Question about Koss Audio Players & Recorders
Koss dvd player stuck in ntsc/pal mode
How do i get it back in tv mode
SOURCE: Oritron dvd 3119 player
You have to blindly instruct the NTSC/PAL menu item, which toggles between NTSC and PAL;
This is how it is done:
1) turn your dvd player off.
2) Turn it back on and make sure there is no DVD in the player tray.
This will ensure the menus are active
3) Using the remote, press the dowm menu selector key exactly three times
4) press the center menu select key once.
This will activate the display adjustement menu
5) press the down menu key exactly once.
This will activate the NTSC/PAL menu
6) press the center menu key
DONE.
The player should now have switched back to NTCS if it was in PAL.
IF it was in NTSC it should have switched back to PAL.
Note: If you still have the manual you can follow the menu tree blindly using the instructions in the manual. The above sequence is for activating the NTSC/PAL menu.
This player can also switch to progressive scan, which creates a similar problem. At least the progressive scan menu has enough warnings before it will actvate.
Posted on Sep 22, 2008
  • 13 Answers
SOURCE: Cyberhome 300 DVD Player: pal to ntsc mode?
You might want to reset to factory defaults, but there is an error in the manual. In order to reset to factory defaults, turn on (with no disc inside), DO NOT OPEN THE DISC TRAY, just press the stop button on the player for 5 seconds.
Posted on Oct 27, 2008
  • 124 Answers
SOURCE: koss dvd player kd 305
Make sure you dont have a disk in the tray. Hit the Pal.ntsv button 2-3 times. You will get the picture back. If not, then you also hit the p.scan button. Hit that button 2-3 times till you get the picture back.
Posted on Nov 10, 2008
TBlessed 1
  • 61 Answers
SOURCE: koss ks4102 pal/ntsc output
try to unplug the system for about 20min to see if it will reset the system
Posted on Dec 01, 2008
SOURCE: how do you change the DVD player mode from PAL to NTSC ?
I just found the way to change the setting from PAL to NTSC.
While the unit is turned off , press the EZ View button on the remote control. Press alternatively the select between the PAL or NTSC setting on the unit display. That's it.
Posted on Apr 01, 2009
DVD will not play in color, what am I doing wrong
Hi, are you using a UK pal tv? Chances are you are watching a US region 1 dvd which is encoded in NTSC. This will play in 525 lines and black and white on a UK PAL tv. Does your DVD player have an NTSC playback to PAL tv swich? It would simply be labeled "PAL" and "NTSC" If not on the back then possibly in the menu. If you have the switch select NTSC and try again.
Hope this helps
Steve at Olive Country Computers in Spain
Mar 04, 2011 | Durabrand DVD-1002 DVD Player
Koss dvd player kd 305
Nov 10, 2008 | Televison & Video
Lost video output
You might have changed you settings for video type, PAL or NTSC or the letter box or 4:3 or 16:9 etc..
any way if your player contains a battery to retain settings unplug your player and remove the battery
if it doesnt have a battery unplug for 24 hrs,
you shold look at your remote for a button labeled P/N or N/P or ntsc/pal or pal/ntsc, or something close to that,
just press the button
if that dont work you can remove the batter and unplug for 24 hrs or if it dont have a battery just unplug for 24 hrs
IF THOSE DONT WROK POST YOUR PLAYER BRAND and MODEL i can advise you further then
Jan 02, 2008 | Koss KS4110 DVD Player
PAL mode ?
PAL/NTSC is automatic. if you insert a PAL DVD output is PAL ( most probably PAL-B. Some other brands allow manual PAL/NTSC switching, but at this machine this is automaticaly done. Please verify your TV set allows PAL programs
Oct 27, 2007 | Sony DVP-NS50P DVD Player
KS3102 Koss DVD player hookup to Toshiba how??
I have an owner's manual for that system and would be glad to copy the diagrams for you. Additionally, I think that you need red, blue and green wires from the back of the Koss to the inputs on the TV.
Oct 02, 2007 | Koss KS3102 System
PLAYING DVD
check your connections on the back of the tv and back of the dvd player. make sure you are using the proper conections on the back of the tv. if you connect the RCA (composite) cables (red yellow white) you should be going from the red yellow white on the tv to the red yellow white on the dvd player. if you have the component(red blue green) connection on the dvd connected to the red yellow white on the tv, you may get a black and white picture. If this does not work, check the manual for the dvd player and see if there is a way to turn "Progressive Scan" features off, some older TV's cannot handle a progressive scan dvd player.
Aug 13, 2007 | Koss KS2503 System
Koss KS5190 Display mode stuck
I'm not ranked and I'm not a Guru, but I can solve this picture rolling when the problem is "the video was accidently changed from NTSC to PAL and you can't see what your doing to get it back". You will need the remote control unit. First, remove the disc from the tray. Now, turn the unit off with the power button. The tray will close by itself. After the display on the front of the unit goes out, turn the unit back on using the remote control. This will let you know the remote control unit is working. When the power comes back on and the display on the front of the DVD player says, "NO DISC", with the remote control and (very important) while pointing the remote at the player, (Remember to point the remote before pressing any buttons) press the "Down Arrow" button 3 times. This will take you to the "Display" box. Now, press the "Right Arrow" button 1 time. This will take you to the "TV Image"box. Now, press the "Down Arrow" 1 time, this will take you to the "PAL/NTSC" box. If you have done everything as I have tried to clearly lead you blindly to your destination. Press the "OK" button 1 time and the picture on the screen will stop rolling and change from black & white to color. You will have now changed your video output from PAL to NTSC. If you press "OK" again, it will start to roll again. If this did not take care of your problem, turn the player off and try it again.
The previous problem solvers were on the right track, but the track was rough and they just about derailed the train. Thanks to them, I had a track to follow. I had no other information, except what I found on "Fixya.com". MR. CD
Feb 03, 2007 | Koss KS5190 System
Pal/Ntsc playing problem
is your tv is the same tv that u playing before? coz according to you if u play ntsc there is no problem. if ur tv is multisystem, u can change the tv system menu to auto, but if not u cannot watch coz ntsc tv only accepts ntsc signal.
Jan 08, 2007 | Pioneer DV-373 DVD Player
Sony Mobile DVD MV-7101 Display is Black and White
Try pressing the arrow up on your monitor while it is on the PAL mode. This is what I just tried on my systema and it switched from PAL to NTSC.
Jan 07, 2007 | Sony MV-7101DS Car DVD Player
49 people viewed this question
Top Koss Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Steven Wander
Steven Wander
Steve K
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
