Question about Nikon D200 Digital Camera with 18-200mm Lens
Triangle symbol by f-stop.. Cannot change f-stop
Frigidaire triangle symbol
Good Morning Jon, this is Z. Thank you for allowing me to assist you!
I see that your post is listed under Frigidaire freezers. Please help me understand if the question you are asking is related to the "UP" and "DOWN" arrows that are designed to change the temperature setting? If you are speaking about another triangle symbol, I will need your model number please. The serial tag, which lists your model number, is normally located inside the cabinet, on the left side wall. With this information I can better address the issue at hand. Thank you!
Jul 25, 2014 | Frigidaire Freezers
Triangle symbol
That red triangle is the STOP button.
Nov 12, 2013 | Canon PIXMA MX340 Wireless Office...
WHAT THE SYMBOLS MEAN
From left to right:
(Lights)
Exclamation point: Error
Weird Monitor beat symbol: Jam
Paper: Out of paper
Toner (Triangle leading down to dot pyramid): Toner refill
Lightbulb: ready
(buttons)
Greenish Play button (square with triangle): Continue
Red button with x: Stop/Cancel
Dell 2230 User Guide Page 1
Mar 27, 2013 | Dell 2230d Laser Printer
Exclamation point in triangle blinking on dashboard
Hi, The exclamation point in triangle blinking is the "Emergency Blinker" This blinker turns on all all of the turn signal lamps at all four corners of the car. Left and Right, Front and Back. The triangle represents the European symbol for roadside emergencies. In fact on European Mercedes and other cars there is a triangle shaped reflector you can put behind the car so that other drivers know you have an emergency. THAT TRIANGLE ON YOUR DASHBOARD IS A BUTTON. PUSH IT ONCE. THE BLINKING SHOULD STOP. If you have a roadside emergency, and are broken down by the side of the rode. Push the Red Triangle and your lights will blink on and off ouTside to say, in effect "help".
Hope this helps.
Best,
Mark
Jan 13, 2011 | 2005 Mercedes-Benz C-Class
I have an emerson euphoria am/fm stereo radio/cd player/cassette recorder. i want to record on cassette. there are 6 buttons with symbols on them. what are they and which do i use to record
the standard tape symbols are as follows.
triangle on side pointing right - play
filled dot - record these need to be pressed at the same time.
while recording
II symbol is to pause
square is stop.
double arrows left is rewind
doubble arrows right is fast forward.
arrow up with a base is eject.
Nov 13, 2009 | Emerson PD6810 CD Boombox
Unable to change symbol on tomtom 920 sat navigation.
using TT home check that you still have the symbol you want installed on the TT. I had a similar problem where it would seem to forget what I had choosen on occasion and sometimes I had to use TT home to check and re-install. problem itself seemed to just go away. (Guess it got sick of me telling it LOL)
Feb 02, 2009 | Tomtom GO 920 GPS Receiver
PLEASE HELP ME
you have to reset your drum counter in the maint mode. do you knoe how to get in the maint mode?
Dec 10, 2008 | Sharp AL-1000 Copier
The mouse on the laptop has stopped working. I have changed over the mouse itself thinking it was a problem with the mouse, but it worked for about 30 minutes before it stopped working again.
check to see if it's a driver issue:
check in device manager for a ? or a ! next to the pointing device: go start>right click my computer>properties>hardware tab>device manager and look for a yellow symbol with a ! triangle or a yellow "?"sign... if you find this under ponting device you have most likely a driver issue,
check the manufacturer's website for an updated driver for you pointing device and reinstal the driver.
Sep 22, 2008 | Computers & Internet
What does the triangle symbol with small objects in it mean?
It´s the descaling indicator, you need to descale the machine.
Jul 09, 2008 | Schaerer Opal Espresso Machine
Flashing light
Here is what HP has on the subject of the triangle light flashing:
c00028322.gif 1 - Attention Light 2 - Ready Light 3 - Go Light Figure 2: Printer light key c00028323.gif 1 - Symbol for light off 2 - Symbol for light on 3 - Symbol for light blinking
c00028328.gif Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Figure 8: Paper jam c00028328.gif 13.JJ.NT JAM IN TRAY 1
13.JJ.NT JAM IN TRAY X
The Attention LED is blinking. Check paper loading then open and close top cover.
When there is a jam in tray 1, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored.
When there is a jam in tray X, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored. These are the error explanations for just the flashing triangle light, there are many more, but none for just the flashing triangle.
If the light pattern is different let me know (other lights on as well)
-Hope this helps.
May 28, 2008 | HP LaserJet 1012 Printer
Open Questions:
Nikon D200 Digital Camera with 18-200mm Lens Logo
134 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
