Question about Toshiba Satelite 5205-S505 Notebook
Toshiba laptop running win xp was fine. Now suddenly has black and white lines on boot up,never goes to regular screen. I'm trying to figure out the prob in safe mode but no luck. help?
  • Brad Brown Oct 23, 2010
    What version of windows?
    What version of antivirus?
    What was the last thing that you installled
  • dance4surviv Oct 23, 2010
    win xp..Norton antivirus...I ran the virus scan in safe mode didn't come up with anything....I did download what I thought was a boot up help file for another computer right b4 it started acting up....but I can't find the file to delete and can't figure out what exactly went wrong...
  • 356 Answers
Could be on-board issue. no fix for this but mobo replacement. e-mail me and i will try to diagnose. [email protected]
Posted on May 17, 2015
6ya staff
SOURCE:
Anonymous
  • 136 Answers
SOURCE: Toshiba satellite laptop keeps restarting
Is the fan working? It might be overheating.
Or one of the drivers is corrupt, and crashing the computer. The only way to solve that is by remotely (by means of starting from CD with a mobile OS).
Posted on Nov 02, 2008
Anonymous
  • 61 Answers
SOURCE: how to install win xp in toshiba portage r200 laptop
This is resolved by installing Intel Storage Manager drivers through "F6" option on XP Setup. YOU MUST HAVE AN EXTERNAL FLOPPY DISK (A Drive)...as the Portege doesn't come with one...and XP does not support USB or CD ROM for this particular function.
Posted on Mar 18, 2009
SteveRand
Steve Rand
  • 210 Answers
SOURCE: Black screen w/blinking cursor
So.. you can select safe mode? Or you turn it on and it is resuming into the blank screen?
If the latter. Unplug the power, pull the battery out for 20 seconds or so. Then put it all back together and try booting up.
Posted on Apr 20, 2009
Anonymous
  • 9 Answers
SOURCE: blinking white dash during boot.
Something has messed with your MBR, master boot record, which is a small sector at the beginning of your first hard drive which tells the bios which partition to boot. You'll have to use your xp or vista's installation disc to repair the system.( Choose; repair this installation of windows when prompted )
While you are in the bios check under the boot section the order of your boot devices. If you have more than 1 HD check that the one containing your OS is first.
Posted on May 08, 2009
Anonymous
  • 18 Answers
SOURCE: My Toshiba A200 laptop keeps freezing up about 1-5
I think you antiwirus has damaged the system files and you should just re instal the opperating system
Posted on Nov 18, 2009
Toshiba L10 centrino boot problems
well try to use hiren boot v15.2.
and run mini win xp...or just reinstall your OS.
Regards,
Jovan.
Apr 16, 2014 | Toshiba Satellite Computers & Internet
I have a Toshiba laptop with a Windows 7 operating system AND A BLACK SCREEN WITH AN ARROW(curser) ON IT
Try running the check disk utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 21, 2012 | Toshiba Computers & Internet
I have a gateway laptop that won't boot up. Only
try checking out to see if maybe you have a bad memory inside first. then if thats not the problem im gonna have to figure your hard drive might be going bad because of corrupt files and fragments.
May 27, 2011 | Gateway Laptop with Intel Centrino...
Laptop won't reboot
are you trying to put win 10 on as it can do this some time, can take upto 10 15 min to load, when the like is flashing its dos, when the screen is black its windows it takes some time for windows to find a driver and load it so the screen comes up. i've had this on a200's before. if you keep rebooting you will need to wipe the hard drive and start again. this also does this on win 7 and 8. win xp it does not do this as its full dos setup .
Jun 30, 2017 | Toshiba Satellite Pro A200-EZ2204X...
Laptop Screen goes blank
Are you running on battery or AC? Try using the power cord, remove the battery and see if it continues. I have seen a battery that is on its last legs do some weird things to a computer. Also, check your power management setting. Control panel, power, and set the computer to "always on" just to see if it could be a power management setting. If none of this works, i would back up all your files, and try to reload win xp from scratch.
Jun 23, 2009 | HP Compaq nc6320 Notebook
My PSAF3u-0nR00V willnot boot it is a sudden and recent problem
Easiest thing to do is to try and boot into safe mode with command prompt and then run a repair.
Here's a guide.
Jun 13, 2009 | Toshiba Satellite A205-S5804 Notebook
Dell latitude d600 screen goes black during boot
ok after you have booted in safe mode do a restore to a date just before the last day it worked properly and try that restore is found here
start/programs/accessories/system tools/system restore
hope this helps
Mar 15, 2009 | Dell Latitude D600 Notebook
Display has gone bad with fine vertical pink lines
Connect an external monitor to your laptop, if you get a clear image on this monitor the the video card in the laptop is OK.
The fault could be a defective inverter that supplies high voltage to the CCFL lamp or a faulty CCFL lamp. Most likely a faulty CCFL lamp.
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) as reached the end of the life and all you need to do is replacing the CCFL lamp
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 06, 2009 | Toshiba Satellite 5205-S703 Notebook
Toshiba a75 s-206 problems helppppppppppppppp
Sounds like a bad hard drive to me. Take out the hard drive completely from the laptop and boot up with the windows xp cd and it should go past the blinking cursor. At that point you know you'll need another hard drive.
Mar 06, 2009 | Toshiba Satellite A75-S206 Notebook
My Toshiba Satellite A215-S7413 laptop randomly goes to a blue screen with lots of white writing on it. I never have time to read it because it goes away so quickly. After the screen goes away it restarts...
Try going to Start - Run.
Type sfc /scannow in the run line and hit enter or click ok.
A dialog will pop up that says "Windows File Protection"
Allow this to run and insert the Win XP CD if requested.
Hopefully this will resolve your issue!
Jul 14, 2008 | Toshiba Computers & Internet
Toshiba Satelite 5205-S505 Notebook Logo
78 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
