Question about Bernina Artista 180
Repeated message: "Please Check the Upper Thread."
I use my Bernina 180 daily. Two days ago, it started a new problem. I'm getting the "Please check the upper thread" message repeatedly. When I pull the thread out and rethread it, it will sew for about 20", then starts giving me the message again. I have taken the end cap off and have pulled some tiny threads out of the bobbin area. I don't see any loose threads in the upper area but have aired it all out. I am trying to see what is going on so have no thread in it, yet it still stops.
A 2nd problem that started a year ago: I use invisible thread a lot--now the thread repeatedly breaks. It worked fine in the past. I have tried a number of different brands--I don't think it is a brand issue. The only way I can get it to work at all is to loosen the tension all the way and then it just barely works.
Any ideas? Thanks.
  • Annblasdel Jun 20, 2008
    You're right--I have since figured out that it is related to a sensor in the tension area (thanks to an engineering cousin who came to visit). A service person advised that I could turn off the beeper. It has sewn fine ever since but I will have it checked next time I have to take my machine in. Thanks!
  • 323 Answers
The machine stops because the sensor near the check spring(in the tension area) tells it the thread is broken or not there.. You can try to clean it out again but it's probably going to have to go in for service.
sewman7
Posted on Jun 19, 2008
I have Bernia 180. The bottom thread is puckering. Top thread is perfect. I cannot find help in manual. Please help
Check that the bobbin is inserted turning the proper direction in the bobbin case and that the thread is threaded correctly through the tension control on the bobbin case.
Make sure the upper thread is threaded correctly. The factory standard upper tension setting is midway between high & lower number although this may need to be tweaked for your particular machine.
If the machine is still pulling the bobbin thread too tight, you can try tightening the upper thread tension. If it still isn't resolved, you may need to loosen the bobbin tension.
You might also want to check the presser foot pressure on your machine. That generally needs adjustment when changing from thicker to thinner fabric and vice versa.
Manual: BERNINA artista 180 Support BERNINA
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Understanding Thread Tension Threads
How can properly adjust my tension
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Oct 02, 2016 | Bernina Sewing Machines
Will not sew continuestly when im embrodering when i press the reverse button
It is completely normal for a Bernina 180 and other Bernina models to stitch just a few stitches and stop after first pushing the reversing button. The reason for this is so you can cut off the extra piece of top thread so it does not get caught up in the embroidery design. After you cut off that extra piece of thread, press the reversing button (hold it in till the machine starts) then it will continue with the design. Assuming you do not have a problem (a message would come up on the screen) or you are out of bobbin thread, the machine will continue to embroider till either the design is finished or it stops because you need to change the upper thread to the next color. Each time you start to embroider it will stitch about 3 or so stitched and stop. Cut off the extra thread and press the reversing button again to continue.
If this is not the problem you are having then you need to describe your problem better, in more detail.
This should help! Bill
May 26, 2015 | Bernina Artista 180
Thread bernina embroidery bobbin
The thread sensor eye is probably dirty.
Dec 26, 2017 | Bernina Sewing Machines
Error message says please check upper thread. I do that and then it stops after a few stitches. Please Help. Carolyn
Hi
Likely there is thread or lint caught in the "flag" on the upper check spring or there is a broken thread caught in the take up levers
Most of the time the front cover has to be removed to get to the problem
contact me if you cannot get this resolved
sewaway@shaw.ca
Wayne Buss
Apr 14, 2010 | Bernina Artista 180
Bernina Deco 650 Check if upper or lower thread is cut shows on
turn machine off and on to see if message clears... not sure for that machine ( I work with Brother products) but if it has a wiper (small hook shaped blade) that trims the tread automatically it may be stuck in the extended position
Apr 08, 2010 | Bernina Bernette Deco 600
Bernina artista 180 keeps warning to check top thread and it is threaded right
Refer to your manual for maintenance and clean the machine as indicated. A sensor may be blocked by lint.
If this continues, the machine will need to be serviced by an authorized Bernina repair tech.
Mar 25, 2010 | Bernina Artista 180
Have the artista 180 and the thread keeps
Hi, possibly you have put the bobbin in upside down. Try flipping it over in the bobbincase and see what happens. It should turn clockwise when looking at the bobbin and pulling the thread.Check that your upper tension is not too loose. Check that it is threaded correctly.
Hope this helps.
Rick
Oct 07, 2009 | Bernina Artista 180
Bernina 180 Artista sewing machine
you may have to replace the upper thread sensor
Apr 22, 2009 | Bernina Artista 180
"check top thread" warning, but top thread is threaded correctly
The upper thread sensor may be bad or need cleaning off but this doesn't happen very often. What does happen is that the thread regulating spring (the spring that the thread goes through just before going up to the take up lever) has come out of a small grooved piece it fits through. By taking the side cover off you should be able to see this and possibly be able to pop it back in. A tiny amount of super glue can keep it from happening again.
Nov 07, 2008 | Bernina Artista 180
Sewing Machines Logo
478 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
