Question about Palm Vx Handheld
Can't reset trip meter on vx wagon. speed alarm and odometer works.what do you think i do?
Trip Meter not working.
Odometer and Trip Meter Stopped Working - AcuraZine Community
acurazine.com/forums/.../odometer-trip-meter-stopped-working-757772/
Dec 29, 2009 - The tech said he has seen the odometer & trip meter not workingbeing ... I have a 1997 TL and the same exact thing happened to me today. speedometer,trip and odometer not working
Aug 5, 2012
Cannot reset Trip A or Trip B on New 2012 MDX
Aug 1, 2012
Trip meter resets itself
Jul 25, 2012
Trip Computer Reset feature (with refuel) question..
Dec 19, 2009
More results from acurazine.com
Acura TL odometer trip meter not working Questions ... - Fixya
www.fixya.com/tags/odometer_trip_meter_not_working/cars/acura/tl
Dec 15, 2015 | 1997 Acura TL Series
How do I check the instrument cluster on a 1996 dodge Dakota?
i believe it has a vehicle speed sensor in the rear diff that is probably your problem as the sensor you replaced in the transmission was probably the output shaft speed sensor
Sep 18, 2014 | 1996 Dodge Dakota
Odometer quit working
I have a 96 Ford Explorer Sport and I noticed that the odometer and the Trip meter had stopped working. I pushed the Trip meter to 0 it out. When to town and I had not went even one mile. I had indeed went 22 miles. What caused it to stop?
Jan 01, 2014 | 1993 GMC Jimmy
I want to reset the 'regular service alarm light' on dashboardm of my 2006 Volvo S40
The service indicator can be reset as follows: Place the key in position 1, push and hold the trip odometer reset, the trip odometer will zero, turn the key to position 2 while continuing to hold the trip odometer reset. The odometer number will return to the previous value and the service indicator will be reset.
Oct 21, 2010 | Volvo S40 Cars & Trucks
1999 volvo s70 odometer not working
i would start with the speed sensor, have the computer scanned for codes that will help to pinpiont the problem,i would bet its the speed sensor, hope this helps.
Jan 16, 2010 | 1999 Volvo S70
How do I change out a non working odometer/trip meter?
This has been a problem with VOLVO especially the 850 models what happens is the plastic senssor inside the speedometer breaks off and it will tell you the road speed but ODOMETER AND TRIP METER will not work and the only way to fix it is to take the cluster out and sometimes it can be soldered back in place or get a used cluster and replace the unit sorry but it is not a simple fix
May 24, 2009 | 1995 Volvo 850
Odometer and trip meter do not work on 1990 dodge truck
OdometerGears.com has the replacement gears for you to repair your odometer. You need a E20= 20 tooth gear and a 16 tooth medium pod. The price is $54.00 for both including shipping.
Apr 01, 2009 | 1990 Dodge W150
Odometer/Trip Meter Not Owkring
it's most likely the cluster if one function works and the other doesn't. And, you likely have an electronic vehicle speed sensor that sends a signal to your analog cluster that then dispays your speed and odometer.
Jan 21, 2009 | 1991 Chevrolet Caprice
Palm Vx Handheld Logo
Top Palm Computers & Internet Experts
Ekse
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
