Question about Home Security
I have a 2011 Honda Pilot. HomeLink works intermittently. I changed battery and reprogrammed and still same program. Any advice?
4 Suggested Answers
SOURCE:
  • 3197 Answers
SOURCE: 2006 Honda Accord Garage door Homelink Program with Chamberlain
useful info.
Posted on Sep 14, 2009
swolfinor
  • 504 Answers
SOURCE: Garage door opener remote won't work
look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
HOPE THIS HELPS
Posted on May 29, 2010
  • 3197 Answers
SOURCE: Our Craftsman garage door remotes
Most likely logic board.
Posted on Aug 09, 2011
Why won't it start?
Honda Pilot 2005 won't start dead starter - YouTube
? 2:48
https://www.youtube.com/watch?v=tH2rEYLbQrY
Sep 15, 2011 - Uploaded by Alexey Gavrilov
Honda Pilot 2005 won't start dead starter ... How To Replace a Starter 2006 Honda Odyssey -EricTheCarGuy ...
Today my Pilot won't start! - Honda Pilot - Honda Pilot Forums
www.piloteers.org > ... > General > Problems
Mar 13, 2011 - A half-hour later, I got in to move it back, and the Pilot would not start. All the .... Most original batterys from 2005 need to be replaced by now. Starting Problem 2005 EX
Feb 24, 2011
Cold Weather (0 deg F) 06 Pilot won't start after jump - Honda ...
Jan 17, 2009
Engine won't start - clicking sounds and guage flutter - Honda ...
Dec 23, 2007
Starting Problems
Mar 24, 2006
More results from www.piloteers.org
Thread: '05 EXL won't start - HondaSUV.com Forums
Jan 01, 2016 | 2005 Honda Pilot
I don't have the owner's manual for my 2002 GMC Yukon XL Denali. Do you know how to program the garage door opener?
I hope this helps.
Programming the HomeLink Transmitter
Do not use the HomeLink Transmitter with any garage
door opener that does not have the stop and reverse
feature. This includes any garage door opener model
manufactured before April 1, 1982.
Be sure that people and objects are clear of the garage
door you are programming.
It is recommended that a new battery be installed in
your hand-held transmitter for quicker and more
accurate transmission of the radio frequency.
Your vehicle's engine should be turned off while
programming the transmitter. Follow these steps to
program up to three channels:
1. Decide which one of the three channels (one of the
HomeLink buttons) you want to program.
2. Press and hold the desired button on HomeLink
through Step 3.
3. When the HomeLink indicator light begins to blink
slowly (this may take up to 30 seconds), hold the
hand-held transmitter about 1 to 3 inches (3 to 8 cm)
away from HomeLink and then press and hold the
transmit button on the hand-held transmitter.
Continue to hold both buttons until the indicator
light on HomeLink begins to flash rapidly (this may
take up to 90 seconds).
If you have trouble programming HomeLink, make
sure that you have followed the directions exactly as
described and that the battery in the hand-held
transmitter is not weak. If you still cannot program it,
move the hand-held transmitter to the left or right or
forward or backward or flip it upside down. HomeLink
may not work with older garage door openers that do
not meet current Federal Consumer Safety Standards.
If you cannot program the transmitter after repeated
attempts, refer to "Training a Garage Door Opener with
Rolling Codes" later in this section or contact the
manufacturer of HomeLink at 1-800-355-3515,
or on the internet at www.homelink.com.
Be sure to keep the original hand-held transmitter in
case you need to erase and reprogram HomeLink.
Training a Garage Door Opener with a
"Rolling Code" Feature (If Equipped)
If you have not previously programmed the hand-held
transmitter to HomeLink, see "Programming the
HomeLink Transmitter" listed previously. If you have
completed this programming already, you now need to
train the garage door opener motor head unit to
recognize HomeLink.
1. Find the "Learn" or "Smartbutton" on the garage
door opener motor head unit. The exact location and
color will vary by garage door opener brand. If you
have difficulty finding the Learn or Smart button,
refer to your garage door opener owner's manual or
contact the manufacturer of HomeLink at
1-800-355-3515, or on the internet at
www.homelink.com.
Because of the steps involved, it may be helpful
to have another person assist in programming
the transmitter.
2. Press the Learn or Smart button on the garage
door opener motor head unit. An indicator light will
begin to flash when the motor head unit enters the
training mode.
