Question about MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
Looking for a diagram for the GWF67V MotorGuide for our Pastor. It hasn't been used for some time and it looks like problem is down in motor but need diagram to be sure.
4 Suggested Answers
SOURCE:
sparktgo
  • 68 Answers
SOURCE: I'm looking for a manual for Motorguide- Laser
standard motorguide manual
http://sites.mercurymarine.com/pls/portal/docs/PAGE/MOTORGUIDE/MOTORGUIDE%20SUPPORT/ONLINE_MANUALS/MANUAL_CONTENT/MM6900%20-%202004%20-%20OWNER%27S%20MANUAL_0.PDF
Posted on Oct 12, 2009
  • 553 Answers
SOURCE: motorguide model ht24 looking for wiring diagram to rewire switch
If the insulation is burnt off the main wiring you have a severe short. DO NOT TRY TO USE. Unless your a qualified electrician or motor repair tech, take it to one to have it repaired or by a new one.
Posted on Jun 12, 2010
SOURCE: Wire going to prop of Motorguide trolling motor shorted
Unless you are mechanically inclined, dont attempt this. Take the lower unit apart by removing the prop and removing the two bolts that hold the forward and aft housing to the center housing. Fwd being the cone shaped part. Pull the aft housing away from the motor so you can inspect the connections to the board that holds the brushes and the soldered wiring terminals. You should find the solder missing from at least one of the terminals that connects the wiring from the foot switch to the speed control windings inside the aft housing. Clean up the terminal and wiring and re-solder. Also re-flow the solder on the other terminals. Clean up the seals and the area where the seals meet the housing parts. Replace seals if damaged. Reassemble the lower unit and torque the bolts 45-50 in-lbs and no more otherwise you will fail the seals. This problem is due to a "cold" solder joint that creates a high resistance to elec current flow and heats enough to melt the solder. This is a result of poor quality control at the manufacturer. Good luck.
Posted on Dec 29, 2011
Replaceing mower deck belt on countax C600H NEED DIAGRAM
Me too, if anyone knows where this is one, in the meantime will look to see if standard diagram for all machines.
Aug 05, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
I have a motorguide fw71 fb bow-mounted trolling motor which I believe is receiving a short somewhere. I have the batteries hooked up right with a 30amp breaker going to each and often when I troll on...
Using an ammeter check for current draw and compare that with specs to determine if your draw is excessive. If motor has ever overheated and some of the windings have had the insulation burn off you will have a motor with less resistance and it will draw more current since less back emf is being generated.. Under those circumstances it can overheat and also blow existing fuses. Should that be the case you are looking at shopping for a new motor.
Apr 18, 2017 | MotorGuide FW71 FB Freshwater Series...
Need a relay for a MotorGuide Stealth 200 troll motor - part VF4-899F11
I have a Motorguide Stealth 200B trolling motor, works perfect but getting a new boat with a new motor. Trolling motor has original manual and paperwork with it, as well as 4 blade Ninja prop and prop wrench. Has some cosmetic scratches on motor. looking for $25.00
Feb 12, 2011 | MotorGuide Standard Motor Replacement...
Motorguide model ht24 looking for wiring diagram to rewire switch
Jun 11, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
Can you change a motorguide 65lb thrust foot control model with fix speed settings to a variable speed
well a "Speed Controller" can usually be used on ANY DC/AC motor, depending on type, some motors just will not work, with a speed controller... Think of it a bit like a "Light Dimmer", with the "Bulb" being the "Motor"
Have a look below for info. www.stefanv.com/electronics/escprimer.html
Mar 05, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
Aug 11, 2009 | MotorGuide Electrical Supplies
Replaced Motorguide Trolling motor switch ... same problem
Trolling motor runs on it's own when plugged in,speed adjuster won't control speed and 3 position switch doesn't perform either..please help. motorguide 74lb thrust.
Jan 14, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
51 people viewed this question
Top MotorGuide Electrical Supplies Experts
jdthefixer
Sheldon Dedek
Mike
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
