Question about RCA 27V514T 27" TV
Beautiful picture,no sound - RCA 27V514T 27" TV
    Top Expert:
  • RCA Master
  • 76,140 Answers
Hello
If your TV displays good picture and there is no sound output from it, please connect an earphone or headphone to its headphone/earphone socket, if provided, and check whether the sound output comes from it or not. If there is sound output from the headphone socket, and not heard from the speaker of your TV, the speaker inside your TV may got damaged. Check the speaker of your TV. For that you have to open the TV. Unscrew it and go for the same type and number and replace it. There is an other possibility, that is if your TVs headphone socket itself can got damged. You can make sure it by after checking your speaker. If the speaker is alright; the socket is faulty. Replace it with same type.
An other fault can occur is Audio Output Ic failure. If it has damaged, you won't get sound output either from speaker or from the headphone socket. You can make sure about it. Keep your ear very close to the speaker side of your TV, switch on the power to TV. If there is a "Thumb" soud is heard, you can make sure that your TVs speaker is Ok, and if there is a "Hum' sound also comes from it, Output Ic is damaged.
If so you have to open your TVs back cover and locate the Audio Output Ic. It can be located by following its speaker wire. The speaker wire goes to Output Ic. Usually it may be screwed into a metal heatsink. Desolder it out of the board, and go for the same type and number. Replacing it will solve the problem.
All the precautions must be taken before opening your TVs back cover. Plug it out from the wall socket bfore doing this. Keep chldren away from you, and not let them even stand beside you. Let an adult be there beside you as a precationary measure.
Read and understand well the above said solutions and go on.
Wish you sucess.
Posted on Oct 24, 2010
SOURCE:
The picture went black...has sound....bulbs gone?...lamp? Thx
Seems to be the inverter board that controls the bulbs! With the TV on if you shine a torch at the screen can you see a faint picture? If so it is the inverter board that needs replacing!
Jan 04, 2015 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubichi VS 45609. When I turn the TV on sometimes it comes on and has beautiful picture and sound. Then after 1/2 or so it goes to a black screen. While on the black screen I am able to PIP it and see...
I have the same TV and what is happing is the TV has 2 recievers in it to allow the PIP, So you have a power pack gone on 1 reciever the other is working, Your set has 2 power packs,1 for each receiver.
I had both of mine go, 150$ a piece to have fixed, good luck.
Mar 07, 2011 | Mitsubishi VS-45609 TV
I HAVE A BEAUTIFUL COBY TV (TFTV3225). PICTURE IS BEAUTIFUL-SOUND IS AWFUL (SOUNDS FLAT, CANNED, NO STEREO OR SURROUND SOUND EFFECT.) PLEASE ADVISE BEFORE I RETURN THIS BRAND NEW TV.
Howdy, If you want good sound from a Coby TV you need external speakers. Coby is one of the lowest end producers of televisions and are notorious for poor sound. Good news is that for what you saved by buying a coby, you are still ahead after buying external speakers and amp (often called home theater system, some have built in DVD player). That's the scoop on Coby. hope this helps some.
Regards, Farmerbear
Aug 31, 2010 | Televison & Video
No sound
called someone else. thanks but no thanks for the paid solution.
Mar 30, 2009 | Audiovox AVT1498 TV
NO SOUND
Use Extneral Audio Jacks to a stereo for sound or replace audio output ic.
Feb 11, 2009 | RCA HD50LPW164 50" Rear Projection HDTV
No sound beautiful picture
check color code cables be sure all cable match up with the right inputs red to red and white to white rca or HDMI will same you alot of problems but sure that your tv have HDMI outputs
Feb 04, 2009 | Hitachi 61SWX10B 61" Rear Projection...
No sound
i have a 52 inch rca ,picture but no sound
Dec 26, 2008 | Televison & Video
Sound no picture
Try resoldering the vertical output IC this is acommon problem with this model
Mar 20, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Brand new TV and it has a beautiful picture but no sound any suggestions?
S-video does NOT carry audio.
You'll have to get some RCA audio cable and connect them to the audio in ports associated with the S-Video input.
Nov 21, 2007 | Olevia LT32HVM 32 in. LCD Television
PLTV-32 good picture, no sound
if you still have a problem (and the tv!) email me at gmail.com
Jan 23, 2007 | Protron PLTV-32 Television
RCA 27V514T 27" TV Logo
85 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
