Question about RS855LCD AutoPage MultiChannel 2 Way Paging Vehicle Security Sys
I got my remote wet and it not working and cannot unlock car and that make the ignition not be able to turn on. How can i turn off the transmitter. I saw something about using smartphone as an alternative to remote? need help thanks in advance
How to get my remote key fob on my 1997 lasabure to work
Close all the vehicle doors.
Insert the ignition key into the ignition lock cylinder.
Press and hold the DOOR unlock switch.
While holding the DOOR lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
Release the DOOR unlock switch. The doors will lock and unlock to confirm the program mode.
Press and hold the LOCK button and the UNLOCK button simultaneously on one keyless remote. After a delay of approximately 15 seconds , the doors will lock and unlock to confirm the programming of that transmitter.
Repeat the previous step to program up to four transmitters.
Turn the ignition switch to the RUN (one more click forward) position in order to exit the keyless entry transmitter mode.
Operate the transmitter functions in order to verify correct system operation
Jul 31, 2014 | Buick LeSabre Cars & Trucks
Tip
How to program Chrysler Remote Transmitter
A Chrysler Transponder Key once programmed into a one car cannot be programmed to work any other car.
The transponder code identification is learned by the Sentry Key Immobilizer Module during programming. The Sentry Key Immobilizer Module sends the "Secret Code" to the transponder key and is retained by the transponder key during programming. After programming of the transponder key identification to the Sentry Key Immobilizer Module and the Secret Code is exchanged, the Sentry Key Immobilizer Module will ask for the transponder identification and the Secret Code every time the key is turned to ON or START.
No Emergency "Start" procedures for Chrysler vehicles.
Chrysler Key Operation and Programming
Model: 300 Year: 2005 - 2008
Model: 300C Year: 2005 - 2007
Remote alarm / central locking
System Operation
  • Pressing key LOCK button activates alarm and central locking.
  • Pressing key UNLOCK button once deactivates alarm system and unlocks driver's door.
  • Pressing key UNLOCK button twice within 5 seconds deactivates alarm system and unlocks all doors and trunk.
  • Pressing trunk lid button twice opens trunk lid.
  • System will automatically lock all doors when vehicle is driven above 15 mph.
  • Additional functions can be set to respond to the transmitter.
Programming
When
  • Key transmitter added or replaced.
How
  • Key transmitter is programmed during immobilizer programming procedure.
Immobilizer
System Operation
  • Switch ignition ON.
  • Immobilizer warning lamp illuminates for approximately 3 seconds.
Programming
When
  • Keys added or replaced.
How:
NOTE: Two programmed key transmitters must be available for the following procedure to operate. If none available key transmitters can only be programmed using diagnostic equipment.
  • Insert first programmed key into ignition switch.
  • Switch ignition ON for at least 3 seconds but no longer than 15 seconds.
  • Turn ignition OFF and remove key.
  • Withing 15 seconds insert second programmed key into ignition switch and turn ignition ON.
  • After 10 seconds an acoustic signal will be heard and immobilizer warning lamp will flash.
  • Turn ignition OFF and remove second programmed key.
  • Within 60 seconds insert non programmed key into ignition switch and turn ignition ON.
  • After 10 seconds an acoustic signal will be heard and immobilizer warning lamp will illuminate for 3 seconds.
  • Switch ignition OFF.
  • Remove Key.
Check operation of programmed key transmitter.
Repeat procedure for additional key transmitters if required.
Model: 300M Year: 1999 - 2003
Model: Concorde Year: 1998 - 2003
Model: LHS Year: 1998 - 2001
Model: PT Cruiser Year: 2000 - 2005
System Operation
  • Pressing remote transmitter UNLOCK button once deactivates alarm system and unlocks driver's door only.
  • Pressing remote transmitter UNLOCK button twice within 5 seconds deactivates alarm system and unlocks all doors.
  • Alarm / Central locking functions can be altered using remote transmitter.
Programming
When
  • Remote transmitter added or replaced.
How:
NOTE: One programmed Remote transmitters must be available for the following procedure to operate.
  • Obtain all remote transmitters.
NOTE: Any existing remote transmitters not used during programming will become inoperative.
Using a programmed remote transmitter proceed as follows.
  • Press and hold remote transmitter UNLOCK button.
  • After holding the UNLOCK button for at least 4 seconds but no longer than 10 seconds, press remote transmitterPANIC button for at least 1 second and release both buttons.