Following this step, you have 30 seconds to
start Step 3.
3. Return to HomeLink in your vehicle and firmly
press and release the programmed HomeLink button
three times.
The rolling-code garage door opener should now
recognize HomeLink. You may either use HomeLink
or the hand-held transmitter to open the garage door.
If after following these instructions, you still have
problems training the garage door opener, contact the
www.gmcextendedwarranty.com
Dec 19, 2010 | GMC Yukon XL Cars & Trucks
2003 honda pilot, remote control doesn't work even with new battery , light on remote control doesn't blink
did the light blink when it worked? It may need to b reprogrammed. check the owners manual, it should tell you how to program. If the fob is dead, check ebay for a new one, usually 50 bucks and the reprogram
Dec 06, 2009 | 2003 Honda Pilot
How do I program my garage door opener in my 2006 Pilot?
GOTO HOMELINK.COM
THEY MAKE THE SYSTEM AND HAVE INSTRUCTIONS YOU CAN DOWNLOAD.
PLEASE NOTE: NOT ALL BRANDS/MODELS OF OPENER WILL WORK WITH THIS SYSTEM.
HOPE THIS HELPS
Sep 22, 2009 | 2006 Honda Pilot
GARAGE CONTROL SYSTEM
Try holding the hand held remote up next to the homelink (built in remote). Hold down the botton on the hand held remote and the botton you want to program in the car at the same time until the homelink light goes out. This could take 60 seconds or more. Now depending on which model garage door open and how old it is you may need to program the car to the opener. Usually this is done by pushing the botton on the back(Liftmaster,Sears, Chamberlin) or the botton on the front(Genie) and then go to the car and push the same botton on more time. I hope this helps.
Feb 05, 2009 | 2005 Honda Pilot
Honda Pilot 2005 garage door programming
Hi,welcome . Homelink has a website and phone number for programing help contact.
HomeLink at 800-355-3515 or visit their
website at www.homelink.com. they have a very good support system to hep you with problems.
Nov 13, 2008 | 2005 Honda Pilot
Open Questions:
Why Sliding Doors different from Hinge Door Wardrobes? If you are thinking about wardrobes there are two types of wardrobes hinge doors & sliding doors. Over the centuries of use, hinge doors have done well when it comes to giving a simple system for storing and protecting your valuables from the elements. These days doors are available across a large variety, based on material, color, style, finish etc. In this article, understanding their difference between hinged wardrobe doors vs. sliding wardrobe doors. If you would like to speak to a leading Noida based wardrobe company call Vara Designs and Decors to ask questions or book a in-home design and quote. For Hinged Doors - Improved visibility When you open the doors you get the entire view of the wardrobe. Hinged doors do not dissemble one side of the wardrobe as alike sliding door. More Hanging Space You can hang your accessories like sling bags, scarves or belts on the back of the doors with hinged doors. Color & Finish Options Actually swing doors have been in the market for a long time, these wardrobes come in different styles and colors. According your requirement and budget, you can get any wardrobe door design or color. You can choose metal-framed shutters with glass panels. If you have a small bedroom, you will need to plan the position of your wardrobe such that the doors do not prevent movement. For Sliding Doors - If you want to choose a sliding door, sliding doors work and look best when you have at least three or more doors. Extensive Length of Sliding Doors Sliding door wardrobes support large spaces that can house a lengthy wardrobe. The intrigue of these wardrobes lies in having room for a lot of things like garments, beauty care products, and accessories, etc. Besides, they save space as sliding doors don't impede the traffic stream in the room. Sleek Design of Sliding Wardrobe You have the luxury of designing your wardrobe as you wish depending on the texture or color. Mirror sliding doors can give you both style and functionality in one simple package. Space-saving Sliding Wardrobes Sliding wardrobes are perfect for minimized rooms since they are basically space-saving. While this restricts the perspective on the clothes in the wardrobe, it likewise streamliness space for small rooms. Vara Designs and Decors provides best sliding wardrobe designer in Noida, Delhi NCR. We provides interior design, modular kitchen, woods design & wardrobe etc. at best price. Call: +91 ********** & Email: [email protected] for more information here.
Oct 03, 2019 | The Home Security
Home Security Logo
304 people viewed this question
Top Home Security Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
