Question about Frigidaire Microwave Ovens
Microwave runs with no power - Frigidaire Microwave Ovens
  • Frigidaire Master
  • 9,098 Answers
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
My microwave over just stopped heating but runs like it is heating
hi , now that's either power supply to power the magnetron or the magnetron itself ...
Regards
Rob
Jul 15, 2015 | Kenmore Elite Microwave, Model...
Why is the microwave running without being turned on?
These above range microwaves "hoods" automatically turn on a cooling fan even when the microwave is not in use. If you read the manuals you will see warnings about the fans automatically starting. Even when the microwave is not in use opening the door likely interrupts the power to the automatic cooling fan.
Jul 29, 2014 | Whirlpool GH7155XHS Microwave Oven
I have a Whirlpool Gold Accubake System Microwave. I have no power to the microwave. The outlet it is plugged into have power running to it and the circut breaker is good and only runs to the microwave...
Most likely the power supply has to be replaced; but it could be the safety switch too. Do you have any experience or knowledge in using meters and troubleshooting electronics? If not and you want to repair the microwave- send it out to a qualified/ certified microwave repair shop. Or else buy a new one. Best regards ~
Mar 13, 2014 | Whirlpool GT4175SPS Stainless Steel 1200...
FMV152KWA microwave buzzes when not running
Missy Uhland Bauman,
I understand that you are hearing a buzzing noise from your microwave, even though the door is shut and and it is not running. I would suggest to give the appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back. If you are still hearing a buzzing sound, I suggest either contacting the manufacturer or your local authorized technician.
-Best Regards-
Jan 10, 2014 | Frigidaire FMT118E1B Microwave Oven
Not heating
Hello
Power Supply
Check whether there is a proper power supply. Look to see whether the cord is connected to a grounded 3-prong outlet and the cord is fully plugged in. If the electrical system is built-in and no power cord is visible, replace or reset the household fuse or circuit breaker.
Microwave Functions
Some basic microwave operational steps may affect whether the microwave is heating. Open and close the microwave door, as the unit will not function with the door open, and push "Stop/Clear" to cancel any previous settings, such as the timer, which do not heat the microwave oven.
Setting the Microwave
Once the power to the microwave has been reset, or verified as working, and the microwave is ready to run, select a new cook cycle and press "Start" to see if the microwave begins to run and cook food as expected. Allow the food to cook for the alloted time and then open the microwave door and check to see if the food has cooked or heated. Choose a longer cooking time and restart the microwave if food is heating but is cooking slowly.
Repair
If all efforts to troubleshoot the function and power to the microwave still do not get the appliance heating food as expected, there may be a repair issue that needs to be addressed. Contact professional technician for advice.
Oct 05, 2011 | Sanyo Microwave Ovens
New maytag power shuts off and comes back in half hour
Depending on the model you may need a 15 or even up to a 20 amp circuit to operate the microwave. Check the installation instructions to be sure. What is most likely happening is the circuit in your home is not powerful enough to run the load of the microwave oven. If this is the case it could be dangerous. I would strongly recommend you have an expert examine the house wiring prior to starting the unit again.
Apr 20, 2010 | Maytag MMV4205 Microwave Oven
No power
you cant run a microwave with out something in it you will kill it fast you might be able to take it to a repair shop but it sounds like its fried running it empy is very very bad
Dec 12, 2009 | GE JES1288SH Convection/Microwave Oven
Magic Chef Microwave Shutting Down Problem in RV
your micrwave may run fine at 110 but it draws more power than the generator is putting out when the magnetron kicks on which is the part that creates the microwave causing the food to heat up. In other words the amperage is too low for the microwave. Amperage is what matters not voltage.
Apr 12, 2009 | Hotpoint RVM1435 Microwave Oven
Microwave Ovens Logo
65 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
