Question about Sherwood Audio Players & Recorders
I have my 6 speaker Bose system set up to a sherwood audio/video reciever model RD-6513. everytime i try to set the speaker on auto set, the digital readout says Set FL and a noise is heard in front left speaker, but then it comes to a stop and error is displayed on the digital readout. How can i get all the speakers to set automatically/
    Brigadier General:
  • 3,513 Answers
Please check the links bellow related to your issue:-
http://www.ehow.com/how_2036224_setup-bose-theater.html
http://www.ehow.com/how_4826457_install-bose-surround-sound-speaker.html
http://www.ehow.com/how_6917455_use-bose-speakers-receivers.html
Please get back to us if you have any further query or else accept the solution.
Thanks for contacting fixya.com
Posted on Oct 24, 2010
SOURCE:
I have a sherwood rd-6513 it keeps shutting off straight after turning on. How can I fix this?
Hi
Its in protection mode ..
check your speakers cables first
if is all OK
then the receiver needs to be serviced the power supply section has a damaged parts or re-soldering the points again , but mostly damaged parts due to age of the device.
hope this helps
Kind regards
M.Mathis
Mar 13, 2016 | Sherwood Audio Players & Recorders
Find remote code for sherwood rd6500 reciever
The only place you will find those codes, are in the back of the owner's manual. There is usually a general procedure to find a code that works, if they don't show the make and model number in the manual.
If you don't have the manual, I'm sure it on their website.
Feb 28, 2015 | Sherwood RD-6500 Receiver
No sound from tv when connected to sherwood 7505
try pressing the aux button on the front of the reciever while the reciever is linked up to the tv ,if that dont work connect a red and black banana plugs into your aux on the back of the reciever and on the other end of the lead must be a head phone pin check size of headphone socket. to plug in to your tv head phone volune then u can control the recievers volume through the tv using the remote.go to menu then tv set up then scroll to the sound note icon press enter scroll down click on head phone and turn it up then you should have sound through the speakers from the tv.
Jan 27, 2013 | Sherwood Rd-7505 Home Theater Receivers
I just purchased a Sherwood RD 6513 reciever, I'm trying to connect a hd cable box (motorola dch 3200), dvd player (sony dvp ns710h) and a rca hd tv (l32hd41). I connected hdmi cords from both components...
Hi! I will be more than glad to assist you. I f you are going to hook up your cable box - motorola to the sherwood receiver, connect an hdmi cable to the back of the motorola cable box, there is only 1 hdmi output there, then connect the other end to the sherwood receiver on the hdmi input, then connect another hdmi cable to the hdmi output and the other end goes to your rca hd tv.
for the sony dvp, you have only one hdmi out, connect an hdmi cable to the back of the sony dvp if u have another spare. connect it to the hdmi input of the sherwood receiver. there is only 1 hdmi output at the sherwood, so u need to use a component cable to be connected at the back of the sherwood receiver component output then the other end goes to the component input of the hd tv.
if you dont have anymore hdmi cable to hook up your sony dvp, u can use component cable, the connection will goes like this, connect a component cable on the output of the sony dvp and the other end goes to the sherwood component input then connect another component cable to the component output of the sherwood and the other end goes to the rca hd tv on the component input.
I hope this will solve your concern, if you have any question, u can get in touch..
Aug 21, 2009 | Televison & Video
No sound
you need audio cable also (red and white).for each device
reply for more help bama46 please rate
Aug 19, 2009 | Audio Players & Recorders
Can I hook the reciever to mm bose subwoofer and 5
if bose unit has built in amplifier .Then your sherwood would have to have a variable RCA output jacks in order to work with sub.Then bose audio input RCA cable would connect there.If bose unit does not have built in amp .Then you would connect sherwood left/right speaker outputs into bose left/right inputs .Then other bose speakers will connect to bose unit
Jul 30, 2009 | Sherwood RX-4105 Receiver
Hear sound but cant get any real volume even at full blast
I was playing around with my Sherwood RD 6513 and adjust the the output level to its maximum, amongst other settings. This limited my output on the amp to a maximum volume of 65 not 90+.. Anyway i pluged in the microphone and done another 'auto setup' of the volume levels and distances, and this allowed the volume to exceed 65 again!
Also if you have an external source such as a DVD player - i would assume you have already checked its output volume setting?
Nov 23, 2008 | Sherwood RD-6500 Receiver
93 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Allison
Steve Allison
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
