Question about Vulcan VR4 Electric Kitchen Range
Is this a single phase unit or 3 phase unit? - Vulcan VR4 Electric Kitchen Range
    New Friend:
    Problem Solver:
  • 7 Answers
Tell me what it says on the back of stove
Posted on Oct 24, 2010
SOURCE:
What type of circuit breaker do I need to use in my consumer unit for a Miele PW5065 washing machine
Feed the single phase power panel from the 3 phase panel and leave the single phase panel alone. You cannot run single phase motors on 3 phase power. Not for long at least . The motor will smoke in a short time.
Feb 02, 2016 | Miele Washing Machines
Replace compacitor on Carrier 5 ton 3 phase AC
Your 3 phase unit should not have a capacitor. I'm guessing it's single phase. If it's a single capacitor than the compressor should not be going to it also. To test the motor, common to start plus common to run should equal the ohms you get between start and run. For instance, 1.2 ohms+ 2.2 ohms= 3.4 ohms. Follow the wiring diagram on the inside of the door, send model number!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 29, 2017 | Carrier Heating & Cooling
Hi I purchase a 3 ton -3 phase condensing unit. Dayton model 1nxd4 for a friend house,after the instalation was finish the unit will not turn on. after installing the unit i found out that the unit was...
Three Phrase is usually only avail at a commercial
business
You would need a complete additional service to the house just for the AC
They would have to install a new transformer on the pole
I would suggest replacing the motor if that is the only issue,
to single phase 240 volt
May 23, 2011 | Heating & Cooling
Should there be (3) red wires feeding the rooftop condensor? Is there a pdf of the wiring diagram I can get?
If you're talking about the high voltage wiring, the answer could be yes if it is a 3 phase unit. That means you have 3 separate legs of "hot". Many rooftop units are 230v 3 phase in the US. Single phase would have two hot wires and a ground. Look in the disconnect box. If there are 3 fuses you have a 3 phase unit. If you have 2 fuses, you have a single phase unit. Be careful, you are dealing with very high voltage and very dangerous.
Apr 11, 2011 | Heating & Cooling
Have 3 phase mr slim 36000 unit single phase power can I buy a inverter to make work?
No, a 3 phase equipment cannot be used on single phase power supply.
Oct 02, 2010 | Heating & Cooling
I have a new water heater, and the hook up terminals are labled 1-2-3 are they hooked the same as in the panel 1-2-3 ?
No. You have to find out if you have 3 phase or single phase power. If this is a new unit you will find a wiring diagram inside the front cover. 3 phase power has 3 "hot" wires. Single phase has 2 "hot" wires. There is a big difference when you hook it up wrong. I don't know if this is a new installation or if you are replacing an old one. The terminals are numbered for 3 phase. If you look in your breaker box, 3 phase 208 will haven a breaker with 3 spaces hooked together by one bar. Single phase will have two spaces hooked together by a bar. So if the breaker kicks out it will flip all 3 space on 3 phase or 2 spaces on single phase. If you already have wires to the location of the booster heater, you may have to use single phase if that is all that is at that location. If you have single phase power you will have to look at the wiring diagram and you will see the terminal block represented for both single and 3 phase. Normally running from the terminal block will be six wires marked 1 through 6. The wireing diagram will say something like "for single phase put 1,3,5 on terminal 1 and 2,4,6 on terminal 3. Leave terminal 2 out all together. Of course at this point your 2 hot wires will go to terminal 1 and 3. There are other considerations as well. With 3 phase the circuit wires will be smaller gauge and may not carry the current you need for single phase. This is a booster heater. You need to hook up your hot water line to go into the heater and the boosted hot water to your appliance. It will not work to heat your water for other purposes. It is meant to take 140 degree water and boost it to 190 degrees. Good luck, hope this helps
Sep 11, 2010 | Hatco Corporation Compact Electric Booster...
I have a miller cp 300. It is wired for 3 phase power. I need to hook it up to 230 volt power. How do I do this correctly.
You cannot do this... 3 phase and single phase cannot be inter used... see 3 phase is 440 V AC, single phase is 230 Vots AC. This is unless the unit has Dual capability, in this case the wiring could only be wired to a Single Phase. of the unit. You will need a slow blow breaker of the correct rating and also the cable must be similarly CURRENT rated. If it IS only 3 phase, you can purchase after market single phase to 3 phase converters, that will allow you to plug the 3 phase into a single phase circuit and work, they quite costly though.
Mar 22, 2010 | Welding Tools
Can I change model 754 machine from three phase to single phase by just replaceing the three phase motors with single phase motors?
no you cannot. The cost to replace the dasher motor and compressor would be extreme. In addition, you would need to convert the controls from 3 phase controls over to single phase controls.
Those machines are designed for 3 phase power. If you could get the same components in a single phase version, you would spend more money economically than its worth.
Take the money you would spend converting and purchase a single phase countertop unit. They are made.
Feb 11, 2010 | Taylor 632-27 Ice Cream Maker
I have an 3phase roof top unit the owner was told it can run on 1phase wiring. is this true.
yes you can , but it would be cost prohibitive because the compressor would need to be changed out with a single phase unit( that is if they make a single phase unit this large) and anything else as in condenser/evaporator motors would also need change out if they are 3 phase motors, as for just wiring it to a single phase line, it can't be done
Nov 19, 2009 | Cell Phones
Voltage 1phase or 3 phase 240 volts BTUs M# 585epo36o75
Looking at the model number, it appears to be a 3 ton. (36,000 btu) Most all residential units are single phase and most all commercial are 3 phase. One way to tell, look to see if the compressor has a capacitor. 3 phase never use capacitors on the compressors as they are not needed. Some residential units have a "Dual" capacitor. That is, it has 3 terminals, 1 common, 1 for condenser fan motor, and 1 for the compressor. Also, this info should be printed on the unit's lable.
Good Luck and hope this helps.
May 09, 2009 | Amana Comfort Zone 12M32PBEH Air...
Vulcan VR4 Electric Kitchen Range Logo
88 people viewed this question
Top Vulcan Kitchen Ranges Experts
Treefrog15
Treefrog15
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Vulcan Kitchen Range Expert? Answer questions, earn points and help others
