Question about Bernina Virtuosa 160
Needle hits the plate
I have a Janome machine, brand new, and the needle won't go in the whole anymore. It keeps hitting the plate on the back of the whole. I know how to put the needle in and I have changed it a few times to see if it wasn't a faulty needle. But nothing changes. I happenned after I did a backward straight stich and it won't work anymore. Help!
  • 323 Answers
Remove your needle plate, clean around it, turn the handwheel to see if the hook will catch your thread(Like you are trying to bring up the bobbin thread). If it catches okay, put the plate back on and as you tighten the screw push the plate towards the rear of the machine. Reassemble everything, rethread , insert a bobbin and try it by turning the handwheel again. If it still hits, you need a service. If it doesn't, have fun!!
ssewman7
Posted on Jun 10, 2008
Janome 6600. Needle came loose &fell down into the bobbin area. Needle did not break off. I took off the plate and manually tried to move a new needle and shaft up/down. needle is hitting something
If you did not get the old needle out, it may be blocking something. That old needle must be removed before you attempt to any further sewing. Try removing the bobbin case from the machine and looking in there to see if you can locate and remove the old needle. Sometimes, I've had to turn the machine sideways or upside down and shake it to dislodge the needle.
Open the bobbin area and hand rotate the handwheel while watching the needle action. If it is hitting, you should see it. If that is the case, the machine may be out of time and need service.
Jul 11, 2017 | Janome Sewing Machines
How do I adjust the bar that holds the needle? I ran over straight pins and now the needle keeps hitting the plate
If you are not using a brand new needle, install one now. If there are still issues, the machine has been knocked out of time (happens when hitting pins!).
Search for sewing machine timing or take it for service.
Feb 25, 2017 | Sewing Machines
What size needle is used on janome model 672
Janome makes sewing machine needles. However, many machine brands recommend using their own brand needles (ie Singer recommends only their needles and I have encountered issues using Singer needles with non-Singer machines). Sometimes, machine-brand needles are higher priced. More expensive does not guarantee better quality. However, unbelievably inexpensive off-brand needles may not be a good thing.
PRODUCT REVIEW JANOME SEWING MACHINE NEEDLES
Janome needles will most likely work fine on your machine, however, most modern sewing machines accept the standard 705/130 needle. Beware, though, that some brands of 705/130 needles have slight variations that may cause problems. If in doubt, consult your Janome dealer or an experienced Janome user. It may come down to experimentation on your own. Don't be surprised that a brand recommended may work better than others. Because a sewist is a staunch advocate of a particular brand, does not mean it will work best for your machine. It's just the nature of the beast because every machine and every needle has slight variations. Purchasing a single package of brand needles and trying them first would be a good idea. If the needle doesn't seem to work, you can try another brand until you find one you like. When experimenting with a different needle, start out sewing slowly (or hand rotating the wheel) in case there is a problem with the needle, you may avoid broken needles.
I've found several brands that work fine on my machines (not Janome machines) and seem to work for most sewists, ie Schmetz, Organ, Klasse, even Kenmore. It's probably best to avoid lesser known brands or bargain bin needles. Fabric stores, like JoAnn's carry Schmetz and if you use coupons, you can frequently buy them at a great price, sometimes 50%.
sewing patternreview com
How to Choose Sewing Needles Looking at Types Sizes Lifespan
Along with choosing the needle for your machine, you need to consider the thread and fabric you will be using. Choosing the correct needle is very important for your sewing success, ie use a ball point needle for knits, a leather needle for heavy fabrics/thread, a sharp/microtex for fine wovens, embroidery for applique & embroidery, top stitch for larger threads & heavier fabric, etc.
All About Needles
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwjixZv7tYfOAhVEYiYKHZRIAGEQFggkMAE&url=http%3A%2F%2Fwww.schmetzneedles.com%2Flearning%2Fpdf%2Fschmetz-needle-chart.pdf&usg=AFQjCNHTR52AmqwzvyCjbXmD5Ch52Va5_Q
And, above all, install a brand new needle frequently, ie whenever beginning a new project. A bent/dull/damaged needle will cause all kinds of frustration, including failing to pick up the bobbin thread, skipped stitches, or even hitting/damaging the presser foot, needle plate, or hook. A flying piece of needle is not a pleasant experience--and dangerous (wear eye protection)!
Jul 22, 2016 | Janome Sewing Machines
When I have the walking foot on the needle hits on the back of the foot.Janome 4800 memory craft
Is it a Janome brand walking foot? some generic feet and other brands don't fit the older Janomes.
Feb 12, 2015 | Janome Memory Craft 10000
My needle keeps hitting the metal plate, and its a brand new needle. It seems like the alignment of my brand new machine is off. Basically, the needle keeps hitting the metal plate where the bobbin is, and...
Check whether the needle is installed correctly - maybe it's turned around from machines you are used to. Also verify that the needle plate is installed correctly, not upside down (may be possible on some machines). If the needle and plate are installed correctly, then something is out of line, and you're owed a free adjustment or repair from the manufacturer.
Feb 10, 2015 | Sewing Machines
Needle breaking
it's very possible that when the needle hit the hoop that it caused the needle bar to jump time
I would suggest that the machine be taken to a sewing machine shop to be checked to see for sure if it is the timing or something else since the needle is also hitting the throat plate
May 29, 2012 | Sewing Machines
My Singer 6160's needle is hitting the bobbin plate.
first change the needle--flat side to the back of the machine, make sure the needle is inserted all the way up into the needle holder
make sure it's the correct needle for the machine
if the needle keeps hitting the bobbin plate then the machine may be out of time & would have to be take to a sewing machine shop for retiming.
May 03, 2012 | Singer Sewing Machines
Sewing Machines Logo
195 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
