Question about Saeco Royal Professional Espresso Machine
Warming up problem
Upon turning machine on after non use for a while warming up is displayed and won't move to "ready". Machine stays in "warm up" mode and I'm able to select anything else. Help!!
  • 40 Answers
Your thermo senser may be going bad. Suggest at this time is to have an Authorized SAECO Service Center check your machine. Contact Saeco USA Inc. to located a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Posted on Jun 20, 2008
Why would a Kon. Min. Magicolor 2590MF continually display "please wait"?
It's possible the fuser bulb has gone. I'm afraid the diagnostics and errors on these are pretty poor, so it is entirely possible that it is not heating. Turn it on, the leave it for 5 minutes. Feel around all the surfaces of the printer CAREFULLY to see if it is warming up at all. It should be at 200degrees or more, in the fuser. It's unlikely to be the fuser temp sensor, but fuser bulbs do go especially if moved or jogged when hot.
Jul 31, 2014 | Konica Minolta magicolor 2590MF Scanner
Hi, Im getting a costant "wat warming up" never
please format the hard drive by holding down the 0+8 buttons while switching on the machine when in test mode key in 690 press the start button make sure the number 2 is displayed when finished switch off and wait awhile then switch on if the machine still gives the error replace the hard drive and do the firmware good luck
Apr 01, 2011 | Toshiba e-STUDIO 352 Black and White...
HP Laserjet 3330 Multifunction monochrome printer,copier,scan and fax. This machine will warm up, and after it reads "scanner lamp warming", the scanner lite lights up, the carriage moves back and forth,...
This type of problem is usually caused by dirty mirrors in the scanner. After a few years of use the mirrors and lenses in the unit will get a fine coating of dust particles on them. The dust interferes with the scanner initializing the optics. When this happens the unit displays the Scanner warming up message on the screen and keeps trying to move the scanner assembly to get a good reading from the pickup. To solve the problem you will need to disassemble the scanner portion and clean all of the mirrors with window cleaner and a soft cloth or q-tip. To get dis-assembly guides just do a google search for the 'scanner warming up' error.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 04, 2010 | HP LaserJet 3330 All-In-One Printer
Permanent warming up message
When you replace a power supply for this machine, it needs to be the correct power supply for this model. If you have the old one, check to make sure the right power supply was ordered for this specific model.
Because I cannot see the display, and we only know what it is saying, the next best thing would be to see if the fuser warmed up at all. Open the side door and gently feel the fuser frame to see if it is warm at all. Do not touch the Fuser roll; it is hot even to the slightest touch.
If it is not hot, make sure all the plugs were correctly plugged into the power supply.
On this problem there can be other factors that can cause warming up.
First, the fuser assembly may be defective and needs replacement.
Second the main board may be gone out.
And last if the machine has memory chips in the back, unplug the machine, remove the small cover from the back and unplug the simms chips and reseat them. Plug in the machine, then power it on.
See if the machine will go to a ready.
If not, possibly the fuser, or main board, or both. If the main board or(and) the fuser assembly is replaced,
MAKE SURE THE CORRECT PART IS INSTALLED IN THE MACHINE.
If all else fails, Place a Xerox Service Call on the machine before it gets too expensive in troubleshooting the problem with purchased parts.
Oct 22, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Machine will not move past Warming Up start up
check with voltmetar your element on boiler for espresso,element need have continuidi,and check reset button if your machine have button on tank,and check small fuse on tank(with white rubber around)
Aug 24, 2009 | Saeco Royal Digital Plus Coffee...
XEROX WORKCENTRE M20 WHEN POWERING UP MACHINE IT WILL NOT COME OUT OF WARM UP MODE. FUSER IS HOT. MACHINE DISPLAY WILL SAY WARMING UP, MACHINE WILL CYCLE, SCANNER WILL MOVE , PRINTING WILL APPEAR ON...
what you want to do is this, turn the machine off. Remove the back cover. Then on the main board you should see a memory stick or 2 depending on the model.
Remove the memory sticks, then power up the machine with them out. Let it come to ready, then re install the memory sticks and power the machine back up to remove any software corruption.
Apr 08, 2009 | Xerox WorkCentre M20 All-In-One Laser...
Shuts down during warm up
the fuser unit is not warming up, so the machine shut down
Mar 21, 2009 | Xerox Office Equipment & Supplies
Warming up non-stop with this message UF-585 (YM) OPT
Open top cover
remove toner cart.
leave cover open
Press:
Function
7
monitor key slowly 4 times
6
scroll down to "all job clear"
(as a last resort choose "shipment set")[sets machine to factory default]
wait for machine to reboot
Sep 26, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Canon CLC 2400
go into service mode and clear ram remember to copy the values before clearing or your dc controll is damage
Nov 29, 2007 | Office Equipment & Supplies
Warming up message
how long have you had this machine?
May 23, 2007 | Brother IntelliFax-2820 Laser Fax
Saeco Royal Professional Espresso Machine Logo
803 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
