Question about Sanyo HT27546 TV
"finishing digital channel search" does not clear from screen. How does one get it to go away.
We have an antenna, digital converter box, and digital tv. Can only get 5 channels. No nbc, abc, cbs. Get the message indicator available for digital broadcasting only
You should be able to use the box remote and select channel search mode. As it searches, you will see it "hit" available channels and store them. When channel search is finished, you should see a picture displayed. if no results, there is something wrong with the antenna, the way it is connected to the box, the way the box is connected to the TV, or the way the TV is connected to the box. You may have to reread the instructions to find what is at fault.
Sep 05, 2015 | Televison & Video
Mitsubishi wd 52628 input issue, blue screen and input error
there are no analog channels, they are all digital now, be sure your antenna is facing proper direction before scanning for digital channels
Apr 20, 2013 | Mitsubishi WD-52628 52" Projection HDTV
Hdlcd19wb series a - How do I get the channels in digital, rather than analog? I can't even click on the "dtv signal" option in the menu. All the channels listed to add or delete are analog.
Put the HDLCD19WB on a channel. Press menu on remote. Select channel on the sceen. Press enter on remote. Select auto channel memory on the screen. Press enter on the remote. Use the right arrow button on the remote to set the signal type to air for antenna or cable. Select automatic search on the screen. Press enter on the remote. Wait for search to finish. Check channels with the channel up and down buttons on the remote.
If you have any digital channels you should have them now.
The dtv signal option in the channel menu is only available when tv is tuned to a digital channel.
Jan 01, 2011 | Sansui HDLCD-1900 19 in. LCD Television
I have a Sanyo DP26746 TV. I pushed the reset button in error and am unable to get to any other screen. It wants to look for HD channels. Since I only use a satellite service it can't find any. Help! I...
First of all make sure all the leads are connected to the TV.
Press the reset button on the remote twice (this will clear all previous settings) and perform a channel search and create new ones.
Now you will need to perform an all channel search.
Press the Menu key to display the main menu.
Use the cursor up/down keys on the remote and select "All Channel Search" and press enter. Use the cursor key to select yes and press enter.
Now you may need to perform a digital cable search to pick up your satelite digital signal.
Press the tuner key on the remote and then the menu key.
Use the cursor key to select Digital cable search and press enter.
Now the TV should scan for a digital signal
Good luck and kind regards.
Jun 25, 2010 | Televison & Video
LG LCD TV 37LP1D digital freeview tuning problems
Hi - I have the same problem. Also in Cornwall LG were not interested in helping because the TV was 3 1/2 years old. There was a possible fix in the end offered via LG at a cost of £180 + vat - a hardware update that might or might not work but I was not going to pay that so I now watch my LG 42 plasma via a £25 digi box from the CO OP. LG must have sold 1000's of these Tv's so when the digital switch starts in the more populated areas of the country I exect many more web postings.
Oct 31, 2009 | Televison & Video
Can not tune the tv
My dear friend. A TV is a TV and TV's are many and varied. If you stated the model and what it exactly does, maybe I or other people could help you instantly. But since you have said little in relation to TV tuning, then expect a few guys to help you. But allow me to give you a hint that applies to almost all flat panel TV's, ok? Right. On every TV there is a MENU that gives you many options. First you need to press a button on the remote that displays component connection channels and TVincoming signal type. Since I don't know what brand of flat panel TV you have, I can only ask you to find and press the button on the remote that displays on TV screen the following component channels, that is DVT, AVT, Component 1, Component 2, HDTV1, HDTV 2, HDTV 3 and so on. Apart from DTV and ATV, from Component 1 to HDTV 3, these additional channels are for DVD players that also have HDTV outputs and BlueRay players and or Audio devices. If yout TV hasn't got as many channel input, then ignore this part. To tune your TV you have to first press the butoon on the remote to activate the onscreen channel as above, then scroll on DTV or ATV and, depending on whether you have Digital TV in your country or the standard high resolution Analog TV. Lets say you have Digital NTSC format TV system, select it and then press ENTER on your remote. In the menu you find and click SCAN. Depending on where you are, the TV will begin scanning all frequencies in your territory and possible interstates if the modulator is powerful enough to pick up weak signals. Most TV's have an inbuilt set-top box that boost the signal to give you a crystal clear pic. Now, after pressing SCAN, the TV reaches a signal with a clear pic, all you have to do is recognise the channel that comes in view. The instructions on how to save that channel are on screen and then you can configure it as, say channel 4, if the channel that appeared is channel 4, if not, try and recognise what channel had appeared and then configure it with a number, so when you press that number on the remote it will be the same channel you had stored in the TV memory. After you have done this, press scan again and it will scan to the next channel. Once the scanning recognises another clear signal and it is as clear as a baby's face, you have recognised the new channel. Try, find out what channel it is by looking at the screen, there is usually a visible TV station name or number embossed on the lower corner of the screen, once you know what station that is or what channel number it is, configure that number and press ENTER (save) button. Do the same with the remaining channels. Later I will tell you how to skip unwanted blank channels that usually have no signals but snow and lines, or have faint signals that can only be boosted with a TV booster available from reputable TV retailers, or install a bigger more powerful antenna.
Reagards.
Mike
Oct 06, 2009 | Televison & Video
DTV1300A Sansui is not dtv ready, Am I doing something wrong?
To put your digital channels into the memory of the DTV1300 or 1900 press the MENU/ENTER button. Go to CH SETUP. Press the VOL + button. Go to TV CABLE. Use VOL+ button to set to TV for antenna or CABLE for cable without a cable box. Go to AUTO CH MEMORY. Press the VOL+ button. Wait for the search screen to go away after the analog and digital searches finish on their own. Check ALL your channels with the CH up button. I hope this helps you.
Mar 14, 2009 | Sansui DTV1300 TV
I have a durabrand 1907a and cant' get digitalchannels, please advise how I can get all digital channels? thank you duraproblem
Go into the CH SET menu. Go to the TV CABLE line. Set it to TV for antenna reception or CABLE for cable without a cable box. Go to AUTO CH MEMORY. Press the VOL + button to start the channel search. WAIT until search screen goes away. Check ALL your channels. Hope this helps.
Feb 17, 2009 | Durabrand DU1901 TV
Channel seach
if your tv is rotary or digital.if rotary you search manually the channel .first set the channel you want then press and hold the fine tuning manually counter clockwise to get some good reception.second the digital tv you may press the menu and choose the auto search ,then wait until searching will be finish.
Jan 11, 2009 | Televison & Video
Digital tuner
Try this!
The manual states the TV is designed to search for channels.
turn the power on
then hit menu
(if it doesn't start searching for channels)
then hit channel up -let it run a complete channel search
hit menu again
hit channel up- let it run a second channel search
hit menu again after it finishes it's 2nd search cycle
if it doesn't go to a channel, hit the input button.
it worked for me!
hope it helps
Dec 08, 2007 | Sanyo Vizon LCD-15A2 Television
Sanyo HT27546 TV Logo
51 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