  • Ensure acoustic signal is emitted indicating programming mode active.
  • Within 30 seconds carry out the following procedure for each remote transmitter (including previously programmed remote remote transmitter)
  • Press any button of each remote transmitter to be programmed.
  • Ensure acoustic signal is emitted after each remote transmitter operation.
  • Programming must be completed within 30 seconds.
  • Switch ignition OFF or wait 32 seconds to exit programming mode.
Ensure final acoustic signal is emitted.
Replacement remote transmitters can also be programmed using diagnostic equipment.
Immobilizer
System Operation
  • System arms after switching ignition OFF.
Programming
When
How
NOTE:Two programmed key transmitters must be available for the following procedure to operate.
  • Obtain all keys.
  • Using first programmed key turn ignition switch ON and wait 3 seconds, return to OFF position and remove key.
NOTE: First and second programmed key operations MUST be performed within 15 seconds.
  • Insert second programmed key and switch ignition ON.
  • Wait approximately 10 seconds.
  • Ensure immobilizer warning lamp begins to flash and an acoustic signal is emitted.
  • Switch ignition OFF and remove key.
  • Within 50 seconds, insert new key and switch ignition ON.
  • Ensure acoustic signal is emitted and immobilizer warning lamp remains illuminated for 3 secondsindicating programming completed.
For each additional key repeat procedure starting from the beginning.
Replacement keys can also be programmed using diagnostic equipment.
Automotive and Commercial Locksmith Chrysler Remote Control Programming...
on Mar 26, 2015 | Televison & Video
I changed battery in remote keypad and now i can't get into the car. Already tried hold the lock and unlock on the keypad down for 15 seconds and still didn't work.
Remote Key FOB Information
Transmitter Programming
1. Close all the vehicle doors.
2. Insert the ignition key into the ignition lock cylinder.
3. Press and hold the door unlock switch.
4. While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
5. Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
6. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
7. Repeat the previous step to program up to 4 transmitters.
8. Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter programming mode.
9. Operate the transmitter functions in order to verify correct system operation.
If this does not work, you may need to have the dealer do it with a scan tool. Make sure you take all the remotes you want to use with the car if you have to go this route.
Aug 29, 2011 | 2005 Cadillac STS
Acura RL 2000 Remote needs Program Instructions
TURN ON IGNITION SWITCH WITH ENGINE OFF.POINT THE REMOTE TRANSMITTER AT CENTRAL LOCKING SIGNAL CONTROL MODULE LOCATED BEHIND PASSENGERS SIDE C POST.WITHIN 4 SECONDS PRESS LOCK OR UNLOCK.WITH REMOTE TRANSMITTER.WITHIN 4 SECONDS SWITCH IGNITION OFF.WITHIN 4 SECONDS SWITCH ON IGNITION WITH ENGINE OFF.WITHIN 4 SECONDS PRESS LOCK OR UNLOCK USING REMOTE TRANSMITTER.WITHIN 4 SECONDS SWITCH OFF IGNITION SWITCH.REMOVES KEYS FROM IGNITION SWITCH WAIT 10 SECONDS THEN TRY USING REMOTE TO SEE IF IT WORKS DOOR LOCKS.IF THIS PROCEDURE DONT WORK.TAKE TO DEALERSHIP.
Jun 22, 2010 | 2000 Acura 3.5RL
Battery went dead in 2007 Chevy Silverado truck. Now, remote does not work. Replaced battery in remote and it still does not work.
Make sure you have one working ignition key and all remotes for the vehicle.
1) Close all vehicle doors.
2) Insert the key into the ignition.
3) Hold down the power UNLOCK button on the driver’s door panel-continue to hold down until instructed to release in step 9.
4) Perform steps 5 through 8 in fairly rapid succession.
5) Turn the ignition switch to the ON position (as far as you can go without starting the engine).
6) Turn the ignition switch to the OFF position.
7) Turn the ignition switch to the ON position.
8) Turn the ignition switch to the OFF position.
9) Release the power unlock button on the door panel. The vehicle will lock and unlock the doors automatically.
10) Hold down the LOCK and UNLOCK buttons on the transmitter simultaneously until the door locks and unlocks. This step may take up to 30 seconds.
11) Repeat step 10 NOW for each additional transmitter (including any existing transmitters).
