Question about Vintage Keeper Koolspace chillR Cooling Unit
Koolspace wine cooler
I have a code "AL" which is showing up on the unit and the unit isn't cooling. What does "AL"mean and what do I do about it?
Ole
  • MarkyD Jun 27, 2008
    Same thing happened to me just the other day. Vintage Keeper web-site suggests unscrewing the controler (the little box with the "Set" and up and down arrows on it) and check the plugs on the back. Unplug and plug back in everything and test. My "AL" went away. Unit doesn't cool though. Coolant leak I think.
I have the Vintage Keeper Odyssey. I had the same thing the other day. Unit is 7 years old. Vintage Keeper web-site suggested to unscrew the control box and remove. (The box with the "Set" and Up and Down arrows. Unplug the wiring and sensor on the back and then plug back in. Plug in the unit and text. It took my "AL" away.
Unit doesn't cool very well. A coolant leak may be my problem. I was looking for solutions other than buying a new refrigeration unit.
Posted on Jun 27, 2008
This probably means something is wrong with your unit. Try to unplug it for a few hours and replug it and see if that will make the "AL" go away <a rel='nofollow' href="http://volwinecellars.net">wine cellar cooling units</a> Good luck!
Posted on Jun 14, 2012
I am on my second KoolSpace Chillr300 in less than 5 years. Unfortunatley the units are not reliable or well built. My neighbor just purchased one and the compressor failed in less than a week.
Posted on Sep 09, 2010
Apprentice,
thanks for the information. I had already done this and it shows up again. I'm going to take the unit into my local HVAC dealer and have it checked out. I'm thinking it's probably needing a recharge.
Posted on Jun 09, 2008
This means alarm. Unplug the unit and plug it in again. The unit will not go into alarm on replug for a number of hours even if the unit goes over 70 degrees. your room must have exceeded that temperature for some reason and triggered the alarm feature which shuts the unit off as a precaution. Check your insulation and operating conditions and make changes or just see if it works after a replug.
Posted on Jun 08, 2008
Pressure for wine cooler
used the wrong freon firstly it should be r 22 r137a is for automobiles/trucks only
Aug 28, 2016 | Vintage Keeper Koolspace Wine Cellar
How to tell the year of a koolspace wine cooler
That will always depend on the Manufacture of your Koolspace Wine Cooler. If Koolspace keeps record's they will ask you for your serial number. It does appear you have an eliete model and brand name so I would think they are well ahead of the game.
Fax: 403-283-6111
Calgary Phone: (403) 283-7575
Toll-Free: (877) 283-7575
Design/Construction Inquiry: Click Here
Wine Cellar Services Inquiry: Click Here
Accounting Inquiry: Click Here
Cellar Coordinator Inquiry: Click Here
Gallery
If you have warranty issues with your cooling unit (ChillR or Vintage Keeper Nuvo), please contact the manufacturer directly at www.wineracking.com or 1-888-274-8813
We have set up our Calgary space to introduce you to the most stylish and sensible storage and lifestyle accessories for the discerning wine-enthusiast.
Please feel free to drop by our showroom at any time during regular business hours. If you prefer we can arrange practically any time that is convenient for you.
10:00 am - 5:00 pm : Mon - Fri
Saturdays by appointment only
If this was a Whirlpool question I could find it myself with model and serial If helpful please rate this solution, Thank You, Sea Beeze
Nov 24, 2011 | Refrigerators
My wine cooler is not reaching the set temperature. It stops at around 73 and the display flashed AL. Any ideas?
check to see if compressor cycles, if so you may have a thermistor problem which is intergrated with control, replace if you can find part. make sure to check evaporator, see if ice is forming if so you have a leak,or dry evap. you have a leak. repar.
hope this helps.
Aug 14, 2010 | Vintage Keeper Koolspace Wine Cellar
I have a Koolspace AA6 Tuscany free standing unit. Sn 05314-11. Power went out cooling unit will not restart. I get the thermostat to read and fan to turn for a while then goes into high temp alarm mode.
It seems like this cooling unit (AA6, also Grand Cru 800) just doesn't last as per numerous postings that I found when I was trying to find a replacement unit. Best advise seems to be get a higher output unit that will fit application.
May 14, 2010 | Vintage Keeper Koolspace Wine Cellar
Koolspace NUVO wine cooler recharge
do you have a recovery machine and gauges you need to tap both sides to check the high to and it needs to be vaccumed down to remove moisture ,find and fix the leak. leaks arnt verry common un less someone broke a line somehow. if the compressor is running it is more likley it has a restriction or bad valve in compressor, hooking to high and low sides will determine which if is less than 5 years old it could be under warrant still most sealed systems have a longer warranty than the rest of it is the evaperator getting cold at all.
Dec 31, 2009 | Vintage Keeper Koolspace Wine Cellar
My Vintagekeeper Tuscany 220 wine fridge is making lots of unnecessary noise.
Hello, this is a common problem when parts start to wear in the motor. They rattle and clang allover the place, depending on age of fridge you can get the motor replaced and regassed. Or depending on age it may be time to replace the fridge. I hope this is of some use.
Nov 04, 2009 | Vintage Keeper Koolspace chillR Cooling...
Koolspace 600 Problem
You'll need to replace the fan. The original fan bearings wear our after a couple of years. It's pretty simple to drill out the rivets and replace the fan. I suggest you replace all four with ball-bearing fan units.
Sep 19, 2008 | Vintage Keeper Koolspace Wine Cellar
My Koolspace cooler in my VK250 wine fridge quit cooling
I have the same problem with mine and have tried the same things as you have. I took my unit to a air conditioner service place and they said these units are not worth fixing. It would cost about $150 to add a valve so they refill the gas and then try to find out why it is leaking. I am about to order another one which makes me vary mad. My unit is 1.5 years old.
Apr 09, 2008 | Vintage Keeper chillR 300 Wine Cooler
Furniture Logo
1,867 people viewed this question
Top Vintage Keeper Furniture Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Oloyede Monsuru
Are you a Vintage Keeper Furniture Expert? Answer questions, earn points and help others
