a sub-component section on the gearcase with a part number for the Neutral Drain Assembly repair kit.
OR
Oct 10, 2009 | Washing Machines
My washing machine spins but does not aggitate what do i need to do?
Also see the Whirlpool / Kenmore installation and operations manual for top load direct drive washers.
Also look at the Whirlpool parts list for top load direct drive commercial washers (the consumer model is basically the same.)
The Whirlpool / Kenmore top load direct drive washer uses an agitate shaft from the transmission with splines on its' top that fit into slots in the agitator. If the slots in the agitator are damaged / worn, the washer may not agitate.
Remove the fabric softener dispenser, remove the top agitator cap (a short screwdriver works well), and you'll see a 1/2" square drive bolt. Use a 1/2" socket extension to remove the bolt, pull up on the top agitator and carefully turn it over. You should see four plastic "dogs" that allow the top agitator to turn one way only. If they are worn, they are easily replaced.
After removing the top agitator, you should see a bolt (I think it's 5/8").
Carefully remove the bolt and the rubber washer under it and the main agitator should come off. You'll see the top of the transmission agitator shaft with it's splines. Check them and the slots inside the main agitator.
If the splines on the transmission agitator and main agitator are OK, the washer spins and drains and the timer moves through its' cycle, the problem points to an agitate gear in the transmission itself.
See the parts PDF for the transmission.
Replacing the gear in the transmission is a bit complicated (and messy) but it's a lot less expensive than a $170 transmission.
If you decide that you want to work on the transmission (it's not really that hard) post another question on Fixya and I or someone else should be able to walk you through it.
Oct 09, 2009 | Kenmore 24032\24036 Top Load Washer
1991 Ford Ranger manual transmission remove
  1. Disconnect the negative battery cable.
  2. Remove the gearshift lever assembly from the control housing.
  3. Cover the opening in the control housing with a cloth to prevent dirt from falling into the unit.
  4. Raise the vehicle and support it safely.
  5. On 2WD vehicles, matchmark the driveshaft to the rear axle flange. Position a drain pan under the tailend of the transmission. Remove the driveshaft-to-rear axle flange fasteners and pull the driveshaft rearward to disconnect it from the transmission.
  6. Disconnect the clutch hydraulic line a the clutch housing. Plug the lines.
  7. Disconnect the speedometer from the transfer case/extension housing.
  8. Disconnect the starter motor, back-up lamp and, if equipped, neutral sensing switch harness connector.
  9. Place a wood block on a service jack and position the jack under the engine oil pan.
  10. On 4WD vehicles, remove the transfer case from the vehicle.
  11. Remove the starter motor.
  12. Position a transmission jack, under the transmission.
  13. Remove the transmission-to-engine retaining bolts and washers.
  14. Remove the nuts and bolts attaching the transmission mount and damper to the crossmember.
  15. Remove the nuts and bolts attaching the crossmember to the frame side rails and remove the crossmember.
  16. Lower the engine jack slightly to angle the transmission assembly. Work the clutch housing off the locating dowels and slide the clutch housing and the transmission rearward until the input shaft clears the clutch disc.
  17. Lower the transmission jack and remove the transmission from the vehicle.
To install:
  1. Check that the mating surfaces of the clutch housing, engine rear and dowel holes are free of burrs, dirt and paint.
  2. Place the transmission on the transmission jack. Position the transmission under the vehicle, then raise it into position. Align the input shaft splines with the clutch disc splines and work the transmission forward into the locating dowels.
  3. Install the transmission-to-engine retaining bolts and washers. Tighten the retaining bolts to specifications. Remove the transmission jack.
  4. Install the starter motor. Tighten the attaching nuts.
  5. Raise the engine and install the rear crossmember, insulator and damper and attaching nuts and bolts. Tighten and torque the bolts to specification.
  6. On 4WD vehicles, install the transfer case.
  7. On 2WD vehicles, insert the driveshaft into the transmission extension housing and install the center bearing attaching nuts, washers and lockwashers. Connect the driveshaft to the rear axle drive flange.
  8. Connect the starter motor, back-up lamp and, if equipped, neutral sensing switch connectors.
  9. Connect the hydraulic clutch line and bleed the system.
  10. Install the speedometer cable.
  11. Check and adjust the fluid level.
  12. Lower the vehicle.
  13. Install the gearshift lever assembly. Install the boot cover and bolts.
  14. Reconnect the negative battery cable.
  15. Check for proper shifting and operation of the transmission.
The above was pulled frrom:
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c152800391da
hope this helps
Jul 02, 2008 | 1991 Ford Ranger Supercab
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
306 people viewed this question
Dan Webster
Dan Webster
Sal De