12) Turn the ignition switch OFF then to the ON position in order to exit the transmitter programming mode.
Feb 28, 2010 | 2007 Chevrolet Silverado 1500 2WD
I have a 98 GMC JIMMY. Remotes and Dome Lights stopped working. Car would start then immediately die. Took it to the dealer and they stated it was the Body Control Modual (BMC). Picked up the vehicle...
Keyless Entry System Circuit Description
The Power Door Locks/Remote Keyless Entry control system provides several functions. The driver operates the vehicle door locks and rear window release from outside the vehicle using a hand-held radio transmitter. The transmitter sends coded signals to the remote control door lock receiver. The remote control door lock receiver detects and decodes the signal from the transmitter. The remote control door lock receiver issues signals to the body control module (BCM) through a serial data link. The BCM actuates relays to lock and unlock the doors and liftgate. The BCM can also release the liftglass. The power door lock switches provide manual control of the door locks.
Important: Different keyless entry systems are used on General Motors vehicles. The parts are not interchangeable even though the parts may appear to be similar. Observe the back of the transmitter in order to properly identify the system. On 1998 S/T pickups and utilities, use a transmitter identified with GM/UTA preceding the part number.
With the driver door closed, hold down the power unlock button on the door panel.
The remote control door lock receiver will respond in the following manner in order to indicate that the receiver is in the programming mode:
6.1. Locking the doors
6.2. Unlocking the doors
Important: All extra transmitters must be programmed at this time. When a new transmitter is programmed, it will deactivate the old transmitters.
Hold down the lock and unlock buttons on the transmitter until the remote control door lock receiver will respond in the following manner:
7.1. Locking the doors.
7.2. Unlocking the doors.
Repeat step 7 for each additional transmitter.
Turn the ignition switch to the ON position in order to exit the transmitter programming mode.
May 04, 2017 | 1998 GMC Jimmy
How to program a keyless remote on a 2003 f-150
To program the transmitters yourself:
  1. Insert a key in the ignition and turn from 3(Off) to 4(On) eight times in rapid succession (within 10 seconds) with the eighth turn ending in the 4(On) position.
  2. The doors will lock/unlock to confirm that programming mode has been entered.
  3. Within 20 seconds, program a remote transmitter by pressing any button on a transmitter. The doors will lock/unlock to confirm that the remote transmitter has been programmed. (If more than 20 seconds pass before pressing a remote transmitter button, the programming mode will exit and the procedure will have to be repeated.)
  4. Repeat the previous step to program additional remote transmitters. The doors will lock/unlock to confirm that each remote transmitter has been programmed.
  5. When you have completed programming the remote transmitters, turn th ignition to 3(Off) or wait 20 seconds. Again the doors will lock/unlock to confirm programming has been completed.
Sep 20, 2009 | 2003 Ford F150 Regular Cab
Passlock
turn key all the way on (not to start) let set for 1 hur cycle key and try it.
Jul 20, 2009 | 1999 GMC Jimmy
How to program a 2000 mustang keypad
  1. Insert a key in the ignition and turn from off to on eight times in rapid succession (within 10 seconds) with the eighth turn ending in the on position.
  5. When you have completed programming the remote transmitters, turn the ignition to off or wait 20 seconds. Again the doors will lock/unlock to confirm programming has been completed.
Jul 09, 2009 | 2000 Ford Mustang
Keyless entry remote quit working. Just purchased new battery. Now Spare remote does not work either.
Transmitter Programming Notes Transmitter Programming
  1. Start with the ignition OFF, hold down the power unlock button on the door panel. Turn ignition key ON, OFF, ON, OFF. Release power unlock button on the door panel. The locks will cycle once.
  2. Hold down the keyless entry transmitter LOCK and UNLOCK buttons for 15 seconds . The locks will again cycle once.
  3. Repeat step #2 for each additional keyless entry transmitter.
  4. Turn the ignition on to exit the keyless entry transmitter programming mode. Programming is now complete
Jun 17, 2009 | 2000 GMC Sierra
RS855LCD AutoPage MultiChannel 2 Way Paging Vehicle Security Sys Logo
70 people viewed this question
Top Autopage Vehicle Parts & Accessories Experts
Marvin
Marvin
handt729
Level 1 Expert
Kardoc
Are you an Autopage Vehicle Part and Accessory Expert? Answer questions, earn points and help others
