Question about Maytag Neptune MDE5500AY Electric Dryer
Remove top to get at drum - Maytag Neptune MDE5500AY Electric Dryer
    President:
  • 1,554 Answers
The front panel must be removed first. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket.
Swing the bracket to the outside and unhook it from the slot in thRemove top to get at drum - 67a7d37.jpg lip.
Open the door then lift the front of the top cover and tilt it toward the rear of the dryer. Reinstall the top cover and the front panel by following the removal steps in reverse order.
Posted on Oct 24, 2010
  • phuffson Jun 16, 2011
    These are great instructions...I like the pictures!! Had to tighten the screws holding the paddles inside the drum. Worth a thousands words made simple. Took me 10 minutes after seeing the pics! Thanks!!!!
  • jehb54 Sep 07, 2011
    The loose paddle screws seem to be a common problem with this model!
    I followed these directions and easily accessed the drum to tighten them all. Good opportunity to vacuum lint out of the inner cabinet. Overall, a very easy process and about 30 minutes start to finish. Thanks for excellent info!
6ya staff
SOURCE:
Loud tumbling noise while it is going. How do i open the top of dryer to see the drum?
Sounds like a drum suppot wheel may be locking up and has a flat spot on it causing the "tumping noise. You usually have to remove the front panel to remove top, which you don't have to do to check out support wheels, it's a little more involved, but fairly simple. Look for two screws at the bottom of front panel, either get dwon on the floor & look up or feel for them, cant see them standing, kinda hidden for appearance. Remove screws and pull out on the bottom of panel, the top of panel is held by 2 snap-in clips which should pop out as you swing out the bottom of panel, exposing drum retainer brackets which hold the front drum cover. Remove these to remove drum or access screws holding top down to sides. There is no need to remove top to check support wheels, just remove belt from tensioner & motor pulley and drum should come right out the front exposing the 2 support wheels at lower back of dryer, their held on shaft by a snap ring. If your this far, check Teflon bearings on front drum end. they are 2 flat strips of Teflon rivoted in place. The drum simply slides on them. Replace felt seals on both ends of drum covers if worn. Wheels are $16 to $20 each. Hope this is helpful & cures your problem.
Feb 13, 2011 | Dryers
NEED TO REPLACE REAR BEARING.GOT A NEW BEARING.NEED A DIAGRAM ON DISSASSEBLE,REPLACEMENT AND REASSEMBLE. OR SOME HANDS ON ADVICE....THANKS ..TY
really tedious job. if you are really keen, pl. follow.
remove motor, remove shoker top pins, remove top stone, remove all hose connecting drum, remove heater/other connections, remove door gasket from front, support drum from top, remove springs, lower drum, dismantle drum in two pieces, remove inner steel drum.
well rest i think you can think yourself.
Oct 30, 2009 | LG WM-0532HW Front Load Washer
How to I remove the drum from a Hotpoint WM64 washing machine? I need to change the bearings.
Remove top cover and rear panel.
Remove belt and drum drive pulley.Remove clamp that secures door seal
Remove top control console panel.
Remove door lock.
Remove screws top and bottom holding front panel, remove front panel.
Remove spring clips holding plastic drum front, lift to one side plastic drum front cover.
Tap drum shaft to remove drum from container, remove bearings.
Please rate my solution.
Thanks.
Sep 04, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
How do you disassemble a GE harmony dryer
remove rear pannel and the motor is right there remove drum to acess the motor
remember to lay the dryer on an angle or even flat on it's face if you can to re insert the drum assembly and dont forget the belt
Jul 29, 2009 | GE Profile Harmony DPGT750EC Electric...
Cleaning the drum of the Whirlpool 3 LSR 6233 EQO (get it out)
Remove two screws that hold the control panel,pull forward and lift ,tilt back. Unplug door switch and remove the gold clips that hold the back to the top of washer cabinet. Lean cabinet towards front and remove. Unsnap tub ring at top from outer tub. Remove fabric softener dispenser cup at top of agitator. Remove snapped in plastic cover and seal underneath. Remove bolt under the cover. Remove agitator. Remove spanner nut that holds drum in and remove drum.
