Is there a workaround for "Black Ink Cartridge expired" message on a HP businessjet printer
  • 428 Answers
Pls there is simply no work around for expiry of ink cartridges. You just must get a replacement. Once it expires it continues to behave like an incompatible cartridge.
God bless!
Posted on Oct 23, 2010
SOURCE:
I bought a black ink for my hp photosmart c5 180 and the when i turn on the printer it says the ink has expired. Can i still use it or will i damage my printer. Thanks regards Anita
Hello
according to HP
Each ink cartridge has an expiration date. The purpose of expiration is to protect the printing system and to ensure ink quality. When you receive an ink cartridge(s) are expired message, remove and replace the expired ink cartridge, and then close the message. You can also continue printing without replacing the ink cartridge, by following the instructions on the HP All-in-One or the ink cartridge expiration message on your computer screen. HP recommends replacing the expired ink cartridges. HP cannot guarantee the quality or reliability of expired ink cartridges. Device service or repairs required as a result of using expired ink will not be covered under warranty.
You can get more detail from here
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00819032&dlc=en&product=1153481
Hope this helps, if so do rate the solution
Dec 31, 2010 | HP Photosmart C5180 All-In-One InkJet...
I have all my color cartrage expired and only installed the black one. Can i print?
Yes, you may print with only black.
it will give a message that : Ink Cartridges Empty -
simply click on: Black Only button.
then you will be able print in black only.
Jan 21, 2010 | HP Photosmart 3210 Printer
Error message on HP 2800 business inkjet, message reads 1% ink left on brand new cartridge
View the user manual here. http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00449611/c00449611.pdf
go to page 60 and follow the instructions for replacing the ink cartridge, remember to have the printer on when you do.
Then go to page 62 and allign the print head automaticly following the instructions it gives.
This will re-callibrate the ink level on the printer and should read correctly for you.
Thanks
CompuFirm
May 27, 2009 | HP Business InkJet 2800 Printer
"Expired color cartridge" message blocks black printing - nothing works
Hello merelU. I'm afraid you may have to replace the empty color cartridge as there may be problems with the printer while an expired cartridge is installed on the printer (even though some of the cartridges are still under warranty) and also, HP cannot guarantee the quality or reliability of expired ink cartridges.
all the best.
thx
Oct 07, 2008 | HP Photosmart 3310 Printer
Officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Aug 07, 2008 | HP OfficeJet D135 All-In-One InkJet...
Refilled ink cartridges
The reason why the printer says supply expired because the ink cartridge has its own warranty. When the warranty of the ink cartridge has expired then you will get that message. Eventhough you refill it. You need to replace the ink cartridge itself.
Aug 04, 2008 | HP OfficeJet D125xi InkJet Printer
Hp printer 7110
hi,
Try to remove the black ink cartridge. From there, you can check the expiry date of the Ink cartridge. If its already expired, then you need to use another black ink cartridge that is not yet expired.
Thank you so much.
adonscott
Jun 18, 2008 | HP OfficeJet 7110 All-In-One Thermal...
Expired ink cartridge
You may be getting this error message due to the printer being able to tell that it is a non-hp cartridge. I don't know how it can tell, but mine says that too. I uninstalled the software and then reinstalled the software. And then I took out the cartridge and put it back in. See if this works for you.
Apr 07, 2008 | HP OfficeJet d145 InkJet Printer
My Hp PSC 1350v
Hi, I really appericate all your efforts to fix the issue the issue usually occures if any one of the cartridge is defective or low in ink or both the cartridge are defective. We can isolate the issue only by removing the both the cartridges out of the printer and check for the expiry dates printed on the cartridges as if the cartridges are expired also leads to this message. If the cartridge are not expired and have minumial ink in it you can try the below procedure to isolate the defective cartridge Once the both the cartridges are out of the printer insert only the black cartridge in the printer and check for the message if the message is install color cartridge the black cartridge and printer is detecting fine. If the message is check right cartridge this shows that the black cartridge is defective. If the message is insert left cartridge or color cartridge remove the black cartridge out and insert only the color cartridge and check with the message if the message is insert the black cartridge the color cartridge is working fine. And when the color cartridge is in the printer and if the message prompts to check left or color cartridge the color cartridge seems to be defective so replace the defective one will fix the issue So in isolation we can find the defective cartridge and fix the issue by replacing the defective one.. Hope this will help you to fix the issue.. Wish you success. Regards, Barret.
Sep 12, 2007 | HP PSC 1350 All-In-One Thermal Printer
Hp Officejet 7110 Not Printing From Computer
HP 7110 Printer
The problem with the printer is it does not work, there are flashing lights and the message it gives you is to turn the power on and turn it back on. Needless to say when I reboot the system and unplug the printer and plug it back up, I get the same message, does anyone have any solutions to this problem????
Sep 07, 2007 | HP OfficeJet 7110 All-In-One Thermal...
Open Questions:
WEBROOT TechnICal SupPoRt pHone ~II+[[18OO8-O31O69}} NumbEr u.sa//vs Usa WEBROOT USA phone number is ranked #2 out of 2 because 7,728 WEBROOT USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the WEBROOT USA Technical Support department for problems like Where to buy, Complaint, Technical support, Repairs, Returns. As far as we can tell, WEBROOT USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. WEBROOT USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact WEBROOT USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling WEBROOT USA Calling WEBROOT USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from WEBROOT USA Technical Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with WEBROOT USA's Technical Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare WEBROOT USA's phone numbers against each other. Contacting WEBROOT USA in General While I8OO8O31O69 is WEBROOT USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach WEBROOT USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact WEBROOT USA.
Oct 17, 2019 | Webroot Computers & Internet
Computers & Internet Logo
67 people viewed this question
Ekse
Alun Cox
