Question about Sanyo Televison & Video
I need to set-up my one for all remote for a sanyo tv. i need the tv code
    Top Expert:
  • Sanyo Master
  • 76,140 Answers
Hello
You just try one amoung the following four digit numbers
{ 0049 0097 0110 0004 0268 0012 0108 0180 }
Proceedings
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Posted on Oct 24, 2010
6ya staff
SOURCE:
Can you give me the codes for a sanyo tv for a universal remote
try this link...4 digit GE codes for TV sets including LCD, Plasma, and Panel TVs Brand Code SANSUI SANTECA SANYO SCOTCH 224 more rows
4 digit codes for TV sets including LCD, Plasma, and Panel TVs - GE ...
www.eliztech.com/remotes/ge-4digit-tv-codes.php codes for sanyo tv for universal remote Google Search
Dec 09, 2016 | Sanyo Televison & Video
What remote codes do we need to connect remote to Sanyo TV model 3264B 2008.
Mary, Universal remote codes for Sanyo TV model 3264B Check the attached links,instruction and guides containing 3 and/or 4 digit codes, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://codesforuniversalremotes.com/universal-remote-control-codes-sanyo-tvs
How to Set Up the Codes for Sanyo Television and Remote
4 digit codes for TV sets including LCD Plasma and Panel TVs GE universal...
Apr 26, 2016 | Sanyo Televison & Video
Need remote codes for sanyo tv
press the helpful button Step 1 Insert two AA batteries into the universal remote control if you haven't already done so and then turn on your Sanyo TV. Press and hold the "TV" button on the remote until it lights up.
Step 2 Input the following three-digit codes into your remote control one by one using the remote keypad: "004," "013," "049," "108," "110," "180" and "209." The TV will turn off when you enter the correct code for your particular Sanyo model.
Step 3 Press the "TV" button on the remote once more to confirm the code after you've identified the correct one. You can now use the universal remote to control your Sanyo TV.
http://www.remotecodelist.com/remotes/sanyo/sanyo_rmtu100.html
Jan 27, 2016 | Sanyo Televison & Video
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Jan 09, 2012 | Sanyo 42 in. LCD TV
RCA remote codes lost
Codes For Model RCR311B
Code 1004 for Sanyo TV Code 1048 for Sanyo TV Code 1049 for Sanyo TV Code 1073 for Sanyo TV Code 1080 for Sanyo TV Code 1162 for Sanyo TV Code 1169 for Sanyo TV Code 1180 for Sanyo TV
Codes found here: http://remotefinder.rca.com/default.aspx?site=rca
RCR311B manual (PDF): http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr311-manual.zip&area=other
May 26, 2009 | RCA RCR311B Remote Control
Need codes for a Sanyo TV
0049, 0097, 0110, 0004, 0268, 0012, 0108, 0180
Jul 29, 2008 | GE RM24912 Universal Remote Control
Help plz
here is the codes for
your remote and that
tv
Sanyo tv code 0154 0159 all for one remote code
Mar 02, 2008 | One For All URC4220 Remote Control
Sanyo tv codes
The codes listed by Sanyo for my TV won't work in my star Choice remote.
I tried 017 021 039 056 057 058 and 140 as listed by Sanyo.
Any ideas?
Dec 18, 2007 | GE JASRM24912 Remote Control
Need code for sanyo tv
Welcome to FixYa.
SANYO TV Codes: 0154, 0159
Please be informed that the codes vary with different make and model of the universal remote that you have. If none of the codes above work, please post back with make and model of your universal remote included.
Thank you for using FixYa.
Jas247
Sep 01, 2007 | Sanyo DS31590 31" TV
Televison & Video Logo
173 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
