Question about Sony Playstation 3 (PS3) Console
Error 80022F0A comes up when I try to download a movie rental we paid for yesterday (ethernet wired connection); also error 8001000A comes up when I try to connect via wireless. I have already sought support from my ISP & Wireless Router manufacturer. They suggest something may be wrong with my ps3.
5 Suggested Answers
SOURCE:
  • 49 Answers
SOURCE: PS3 wireless connection ERROR code 8001000B
your wireless may be glitched and may need to be replaced or you need to reformat your ps3 which will return it to factory settings
Posted on May 20, 2008
SOURCE: PS3 cant go online with Belkin N1 wireless router
I have exactly the same issue as some of you above. As soon as I start my PS3 I manage to log onto the network for anywhere between 2 seconds and 2 minutes before I get the dreaded 80710102 error and have to reboot the PS3 to reconnect. I wrote to Belkin tech support and got the following reply... I Haven't tried it yet so don't know if it really works but thought I'd post it up here in case it helps anyone else out...
Hi Antony,
Thank you for contacting Belkin Technical Support.
We understand that the router does not support PS3. We apologize for the inconvenience caused.
A) To isolate the problem, please follow the steps given below to update the firmware and configure the router:
We recommend that you update the firmware from a computer that is connected to the router with an ethernet cable.
Please download only the relevant firmware on the router from the link given below. The firmware file would be according to the router version:
http://www.belkin.com/uk/support/article/?lid=enu&pid=F5D8635uk4A&aid=14489&scid=0
and save it to the computer.
- To update the firmware, log on to the router`s web interface by typing in http://192.168.2.1 in the address bar of the browser. The computer should be
Note: If you have changed your Router’s IP address, use that IP address.
- By default, the password is blank. Click the "Submit" button.
- Click on "Firmware Upgrade" under the option "Utilities".
- Click on “Browse” and select the bin file that you have downloaded.
- Click on “update” and follow the wizard.
- After updating the firmware, restore the router to factory defaults by clicking on "Restore Factory Defaults" under "Utilities".
- Reconfigure the router.
Please follow the steps given below for configuring the router:
- Disconnect the computer from your Modem provided by your "Internet Service Provider" (ISP) if it is connected to the computer.
- Reset the router to "Factory Defaults". The reset button is found at the back of the router. The reset procedure is,
- Unplug the power cable and then plug it back again. Wait for 5 seconds.
- Locate the reset button (inside a hole) at the back of the router.
- Hold down the reset button till the power-light turns solid, and then release it.
- Connect the router to either the telephone line or the filter.
- Connect the computer to port number 1 of the router.
- Make sure the corresponding lights are lit. The telephone light should be ON and solid.
- Make sure your computer has a valid IP address by following the steps given below.
1. Click on “Start” -> “Run” -> and type “CMD” and click “OK”.
2. Type “ipconfig” in the black window and check the IP address.
3. It should be in the range of 192.168.2.x, where “x” ranges from 2 to 254.
- If it is not a valid IP Address, please assign a static IP address, "Subnet Mask", “Default Gateway" and "DNS Addresses" in the computer by referring to the link below.
http://web.belkin.com/support/kb/kb.asp?a=2824
- Please reset the Internet Explorer browser settings by following the steps below.
- Open Internet Explorer. Click on “Tools” -> “Internet Options”.
- Under the General tab, click on “Delete Files” under “Temporary
Internet Files” and select "Delete all Offline content" box.
- Click on “Clear History”.
- Under the Connections tab, select “Never Dial a Connection” and
click on “LAN settings”. Uncheck all the options and click on “OK”.
- Under the Advanced tab, click on “Restore Defaults”.
- Click on “Apply” and then “OK”.
- Log on to router setup page by typing “192.168.2.1” in the address bar of the browser. By default the password is blank.
- On the left under “Internet WAN”, click on the option "Connection Type".
- Select “PPPOA”, (If it is ADSL)/ PPPOE (If it is DSL) and click on “next”.
- Type in the user-name and password and then re-type the password given to you by your ISP. Make sure you type in the full user-name.
