Question about Canon IMAGERUNNER 6570 Copier
Paper Jam Hi, I have a Canon Imagerunner 1370F model & I have a paper jam that I'm trying to fix. I have removed the ink cartridge & took out the paper that was jammed in it and found out that there is some left over paper jammed in the "front roller" part that I can see on the outside under the tray but I don't know how to get to it. Any suggestions please?
  • litfammed Oct 03, 2008
    Paper jam left sided output rollers - ImageRunner 1330 can not see how to get into to pull it out.
  • baby doctor Feb 17, 2009
    There is paper stuck in the roller towards the center of the copier that I am unable to get out. Any suggestions would be appreciated.
  • 318 Answers
Did you open the smaal door on the lower left to try to remove it from there.Or is it stucked in the fixing area.
Posted on Oct 30, 2008
My copier was working just perfect.(canon ir 1270f)...and had a paper jam..removed and now its shows error code toner/drum crg..what could possibly the problem...please help me out with this
hello
remove the paper jam and close the front cover and unplug the power from the outlet and same at the back of the printer, wait for 5 minutes and plug it again. this will helps to clear the error code of the printer.
thank you
Mar 08, 2011 | Canon imageRUNNER 1370F All-In-One Laser...
Paper jam problem
Hello... i have a copier IR6570. If i load the paper from tray 1, it always jammed. But if i load from other trays, everything goes well. Can anyone help me, please...?.
Jul 20, 2010 | Canon imageRUNNER 1370F Grayscale Copier
I have a paper jam and it says to open the front cover, put the front cover just shows the ink cartridges and there is no visible paper jam. how do i find the jam and remove it? It's a canon image...
The paper jam could be in three places.
First:
Open the cover of fixing section, its above bypass, and check for jamed paper
Second:
Open the transfer cover, these cover has handle and it goes by pulling toward you, and check for jamed paper.
Third:
In hight of first paper cassette, on left sideway of copier, beaneath the bypass are small door, open it and check for paper jams. Be sure that you closed them properly because if they arent closed the check printer cover message will arrise.
Hope that helped
Jul 07, 2010 | Canon ImageRunner 1600 Copier
How to fix paper jammed error of canon mp145
Please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 11, 2009 | Canon PIXMA MP150 All-In-One InkJet...
My canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
alternative :
Jun 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Paper stuck
the printer may show a paper jam message and still have none. Check out the sensors, sometimes they stay activated, even when they seemed to be ok. I highly recommend you to clean up your copier with pressurized air. be aware of the following sensors: pre-Registry (open the lower back door/cover and there it is), bypass (right in front of the multipurpouse tray), registry (remove the cartridge, under the metal flag that can be moved back and forth) and fixing (on the left side, where the papers get hot)... good luck!!
if you dont have the pressurized air try a blower or sometihng like that. if have have none of those then you are gonna have to find the way to remove anything that could be blocking the sensors.
Jan 28, 2009 | Canon imageRUNNER 1370F All-In-One Laser...
Paper jam
Hi usually paper jam at paper input area a or transfor section(photo drum area or fuser unit area, so you may try:
1) take out paper tray and open the cover that you can change toner cartridge there (see manual) looking for any paper inside paper input area or around the cartridge, then take out jam paper.
2) open fuser unit at paper output area ckick a locker at somewhere (see maanual) looking for any paper jam
Dec 22, 2008 | Canon imageRUNNER 1310 Printer
My cannon super 63 image runner 1370f
look on the control panel if there is a diagram of your printer it will usually light up the area where the paper jam is located.
once you find location of paper jam there is normally a green knob in the area of jam that when you manually rotate it will release paper also open paper drawer check for jam or unplug and plug copier back in somtimes this will force paper out as it resets
Jan 13, 2008 | Canon IMAGERUNNER 6570 Copier
CANNON SUPER 63 IMAGE RUNNER 1370F PAPER JAM
It is hard to tell where the paper is with out seeing it or looking at the jam log. start by looking for green. On canon green is for jam removel if you see a green tab lift it, if you see a green knob turn it. good luck
Jan 12, 2008 | Canon IMAGERUNNER 6570 Copier
214 people viewed this question
old marine
old marine
Corne Viljoen
