Question about Kenmore Ovens
I have a Sears Kenmore Oven, Model 665.75829, the burners on top work fine, the oven however does not. The flame comes on and after about 3 seconds it shuts off. Broiler similar response.
  • tshippee Oct 24, 2010
    Hi Joe,
    Thank you for your prompt response. As I stated in my question the broiler and bake have the same response. One of course is on top (broiler) and easy to get to the pilot. The other bake the bottom pan and burner dispersion plate must be removed. I tried the broiler this morning (before church) and I got the same response. I held a charcoal lighter on the pilot. The electronic sparker came on as before, the burner lite (across the length of the burner) and then after about 3 seconds it shutdown. So does the oven use the same pilot for the oven and broiler? Not sure what is next. I will after church take the bottom pan an burner dispersion plate off and try that. I don't extect a different response than what I saw with the broiler. Any additional information you could provide would be helpful.
    Best Regards,
    tshippee
    Genius:
  • 1,340 Answers
The thermocouple within the oven is likely bad.If you open the oven and look around,you should see basically a metal rod,most likely uncovered,probaby held down by 2 clips with 2 wires sticking out of it.It reads the temperature as it is right now,compares it to what you want it to be when turning it on the temperature setting,and sends a signal to a circuit board to tell the oven when to turn on,off.If it is bad,it will indeed come on for a couple seconds,then turn off.This prevents it from turning on and heating up and never shutting off,possibly causing a fire.Good luck! greg
Posted on Oct 24, 2010
  • 10,865 Answers
Hello. When the flame come on but does not stay on you have to:
  1. Turn all controls off, open the doors, and allow gas to dissipate.
  2. Hold a lighted match near the tip of the pilot on the burner assembly. If a burner does not light within two minutes, adjust the pilot, step 3.
  3. Turn the pilot adjustment screw (located near the pilot or the thermostat) in small increments and retest until the pilot has a blue flame.
Joe
Posted on Oct 23, 2010
SOURCE:
No flame
when this happens it is usually because of a faulty flame/gas safety valve.
Sep 08, 2008 | Amana AOGD2750 Gas Double Oven
Hello, We have a Kenmore gas stove model # 71761. The burners on top work good.The issue is with the oven portion. Oven is working. Flame comes on upon ignition to desired temperature setting and then...
It sounds like yous stove is working fine. Cycles fine. If you think the stove is cycling more often than when new then ck the seal on the door. You may be loosing heat.
Jan 14, 2011 | Ovens
Ignitor for oven comes on but gas release cuilds up before oven ignites causing a voom
I have a Kenmore Gas Range, model 72503. #1 problem-the orficies were not installed properly; #2 problem-when I turn the top burners on, gas comes out before the ignitor comes on. I called Sears, they sent someone who said that the burners can't be adjusted. I feel this is very dangerous. This is a new 2011 model, made for Sears by Frigidaire. Who should I contact about this problem. Sears say it is out of their hands. Help!
Sep 12, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
Oven won't ignite
most likely you have a bad ignitor.take out the racks and remove the floor,you'll see the ignitor,turn on the bake,the ignitor should glow and the flame should lite within 40 seconds,if it doesn't change out the ignitor,even if it glows that doesn't mean the ignitor is still good change it out.let me know what you find and next time send model number
Jun 20, 2010 | Kenmore 33169 Gas Single Oven
Kenmore Gas Oven doesn't heat
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 07, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Oven takes 5 minutes to come on (ignite).
Replaced the igniter. The parts guy told me that the amperage changes with age and use; thus the igniter still glows, but it takes much longer to operate the gas valve with the reduced amperage. Cost - $70.14
Oct 18, 2009 | Tappan 30IN ELEC IGNa Oven
Oven burner flame is low
0000000.jpgOn top of that safety valve is a nut. Get a good fitting wrench. Turn on the oven and use that good fitting wrench on that nut. Turn it counterclockwise till the flame comes up about midways of the flame spreader. Don't get the flames too high. Midways of the spreader now. LOL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 02, 2009 | Ovens
Gas stove burner/oven noises
too much air on top burner ,delayed ignition on oven ,ignitor not lined up properly or check gas presure may need regulator adjustment or replaced. gas 784
May 12, 2008 | Ovens
Amana gas range bake burner does not heat
Pull the bottom of the oven off. You will see 2 to 4 screws that hold the panel on. The ignitor is under there. Look at the ignitor carefully for breaks. I say carefully as the ignitor is very easy to break.
Feb 03, 2008 | Ovens
Ovens Logo
49 people viewed this question
Top Kenmore Ovens Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
