Question about RTO Atwood DSI-RV Water Heater-6 Gallon
Where is the Elec heater element located on an Atwood G6A-9
  • RTO Master
  • 6,674 Answers
Back of water heater, under cover where electrical cable goes in.
Posted on Oct 24, 2010
SOURCE:
Need to add electric heating element and thermastate to g6a-6e gas water heater
I don't know how you can drill into aluminum tank and install element.
That seems a good way to ruin the heater.
Why not just buy small 'under counter' 1500 watt electric water heater at local box store and install in-line before the water reaches atwood gas heater.
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Otherwise I do not have a solution.
Don't blow yourself up by messing with gas appliance.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 16, 2013 | Water Heaters
Need to replace G6A-6E Atwood waterheater, what replacement model can I use?
Why not the same model/size? Atwood 6 gal, works on propane with electronic ignition. Or, you can get the 6 gallon with electronic ignition, and electric element as well provided you are willing to run hydro to water heater as well, if not already there. Check any RV parts site for prices and availability. Some places are out of stock currently. I assume your current tank is leaking?
Sep 29, 2012 | RTO Atwood Water Heater - 6 Gal LP
Where can I get a selinoid for a Atwood G6A-4E gas velve?
Open following link for Atwood water heater resources including parts list for different models:
http://waterheatertimer.org/Atwood-water-heater-resources.html
Following link shows ATWOOD Solenoid Gas Valve Type B - 93870
http://www.rvpartsoutlet.com/product_info.php?products_id=6268
Jun 04, 2011 | RTO Atwood Water Heater - 6 Gal LP
I have an Atwood water heater model G6A-8E. When
If this model has a thremo couple you might want to check it. It sounds like that is the problem.
Jun 07, 2010 | RTO Atwood Water Heater - 6 Gal LP
Have an G6A-8E Atwood water heater. It Starts fine and shuts down after a couple of seconds. I can see the diode in the control board continue to spark after ignition I replaced the igniter.
If it has the little thermal cut-off in power wire to thermostat (has a little plastic jacket over it) try removing it, and connect female spade from power wire, directly to male spade on thermostat, and see what happens. Also, make sure electrode is positioned in flame good for flame sensing properly.
May 21, 2010 | RTO Atwood Water Heater - 6 Gal LP
RTO Atwood DSI-RV Water Heater-6 Gallon Logo
118 people viewed this question
Top RTO Water Heaters Experts
Donni Steen
Mike
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
