Question about Frigidaire Refrigerators
It is not cooling. The temperture setting will not stay at original setting of 33 degrees
  • 1,891 Answers
It may only need to be cleaned . ck the coil under neat and the fan that cools the coil . / clean it and if fan is not going replace it . mm
Posted on Oct 24, 2010
SOURCE:
I need to know the right temperture settings cause i dont have a manual
dont try to lower cool setting below 70 degrees or heat setting above 78 degrees. all a/c's are designed for a 95 degree ambient when it gets above that you have to increase tonnage to compensate.
Jul 30, 2015 | Heating & Cooling
In the cooling mode for zone 1, why won't the temperature stay as set on the cool setting?
If it 2 degree cooler then that's fine .adjust your thermostat 2 degrees higher so you will get the temperature
Feb 16, 2018 | Carrier Heating & Cooling
Set thermostat at 74 heat pump will not cycle it will cycle at 75 degrees ?
check stat calibration. see if you can measure temperture at stat. the thermostat cover temperture reading is not that accurate.
Jun 01, 2014 | Goodman CLQ36AR49 Air Conditioner
My 2007 Chevy HHR 2.2L, coolant temp sensor is reading that the coolant temp is 20 degrees warmer than the outside temp after sitting for over 12 hours and the operating temp gets to 214 degrees without...
Sure the engine coolant will be warmer than the outside temperture and if the car has been sitting a long time in cold weather and the outside temperture warms up it could be the other way around. The coolant temperture sensers aren't real accurate as they are a relaitive senser beween hot and cold and the numbers reported don't have to be real just the change from hot to cold and the reching of the coolant to the operating temperture. Noe it the senser doesn't read the opertating temperture coprrectly you'll have all kinds of problems. The therostaste will try to set the temperture of the water to it's set temperture and can open or close completly to get 195 degrees F. Many times if it's too cold then the stat is bad and needs to be replaced This shows up in alot of cars first thing after winter and the first onset of cold weather when the daily tempertures vary the most from day to night.
May 06, 2011 | 2007 Chevrolet HHR Special Edition
Hot water temperture will not go over 33 degrees
Check your water heater thermostat on you water heater tank, look for a small removable panel, remove the insulation and then you should expose the thermostat of the water heater
Readjust the thermostat to the desired temperture just be sure not to set to high to cause problems with small children.
Apr 11, 2011 | Home
How do i set my temperture on my air conditioner its stays at 78 and doesnt seem cool in my house
sounds like you could be low on charge,If you set you thermostat @ 78 degrees it should stay within 2 degrees of that and not have more then a 6-8 min cycle every 20 min.
Jul 15, 2009 | Heating & Cooling
It doesn't cool properly
it the freezer froze up?if so its a defrost proublem
May 04, 2009 | Frigidaire PLRU1777DS Stainless Steel...
Frig does not stay cold enough
you are either low on coolant or the fan inside the freezer compartment is stuck or defective.
Mar 25, 2009 | Kenmore 55203 Side by Side Refrigerator
The refrigerator is not staying cold
Check it's cealing of the door. Depends if it's cooling and then not staying cold, means door is not cealed or frequency of opening too much. More possibility is gas leakage.
Mar 04, 2009 | Frigidaire FRS26ZSG
TOW FANS AGAINST THE RADIATOR, TOYOTA CAMRY 2001 4 CYL
yes, they are both radiator fan. dependent on the temperture of the outside air and the cooling temperure on control panel. the fan will kick on when the temperture cross over the preset- set on the computer. so, either fan on, no fan, fan is runing when the car is runing or not, is not a porblem.
the porblem occures when the fan stops, and the temperture is over 100 degree outside.
Nov 11, 2008 | Compaq Presario 1626 Cooling Fan Case...
Refrigerators Logo
66 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Thomas F. Schneider
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