May 13, 2009 | Whirlpool LSR6332K Top Load Washer
Replacement drum for Q3964a
HP Color LaserJet 2820 and 2840 AiO Series Products - How to Replace the Imaging Drum Replace the imaging drum
  1. Push the scanner-release button to open the scanner assembly. Figure 1: Example of scanner release button location c00364331.gif
  2. Open the top cover. Figure 2: Example of top cover being opened c00364332.gif
  3. Grasp the imaging drum handle, and then rotate the drum until the handle is at the top.
    NOTE: The drum may be a snug fit. If needed, gently apply some force while rotating and removing the drum. Figure 3: Example of imaging drum rotation c00364333.gif
  4. Lift the imaging drum straight up to remove it from the device. Figure 4: Example of imaging drum removal c00364334.gif
  5. Remove the new imaging drum from its packaging.
  6. Place the imaging drum on a firm surface, and then pull the orange rings to remove the shipping pins. Figure 5: Example of shipping pin locations c00364335.gif
  7. Remove the orange shipping lock on each end of the imaging drum, and remove the two orange shipping spacers. Figure 6: Example of shipping lock and spacer locations c00364336.gif
  8. Remove the orange cover from the imaging drum. Figure 7: Example of orange cover location c00364337.gif CAUTION: Do not touch the surface of the roller or expose the roller to light for an extended period of time. Doing so could cause print-quality issues.
  9. Align the arrows on the side of the imaging drum with the arrows inside the printer. Figure 8: Example of arrow location c00364338.gif
  10. Lower the imaging drum into the printer, and then press it firmly into place. Figure 9: Example of imaging drum installation c00364339.gif
  11. Close the top cover and the scanner assembly.
Feb 27, 2009 | HP LaserJet 2840 All-In-One Printer
Imagerunner 1310 drum change
To change the drum you have to slide the plattened cover to the left,like you do when removing a paper jam,open the top cover,you will see a handle that you pull to remove the defeloping and drum unit,remove the drum and def unit.
The drum is attached by two clips on top of def unit,unlock the drum from the def by releasing that clips,slide te drum protecktion plate to the rear and remove the drum.insert the new drum by reversing this steps.
If your image of your copies is not bad you can remove the waste toner in the drum unit before replacing it.On top of the drum there are two plugs open them and remove the waste toner,make sure you remove all of the waste toner.Then that message will go away.
Jan 31, 2009 | Canon imageRUNNER C3200 Copier
Drum noise
Ordered drum from Sears parts. 3045EL1002D
Cost of 85$ + 15 to ship. It came in 5 days.
Here is how to do it on a DLE2514W. Takes about an hour. I only used a phillips screw
driver. Take your time and look over the situation. I hope that I rememberd
everything. Good luck.
Dryer Drum Repair
Dryer Drum Repair
1. Remove L bracket with 6 screws at the top, rear.
2. Slide top back 2 inches to unlatch and remove.
3. Remove control panel with 2 screws at top, inside corners.
4. Carefully unplug 4 plugs from back of control panel.
5. Looking at inside at the top. Remove wiring bundle from 2 guides.
6. Unplug wire from dryer light.
7. Open dryer door and unscrew 2 screws behind door just below lint trap.
8. Remove 4 screws at top of front panel that holds the door.
9. Lift up front panel to remove. I couldn't get the door switch plug to disconnect
so I carefully rotated it an set it on top of the dryer.
10. Remove upper case bracket with 2 screws in front and 2 screws inside at top.
11. slide up a bit to unlock from sides. Watch routing of dryer switch wire bundle.
12. Remove lint trap duct with 2 machine screws. Carefully slide down to remove.
13. Remove front drum support with 4 screws attached to sides. Lift up to disengage
sides. Lift drum to free from rollers.
14. Observe how drive belt is routed around motor and tension roller. Push tension
roller up and release belt. Carefully take belt off and remove.
15. Almost done. Lift drum up at rear to free from rear rollers. Remove.
16. While your're there vacuume up dust and reverse procedure to install.
Aug 13, 2008 | LG DLE2514 Electric Dryer
LG Dryer cracked drum on Model DLE5977W
Dryer Drum Repair
Dryer Drum Repair
Apr 28, 2008 | Dryers
LEAKS AND SQUEAKS
If you suspect the leak is from the main drum seal.
To remove the agitator, remove the softener cap by pulling, look inside the agitator, undo the bolt (4) with long socket extension and then lift out.
5e90500.jpg Not sure if you can see the seal ("O" ring at this point, you may need to remove the inner drum.
Isolate the supply.
Lift the top cover by inserting a flat blade approx 4" in at each side at the front to release the two top clips, top cover will lift and hinge backwards out of the way.
To remove the top ring (13) from the drum, unclip each clip around the top untill released, then remove.
to remove the inner drum (10) , unbolt (7) from the inside, lift out inner drum.
Seal (1) should be visible.
Mar 24, 2008 | Maytag PAV2300 Top Load Washer
Maytag Neptune MDE5500AY Electric Dryer Logo
142 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
