Question about Weber Genesis Silver B Grill
Center control knob/burner
Yesterday I noticed my center burner wasn't working. After a few minutes I saw a small flame under the center control knob. I turned the knob off, with some difficulty. Any idea what caused this problem? Can I replace the knob and connecting tubes?
    Master:
  • 638 Answers
There may be some leakage at the control knob portionwhich is creating such problem .u r right its better to replace the knob n connecting tubes. if the solution helps u --- spare a moment to click -accept the solution. feel free 4 further assistance,thanks bye
Posted on Jun 07, 2008
    Sergeant:
    Champion:
  • 230 Answers
This may be due to the obstacles that struck in the burner .so clean the burner with the pin or any thin material and try
    Brigadier General:
  • 3,614 Answers
Yes.. you can replace the burner... but you can still the burner for any possible dirt blocking the gas out on each hole...
micro
  • micromaster
    micromaster Jun 07, 2008
    just try cleaning first the gas burner..
Jenn-Aire Model CVG4380 gas stove top. Why doesn't igniter work?
Under your knobs are burner switches, 3 of them are the same, so this will be a hit and miss on getting them but possible. Each burner should trigger the ignition system. This will be needed to be inspected to find out which one needs to be replace. If you get the right person to look over the unit they could tell you if it can be repaired. I worked on one about 3 years ago and it worked out fine. Good Luck and I hope this helped.
Apr 11, 2016 | Kitchen Ranges
Tip
How to diagnose a propane BBQ flaming at control knobs
WARNING: this test can be dangerous; do it only if you know what you are doing!
I turned on my two burner propane BBQ. The left side worked OK but flames started coming out of the control knob (front area) on the right, and the right side burner was not lighting.
This is obviously gas leaking out of the front area. If the flames go out when you turn the knobs off then the leak is after the valves, controlled ny the knobs. If the flames stay on and only go out if you turn gas off at the tank then the leak is at the pipe entering the controls. In my case the flames went out with the controls, so I looked underneath. I slowly turned the knob down and saw that the flames (therefore the gas) was coming out of the air regulator/entry hole. I knew at once that the pipe going to the burner must be blocked. Sire enough, when I removed the burners I saw that an insect built a cocoon in the pipe. Clearing it solved the problem.
on Jun 11, 2015 | Cuisinart CGG-200 All Foods Propane BBQ...
RHFE Rinnai 551FT gas heater is not working after 7 years
see this steps and fix it. God bless you
If there is no heat, check the electrical service panel for a burned fuse or tripped breaker. Relight the pilot light (see below).
If there is not enough heat, adjust the burner air shutter (see below); and clean the burner ports (see below).
If the pilot light does not light or does not stay lit, clean the pilot orifice carefully with a toothpick, test the thermocouple and replace it if it is faulty (see below).
If the flame flickers, adjust the pilot (see below).
If there is an exploding sound when the burner ignites, adjust the pilot to a higher setting and clean the pilot orifice and the burner ports.
If the burner takes more than a few seconds to ignite, clean the pilot orifice and adjust the pilot light.
If the burner flame is uneven, clean the burner ports. If the burner flame is very yellow, clean the burner; open vents in the furnace room to provide more air; adjust the burner air shutter.
To light the pilot on a standing-pilot (always on) ignition system, follow the lighting instructions located near the control. Otherwise, try these steps:
Light the pilot:
  1. gasfurnace1.jpg Press and hold the pilot control knob to start the pilot. Set the control knob to the pilot position. Hold a long match under the pilot gas port.
  2. Press the control knob; the pilot should light. Hold the control knob down until the flame is burning brightly (about 30 seconds). Release pressure on the knob, and turn it to the on position.
  3. If the pilot goes out when you release the control knob, try relighting, holding the control knob down longer. If the pilot again goes out, check the thermocouple (below).
Adjust the pilot:
  1. Remove any cap covering the pilot adjusting screw on a combination control.
  2. Turn the adjusting screw counterclockwise to increase the flame or clockwise to decrease it. It is correctly adjusted when the flame envelops the thermocouple bulb by 1/2 inch and appears dark blue with a small yellow tip.
Test and replace a thermocouple:
  1. Hold the control knob to pilot and light the pilot as above.
  2. Unscrew the thermocouple fitting with an open-ended wrench.
  3. Set a multimeter to the DVC (lowest voltage) scale.
  4. Clip one multimeter lead to the end of the thermocouple tube nearest the pilot and the other lead to the fitting on the other end of the tube.
  5. If the multimeter shows a reading besides zero, the thermocouple is functioning. Replace the thermocouple tube.
  6. If there is no reading, you will need to clean or replace the thermocouple following steps 7 through 11.
  7. Release the control knob and shut off the main gas valve on the gas-supply pipe that leads into the burner. Shut off power to the burner at the electrical service panel .
  8. Remove the thermocouple from its mounting bracket.
  9. Wipe the combination control clean and install a new thermocouple, tightening it by hand, then give it a one-quarter turn with a wrench.
  10. Insert the thermocouple into the pilot bracket, being careful to not crimp the tubing.
  11. Turn on power to the furnace and relight the pilot (above).
Adjust an adjustable burner air shutter:
  1. Set the thermostat to its highest setting to keep the burner running. Once the furnace has heated up, remove the burner access panel and loosen the locking screw.
  2. Open the shutter by turning it to the right until the blue base of the flame appears to lift slightly from the burner port surface. Then close the shutter until the flame reseats itself on the surface.