For Example, the format for the User-name should be "[email protected] or .net"
- Also confirm the settings of “VPI/VCI”, “Encapsulation” values from your Internet Service Provider (ISP) and configure the same.
- Change the “MTU” to “1400”.
- Click on “Apply Changes” button at the bottom. Wait till it saves the data.
- Click on Home on the right top corner and then click on the "Connect" button. You should be able to go online.
B) Configuration of PS3:
Please contact Sony and assign static IP address and DNS on the PS3. The static IP address should be assigned in the range of the router. For example: 192.168.2.200. The IP address you assign should not be used by any other device on the network. Please confirm the ports to be opened for the PS3 from Sony.
1) Please follow the instructions given below to forward the port numbers for PS3 on the router:
- Please open the Internet Explorer and in the address bar type in "192.168.2.1" and "Enter". The computer should be connected to the router with an ethernet cable.
- Leave the password blank and click on "submit".
- Click on "Virtual server" under the "Firewall".
- Enter the port number under "Inbound port" & "Private port".
- Enter the Static IP address of the PS3 under the "Private IP address".
- Check the "Enable" box and click on "Apply changes".
2) Please follow the instructions given below to enable UpnP on the router:
- Log on to the router web interface at http://192.168.2.1
- Click on System setting under "Utilities".
- Against the heading "UPNP Enabling", choose "Enable".
- Click on "Apply changes".
Note: The NAT feature on the router is enabled by default.
If the problem persists, please get back to us with the following information:
1. Type of connection provided by your ISP (Is it PPPOE, Dynamic or Static).
2. Name of the Internet service provider (ISP).
3. Version number of the router. You would find the version number on the bottom of the device. It would be a number in a series of thousands with a prefix “ver.”. Please confirm if the router is F5D8635?
4. Using the router, if the connection is stable on all the wired and wireless computers?
5. If the PS3 works fine with other networks?
6. When does the error come up? If it comes up for both, CAT5 and CAT6 cables?
Posted on May 28, 2009
  • 64 Answers
SOURCE: error 8001000A.
you may need to add the ps3's mac-adress, ip and so on in your router.
Posted on Oct 01, 2009
SOURCE: internet connection
help me every time i sign in it comes up with AN ERROR HAS OCCURD 80710101 BUT MY LAPTOP WORKS PERFECTLY face book me JOSH HALLETT
Posted on Sep 13, 2010
Getting my system to be able to download the games I purchased
That is just network error.
Your PS3 has not got a IP Address and/or name resolution from DNS.
Try a wired network if you are on wireless or vice versa.
Sep 01, 2016 | Sony Playstation 3 (PS3) Console
Error 8001000A IN MY PS3
hi,
you don't need to connect the router to ps3 configure it one one pc/laptop then activate the wireless on the router,then setup the wireless connection on ps3.
Apr 07, 2014 | Zyxel Computers & Internet
Wont let me sign in.says error 8001000a and says
Have you tried to test your connection. Or maybe you should turn it off from the back, along with any other device you have plugged into it, wait 2-3 minutes, and turn it back on. Hope this helps
Mar 28, 2010 | Sony Playstation 3 (PS3) Console
Only the power and ethernet lights come on
power it off completely for 5-10 min...and then try connecting the wire and check
Nov 29, 2009 | Arris High Speed DSL Modem
Error 8001000A.
Oct 01, 2009 | Sony Playstation 3 (PS3) Console
Error 80710723 when downloading a rental movie
Just add your PS3 IP address to the DMZ on your router. Chances are you have a built in firewall that is blocking your connection to the internet.
Thanks,
Ced
Jul 13, 2009 | Sony Playstation 3 (PS3) Console
Error code 8001000A, when hooking up wirless internet
try a different wep code because it might be the wrong one and if it isnt the wrong one put in the code but add 6992882
Feb 15, 2009 | Sony Playstation 3 (PS3) Console
Rental movies
if you got the movie in itunes,, connect the iphone and drag and drop the movie into the iphone?
Jul 23, 2008 | Cell Phones
Sony Playstation 3 (PS3) Console Logo
195 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