Clean removable burner tubes and ports:
  1. Shut off gas and power to the furnace.
  2. Unscrew or loosen and remove the tubes from the supporting bracket.
  3. Carefully clean the tubes with a brush or vacuum, making sure not to damage the burner ports.
  4. Use a stiff wire to clear any debris from clogged ports.
Sep 30, 2012 | Heating & Cooling
Canon Carrick LPG cooker-failure of full flame control bottom oven I have had this cooker for 14 months and used it for 6 months only from new. The bottom main oven has just started to play...
I had the same problem. I solved it by re-attaching a device which had come undone. On the right hand side of the burner is a rod with a metal wire attached. This was lying loose. It should be fixed to a little grey clip which is itself attached to a a piece of metal. By re-fixing the clip and the rod to the clip it solved the problem. Hope this helps. I have photos of how it should look. email info@music-works.uk.com for a JPG.
Dec 01, 2010 | Ovens
Not sure how to relight the pilot light. Some point during the night it just went off. Not sure how or why that happened either. I have tried to do a few things but need help
To light your pilot you will need to find the gas valve assembly. It will be a block of aluminum with a plastic knob and a few pipes attached to it. Once you find it, rotate the knob to the pilot marking on the knob. You will know when you are at the proper setting because you will be able to depress the knob into the gas valve about 3/8". Once you do that, there will be a small red button which you can snap causing a spark at the pilot. There may ba a small viewing port covered by a removable metal shield. OK, Depress and hold in the knob, snap the red button a few times. Keep holding the knob in, look into the viewing port for a blue flame. If no flame, snap the button a few more times looking for a spark. Once you see the flame stop snapping but continue to hold the knob in. Count to 30. Slowly let the knob out watching that the flame stays on. If it starts to go out, quickly depress the knob and hold for a minute. If it continues to go out, you have a bad thermocouple and it is not letting the pilot stay lit. If it stays lit, rotate the knob to On. A few seconds later and if the unit is calling for heat, it should light the main burner. If you need a new thermocouple, go to a good hardware store or Farm Center (bring the old part with you) and ask for a new one.
Dec 29, 2009 | Williams 1403622 Gas Compact Heater
Rangemaster 110 gas cooker - RH Oven lights but doesn't heat up
Will the flame go out if you turn the control knob to the off position?
Sometimes gas cooking control knobs have two seperate types of control in the one knob. One control turn the gas on or off, one adjusts the variable quantity of gas allowed through a gap to your flame jets. Some control knobs can get gummed up and stick a little. The can be fixed by carefully taking apart the control knob, taking note of EXACTLY how everything goes back together and cleaning any gummed up bits. Then reassemble the knob and drizzle soapy water over the control to test for leaks. A leaky gas join blows bubbles and makes noise. Let me know if this fixes the problem.
John
May 08, 2009 | Rangemaster 110 (Gas) Kitchen Range
Oven lights on low flame but will not come up on high flame .cannon chester cooker.suspect by pass is not working. Do I need control knob/thermostat with the phial. Thanking you.
all gas range ovens have a small metal box in the back upper area of the broiler burner; a gas line runs into this box as do two wires; this is a "flame control " gas valve; the way it works is: after the pilot has been lit as you turn the oven temp control a heating element in the box causes a small valve to open allowing a larger amount of gas into the oven burner to ignite the whole burner If you can only get pilot flame on high replace this valve
Apr 26, 2009 | Ovens
Vulcan oil heater
1. Check electricity is on.
2. Check oil is in the tank and valve turned on.
3. Switch the fan off at the bottom left hand corner.
4. Switch oil knob to No.1.
5. Set Air knob to No.3.
6. Operate re set button (right hand corner of heater under settings dial). Either press in until it clicks or if the pull out version pull out until it clicks.
Wait - ignition should take place in a few minutes and flames will appear on the left of the burner under the radiants.
You should get occasional yellow crests above the pure blue flame just visible below the top row of burner holes under the radiants.
After the red warning light goes out you can adjust to higher settings.
The radiants do not glow on low setting.
You can adjust the heater on to higher settings but this should be done gradually - no more than 2 settings at a time.
Some warnings:
* The unit must be correctly earthed.
* Do not use anything except heater oil.
* Never attempt to re-light the heater when it is hot.
* If the red light does not appear when the oil knob is switched on, immediately turn the oil knob off. Reasons include: Heater is too hot; Electric plug turned off; failure of ignition system.
Good luck - no responsibility taken for the advice (but it is largely copied from my Vulcan heaters instruction manual which I still have (installed in 1967).
Mar 26, 2008 | Heating & Cooling
Avanti DG241BS - oven will not stay on
There has to be a protection system in the burner assembly to cut the supply of gas to the burner if it does not light. For the case of an oven the supply must be cut off immediately if the burner and its pilot go out. For that gas control system to work the burner control must "recognize" with a sensor when the burner is lit and when it is not. Pushing the knob "in" momentarily on this model bypasses the protection system momentarily to allow a burner to be ignited in the first place. If releasing the knob extinguishes the flame the control system is not "seeing" the flame. I tried to find some detail info on you particular ignition system but to no avail so all I can offer is a general approach to these kinds of problems . You need to find and clean or replace the sensor used to detect a flame. It could be an optical one (doubt that) or a temperature flame sensor, a thermocouple sensor, or some other kind I haven't thought of. Fixing this problem involves first determining what kind of sensor it uses. A copy of a service manual for this model can help you determine that. Try to clean the flame detector, and if that doesn't work you have to replace it or the gas control assembly it is a part of. If you have a spark ignition and its not sparking when it should first clean it --carefully--. Spilled food can short them out. Unplug the range before doing this. The owners manual shows it to be under the top burners which can be removed for cleaning this.
Aug 07, 2007 | Avanti DG241BS Stainless Steel Gas Kitchen...
Weber Genesis Silver B Grill Logo
262 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
